Try Your Hand At Black Math!
Here's what I'm working with.
I'm going to buy a JIS taper, symmetrical cartridge BB. Now, class, what length spindle would you choose?
- 120mm spaced frame
- Stronglight 49d crank arms with single 48t 3/32" ring
- Fixed/fixed hub with 1/8" cogs
- 68mm English BB shell
- 1/8" chain
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
118mm? I'd probably go narrower, if possible. I recently pulled a 103mm off the front of the Bilenky, but it uses a Specialized chainset.
Quoted: 1217 Post(s)
Liked 187 Times
Keep an old cup & cone BB around so you can mock up the crankset and get a value for X. Failing that, start long and then you can space the chain-ring in to pretty much whatever you want.
113mm sounds like the ticket. Thanks!
Bikes on Flickr
Bikes on Flickr
Quoted: 378 Post(s)
Liked 1,410 Times
- 120mm spaced frame Not much of an issue
- Stronglight 49d crank arms with single 48t 3/32" ring need to know how deep they'll slide onto JIS
- Fixed/fixed hub with 1/8" cogs Not much of an issue
- 68mm English BB shell Not much of an issue
- 1/8" chain not much of an issue.
Look at your clearance to the chain stay for the single chain ring. That's about your only worry.
If it's close, use it.
If it's too long, guage the extra length, double it.
Ex: 4mm too long on the R means your spindle is 8mm too long.
Adjust for asymmetry.
If it's too short, guage the extra needed, double it.
Ex: if you need 4mm more length, you need 8mm more spindle.
Eyeballing works as well as anything, if you're sober.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
My guess is the 113 will be too long.
Could be. I am using a model 93 with a single ring in the outside position on a French frame (68mm shell) with a 107mm JIS BB (symmetrical) and the inner chain ring tabs are super close to hitting the chain stay. That's not an issue with the 49d, though. Sutherland's just lists "Stronglight" cranks so I guess they're suggesting that all Stronglight cranks fit the same distance between outer ring and BB shell for a given spindle.
So, you'd go with what spindle? 110mm? I'm afraid that with a 107mm I might be getting close to bottoming out the arm on the BB shell.
Bikes on Flickr
Bikes on Flickr
multimodal commuter
Liked 574 Times
Heck if I know. Thinking about it now, I have seen Stronglight cranks sit far inboard of other cranks, so maybe you'll be fine. I do know the last three BB's I've bought were longer than desired. No doubt this was my fault.
incazzare.
I'd try what I had on hand and see if it needs to be shorter or longer than that. Then you'll know about what you need.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Restore, ride, repeat...
I don't have any 1.37" x 24tpi cups on hand, hence all the figurin'.
Bikes on Flickr
Bikes on Flickr
I agree the 113 is likely too long. I'm using a 114mm JIS taper with a #93 double and have about 12mm clearance between the 53 ring and the stay.
110 seems about right if you're worried about the 107 being too close. Alternatively you could get the 107 and add spacers if necessary.
True, but spacers increase the likelihood of the NDS arm bottoming out on the BB shell. I guess I'll roll the dice with a 110mm spindle.
Bikes on Flickr
Bikes on Flickr
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
I think you need to know the position of the cleanest chainline on the original set up and measure the distance from a fixed centerline on the frame and do the same with the fixed, mocked up, and then subtract the difference and multiply by two
.....ahhhh Hell, it's still a guess at best.
car dodger
get a phil BB = adjustable.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Yeah, that'd do it. Pricey, though. How much adjustability do they have?
I'm not sure. I was going to go with a VO, which I think are symmetrical.
Bikes on Flickr
Bikes on Flickr
Liked 2,568 Times
Here's what I was thinking of... DS length is the same as the "107": https://web.archive.org/web/201010220...ttom-brackets/
(For Shimano, at least.)
Quoted: 3811 Post(s)
Liked 6,707 Times
I'd roll the dice with a 108mm spindle and have a couple of 1mm spacers on hand.
incazzare.
I've got a bunch. I can send you some if you want.
Nah, thanks. I'm a risk taker.
Bikes on Flickr
Bikes on Flickr
car dodger
I think the phil BB has 5mm of adjustability. But I wouldn't want all 5 sticking out on side or the other!
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
The last SS conversion I did was from a double chainring late 70's Raleigh. The distance of the stock outer ring was 5+mm off the stay, to get a clean chainline, running 1/8" chain, the new ring ended up being 3+mm off the stay. So maybe it needs to be 4 or so mm shorter than it originally was, or so I thought! But, I was wrong!!!!
The resolution was to go to my LBS with his favorite brew ( chilled, 15 minutes before closing time), told him what I was trying to do. He then grabbed a box of spindles and cups and began searching for a good line, once he found it, measured the spindle and order the BB for me. In the end, I paid for the BB and the install, We drank some excellent Belgium Triples and I got a clean chainline without the use of spacers...which somehow makes me feel good about the decision.
