Campy 12 speed chain too long?
I知 just getting back into cycling with my first new bike to replace my 9 speed Campy Record. I ordered my new (Marinoni Piuma Ti) with Record components, and a compact crankset. I enjoyed unpacking it and tuning it up but I知 wondering if the chain is too long? It痴 sitting on the chainstay while resting in its lowest gears. I知 wondering if that might be why I知 having trouble getting the shifting right.
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 47 Post(s)
Liked 74 Times
Was the bike assembled or partially assembled when you received it? Sounds like the chain needs to be shortened. Park Tool has a video on how to properly size up a chain.
Really Old Senior Member
IF the chain is "drooping", either too long or the chain wrap capacity of the RDER is exceeded.
How much slack can you generate when on BIG:BIG?
This is the method I use for a simple check.
Normally, we want more than 1" and less 2".
Dangerous Old Man
A very simple way to get it right. Small ring up front, smallest ring in da rear. The chain length is determined by one simple thing, just long enough that the chain does not rub the rear derailleur arm. I will post a pic later, got to run right now...
Quoted: 1438 Post(s)
Liked 1,092 Times
Better be sure it is long enough to easily go on big-big or you are in for an unpleasant surprise one day.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
It would be. Small/small sizing optimized for the longest chain possible your derailleurs support. As opposed to big/big that optimizes based on the shortest possible chain size for the given cogs.
Your responses tell me I was on the right track. The bike came just partially disassembled, the drive train was complete. However, I asked for a compact crank, I assume that would require a shorter chain as well? Maybe that wasn稚 installed/shortened. Thanks!
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
This method works for an average triple crank, not so well for doubles. Not for my gravel bike, for instance.
Dangerous Old Man
I build all my rides up from bare frames. I run a 50/33 (special ring made in France for 5 bolt 110 BCD) and a 11/34 in da rear. As long as you don't go way out of spec with the rear derailleur and cassette, it works all the time. What you are looking at is a medium cage 4600 derailleur rated for 30 max, runs the 34 like a dream. Same for my other unit, same specs (50/33, 11/34), running a 4700 rear derailleur rated for 32 max, but sporting a 11/34 also. Both are medium cage (GS)....if I make the chain the next size longer the derailleur arm will rub the chain as the end/tip will be higher and interfere with the chain...
Quoted: 2026 Post(s)
Liked 1,095 Times
This situation is unlikely on a new bike set up by the manufacture but it can be done.
Be careful if the chain is a Campy 10, 11 or 12. All use a special joining pin that requires a Campy tool to install. If the chain must be shortened, you can't just push out a pin and reinstall it, like you could with 9 speed. Although Campy doesn't make a quick link, there are other brands that will fit and work. I remove the original joining pin and the pin next to it, on the same pair of outer plates, then use the quick link to join it.
Quoted: 942 Post(s)
Liked 526 Times
Sounds like the bike is in all kinds of disarray from the manufacturer. Before sizing your chain correctly, make sure the b-limit screw is set correctly. I advise you to visit park tool YouTube channel and watch everything associated with rear derailleurs (setting, adjustment/indexing) and chain sizing.
and yes the small/small chainsizing technique does work. This assumes correct cassette/derailleur compatibility (manufacturer should not be sending a bike with a cassette that is incompatible with the derailleur) and correct b-limit adjustment.
"Better be sure it is long enough to easily go on big-big or you are in for an unpleasant surprise one day."
Yep, be real sure of this. My former boss snapped the chain stay on his custom carbon frame by not checking this and then shifting into the big ring while on the largest diameter sprocket out back.
Dangerous Old Man
That is what bike stands are for. Always run though the gears before you get it outdoors in the wild....
Quoted: 2336 Post(s)
Liked 2,808 Times
here is a good vid for small/small sizing...... i have used this successfully with both 105 5800 compact 50/34 11/32 setup and vintage 52/39 12x28 setups
Quoted: 1814 Post(s)
Liked 1,692 Times
I’m just getting back into cycling with my first new bike to replace my 9 speed Campy Record. I ordered my new (Marinoni Piuma Ti) with Record components, and a compact crankset. I enjoyed unpacking it and tuning it up but I’m wondering if the chain is too long? It’s sitting on the chainstay while resting in its lowest gears. I’m wondering if that might be why I’m having trouble getting the shifting right.
The bike manufacturer had me remove the “B Link” and make a few adjustments. It’s all good, chain length was fine! Been enjoying it for a month now, and realized I should close this out. Thanks guys!
