T Handle Hex Wrenches
Old 01-20-20, 06:19 PM
Tandem Tom
Quoted: 266 Post(s)
Liked 17 Times in 14 Posts
Maybe there is a "fix". My T Handle Hex Wrenches are getting rounded over. Short of buying new ones is there a way to "square" them up? I thought about grinding.
Tandem Tom is offline
Old 01-20-20, 06:27 PM
Digger Goreman
Digger Goreman's Avatar
Bikes: 1995 Trek 800 Sport, aka, "Frankentrek"
Quoted: 122 Post(s)
Liked 94 Times in 65 Posts
Put 'em in a vise and square cut the minimum off the end? No experience, just brain storming....
Digger Goreman is offline
Likes For Digger Goreman:
Old 01-20-20, 06:41 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 847 Post(s)
Liked 180 Times in 147 Posts
I routinely grind worn hex drivers back to new, sharp corners. Just go slow and don't overheat them, dunking them in water helps, or use a wet wheel.
dsbrantjr is offline
Likes For dsbrantjr:
Old 01-20-20, 08:27 PM
woodcraft
woodcraft's Avatar
Quoted: 1190 Post(s)
Liked 188 Times in 110 Posts
Originally Posted by dsbrantjr View Post
i routinely grind worn hex drivers back to new, sharp corners. Just go slow and don't overheat them, dunking them in water helps, or use a wet wheel.
+1
woodcraft is online now
Old 01-20-20, 10:24 PM
aggiegrads
Quoted: 86 Post(s)
Liked 7 Times in 7 Posts
I assume that you are taking about the square end, not the ball end. If the ball end is rounding, that is the end.
aggiegrads is offline
Old 01-20-20, 10:36 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1923 Post(s)
Liked 260 Times in 185 Posts
+1 on grinding worn tools back to square. If it was a decent quality tool to start with, it will be hardened steel, and difficult to cut with e.g. a hacksaw or file; thus the need to grind.
JohnDThompson is offline
Old 01-20-20, 10:48 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 856 Post(s)
Liked 111 Times in 82 Posts
+1
I have found dunking in water also makes my metal cutting, reciprocating saw blades last MUCH longer.
I haven't turned one into an "S" since I stated.
Bill Kapaun is offline
Old 01-21-20, 08:49 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 884 Post(s)
Liked 146 Times in 106 Posts
You can grind the ball off and square it. Then you have a T handle square end hex wrench.
But keep the ground end cool. As mentioned above, easy does it. Grind a small amount, quench in cool water. Never get the end glowing in any way.
WizardOfBoz is offline
Old 01-21-20, 10:43 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1896 Post(s)
Liked 271 Times in 199 Posts
Timely topic. I'm going back east to sit down with my siblings and settle my folk's estate. Up for grabs is an old grindstone. Big, heavy 30"? wheel, pedal powered, runs through water. Magic for knives. Free to me except shipping to the west coast.
Ben
79pmooney is offline
Old 01-22-20, 08:10 AM
Tandem Tom
Quoted: 266 Post(s)
As a woodworker dealing with metal is sometimes foreign😁!
As I grind them square I end up with a wire edge on some of the facets. How do up typically deal with it?
Thanks!
Old 01-25-20, 02:30 PM
aggiegrads
Quoted: 86 Post(s)
Thanks!
A fine file, or better yet, an Arkansas stone.
Old 01-25-20, 04:11 PM
billnuke1
billnuke1's Avatar
Bikes: Not nearly as many as before...
Quoted: 123 Post(s)
Liked 79 Times in 50 Posts
There are some inexpensive or at least wholesale priced Park Tool allen tools on eBay....oops! Wait! I bought’em! I keep’em in both shops, strapped to the stands, and these are are goin’ in both the vacation, and the camper tool sets.
The fold out sets are ok for the bike bag but I need full size sets everywhere else...a touch of arthritis make these full size wrenches a worth while investment.
billnuke1 is offline
