Michelin Pro4 Endurance Tire
Bikes: Schwinn World Sport Jamis Ventura
I was thinking of picking a pair up for my commuter. Anyone have any experience with them?
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I don't commute, but I've used these tires for the last two years. They're excellent. I got ~3200 miles on the rear last year, and am currently using the front from last year on the rear. I've gotten two flats since I started using them, one from tire wire and another from a gravel shard; either of these would've happened with any other tire. They stick well enough to race on (I did last year).
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Quoted: 2952 Post(s)
Liked 3,106 Times
Excellent tires. Commuting tires you can race. Or racing tires you can commmute.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I like them. Replaced some gatorskins with them. They are very fast and easy. The endurance seems to be a good tire, with bead to bead protection.
I got a 28mm tire and it is the EXACT same size as the 25mm tire. I found that wierd. I did notice the tread width is a wider and the recommended pressure is 10psi lower (which is a good thing). Looks to be the same tire, designed for lower pressure and a smoother ride.
The 28mm tires are so small I'm thinking they will fit just about any bike outside of the most dedicated race machines.
Fast enough to race, strong and durable enough to commute on.
Liked 3,106 Times
Yeah, good point on the sizing. I don't have calipers but the "25mm" is the fattest 25 I've ever seen. They just *barely* clear my calipers.
Dart Board
Bikes: 13 Super Six EVO Red, 2005 Six13, 2015 CAADX
I have got two freak flats with them this year. But again they were above and beyond normal flats. One was a staple and the other was a pinch flat. I run 23's but 25 's are better if your heavier. They have lots of colors to chose from. The only downer about them is they are expensive.
I WOULD BUY ANOTHER, TELL A FRIEND TO BUY AND WAIT FOR A SALE.
V
V
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
No. We are running a pair of 23's, red ones, and they pretty much measure 23.
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
V
V
ProBikeKit on sale early in the year around $30 each. This January we did under that. Get 3, no shipping, and have a spare.
Mich did the same thing with the P4SC - 27 is the new 25.
So the 25s are oversized and the 23s are true to size? Then what sized should I get?
OMC
Quoted: 461 Post(s)
Liked 116 Times
Since you'll be using them for commuting, I'd go with the larger tires, assuming they'll fit on your bike.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Dart Board
I also want to give a shout out to another great Michelin tire the Krylion Carbon foldables -great price, tough, reliable, and fast tire -but I am not sure the colors are more than pinstripes on grey/black.
V
V
Liked 415 Times
Get the 25s. They will fit about anything. I even have one that I use sometimes on my track bike (i.e. something I race at the velodrome with) and it barely fits.
For road, I personally prefer the 28's as they are designed to run at 60-90psi
Michelin specifications (min/max):
28: 60-90psi
25: 75-110 psi
23: 90-115 psi
You will be just as fast on either of the 3 sizes, it rather depends on how stiff you want the ride to be.
I see no reason to use a 23, other than style or frame clearance. With a tire like this, a 25 or 28 is just as fast on a smooth road, but faster on rough or imperfect roads.
28: 60-90psi
25: 75-110 psi
23: 90-115 psi
Liked 3,106 Times
OMC
Quoted: 461 Post(s)
Liked 116 Times
Pretty sure the Krylions were discontinued about two-three years ago and replaced by the P4Es. The Krylions out there now are NOS. I went through a few of them, too, and they were good.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Jedi Master
I just measured my PE4 25s, and they are a hair over 25mm on an 18.2mm rim. I like them a lot, but Shwalbe Marathon Plus HS440 is my favorite commuting tire followed closely by the Vittoria Randonneur Pro
Dart Board
How are you guys with the Pro Service Courses? I have not tried those yet.
V
V
Liked 415 Times
I don't know what was wrong with the early tires, but I bought mine in the fall, and it dry rotted over the winter (to the point I could see the cords at the tread/sidewall boundary). It took some work, but I got a replacement that so far hasn't fallen apart on me.
That is an expensive tire to fall apart in the garage. I'm hoping this one lasts longer, or its going back too. So far, so good.
a few hundred miles on a a new pair last season, one small sharp teardrop shaped glass caused a flat. I run the 25's, measured 27, 90-95 rear 85-902 front. I'm about 165 and change. No discernible wear, but I'm not hard on tires either. Really comfortable.
Hey all,
I ordered the tires a couple days ago and went with the 23s since I got them for $6 cheaper each then the cheapest 25s on Amazon. They should get here in the next couple days. Thanks for all the advice!
