Lights and out front mounts
Quoted: 18883 Post(s)
Liked 10,646 Times
It's time to put the lights back on. I'm not thrilled about giving up space on my bars. Thinking about getting an out front mount, probably the Enve one. Can you attach a light to the bottom of these mounts, securely? Or failing that are there lights that use the quarter turn mount?
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
I have a helmet mount, and my commuter has a mount at the fork crown. I know people who like the out front mounts and they seem to work very well. Just depends on what you want.
I have to find where I put that helmet mount for the summer though...
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
I mount lights about halfway down my forks. Depending on forks you may have to make an adapter to convert round to fork shape. Lower is better.
Results matter
Results matter
wears long socks
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I am a big fan of out front mounted lights and use a Barfly Road Max 4 with Light & Motion Urban 800. The Urban light uses the GoPro mount. Using the GoPro mount allows the vertical angle of the light to be adjusted. Below is my bike.
A universal style holder for lights comes with the Barfly mount but I have not used it.
I also use a helmet mounted light with the bar light.
-Tim-
-Tim-
Liked 10,646 Times
The Barfly universal mount looks really promising.
I've never used a GoPro before, how does their mount work? Can it go on the bottom of the computer mount, like in your first pic and 69chevy's?
What I like about the Enve mount is that it attaches directly into the stem, leaving you with all the room on your bars.
Quoted: 20810 Post(s)
Liked 9,456 Times
Combo mounts with GPS and camera (most often GoPro) are the most common, but there are a handful of companies (and a number of individuals with 3D printers) that are making GoPro adapters that'll fit on to the quick release mounts for some lights. Just do a search for 'NiteRider Lumina GoPro adapter' or the like.
wears long socks
Light & Motion Urban 800 FC w/ Road Max mount ? Bar Fly
- Soli Deo Gloria -
Liked 736 Times
Yes, the GoPro mount attaches to the bottom of the computer mount. Lots of accessories such as the lights pictured use GoPro mounts.
A GoPro mount itself is just a dovetail that slides together. A screw goes through it to hold it in place. I replaced the 3mm hex head screw from the Barfly with a Phillips head because mine stripped after a while.
-Tim-
Quoted: 87 Post(s)
I'm using a Light & Motion Urban 800 + GoPro adapter + K-Edge Garmin mount, and I love it!
Mount is extremely secure. Light can be easily adjusted up/down/left/right
Light is easily detached via thumbscrew
Liked 10,646 Times
So I can buy a GoPro mount and attach it to the bottom of the Enve computer mount? (I don't have the Enve mount yet - maybe it would be obvious if I were looking at it.)
Thanks for the info and for putting up with me.
Fax Transport Specialist
Is the enve stem mount a universal fit, or do you need an enve stem? I thought I read that the bolt spacing was different.
- Soli Deo Gloria -
Liked 736 Times
By "Enve mount" I thought you meant a mount made by Barfly for Enve stems. Barfly makes direct stem mount for Fizik and 3T stems and that is what confused me.
I did not know that Enve makes their own mount and eventually saw the litle ENVE logo on the mount in your picture. You will have to contact Enve to determine if they make a GoPro style mount which attaches to the one you pictured. I don't know. It will have to attach to the bottom some proprietary way which only Enve would know.
If you have a Fizik or 3T ARX II stem then a Barfly direct stem mount would work. I don't know if K-Edge makes something similar. There are lots of Rube Goldberg setups out there.
One thing to consider about direct stem mounts is that they typically can't be angled up.
I lust after this setup. Fork mounted Bontrager IONs with ANT+ remote control.
Featured Bike: Vincent Kendziora?s Van Dessel WTF (Whiskey Tango Foxtrot) | Gravel Cyclist: The Gravel Cycling Experience
-Tim-
Likes For TimothyH:
Liked 10,646 Times
Thanks everybody this has been very helpful. I'll post pics of my setup when it's ready.
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
The mount is for a Garmin on top and GoPro on the bottom. GoPro mounts are tabs with holes that a bolt goes through allowing for tilt adjustments.
mvaro2002
6
06-30-14 07:12 PM
Donnie Johnson
9
06-04-14 02:59 PM
