Frame Identification required
Bikes: 2012 Pinarello FP 2 (SOLD), 80s Gitane(SOLD), 89' Panasonic Les Mailots PTi (SOLD), 86 Vitali, 2004 DeRosa Planet, 80s Mata Cicli, 80's Schauff 4 Strene, Francesco 80's Moser San Christobal, 80's Friend Victory
Guys,
Came across with a seller in my city who want to let go this frame.
According to the owner, it is cycles Gitane frame.
Size:
Top tube 57 cm
Seat tube 53 cm
Bottom bracket serial: F2K 0188
Headset: Shimano
Will appreciate if anyone could give your thought based on your experience.
Thanks.
side view
Headset
Bottle holder
Internal cabling
BB
Serial
Size:
Top tube 57 cm
Seat tube 53 cm
Headset: Shimano
Thanks.
side view
Headset
Bottle holder
Internal cabling
BB
Serial
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Like the proverbial yuppie, I built a couple of French bikes, for the experience. So I ain't an expert, by any means. But, this looks to me like a 1988 gitane avenir, with a repaint. How the heck would I know that? See here
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
very possible: the paint could even be original, the catalog lists it as "white pearl".
This was a French model, and the catalog shows it with nutted brakes (check that out) and a Huret RD...if yours is an Avenir it should have the Huret stop at '4 o'clock' on the dropout hanger, I would reckon, and probably a Huret branded dropout, too.
But, since we're talking Gitane, I could be totally off-base
Thank you so much for pointing out the key identity...those photos were snapped by the seller...I plan to pay a visit to him tomorrow and if everything goes well..I will purchase it.
You mentioned about the nutted brakes..would you able to share me a sample ?
Huret stop will look like this image?
Hi luker,
thanks for the help!
if this is a gitane, this could be some other well built frame I supposed?
anyway, really appreciate your help
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
To narrow down the pedigree, you need to determine the BB (35x1 for French, Swiss) and headset threading, steerer tube ID (22.0 French, 22.2 otherwise), BB shell width (probably 68mm), and seat tube OD (28.0mm for French, 28.6mm for almost everyone else). With the forged dropouts and wheelbase adjustment screws, it is probably a butted moly steel frame -- you can verify this by looking for 26.4mm or 27.2mm seat tube ID, depending on whether the OD was 28.0 or 28.6.
Liked 1,062 Times
Hey unworthy1,
Here's a pic from Velobase that shows Shimano DOs, just for example
Compare that to the next pic which shows a typical Huret DO, this tab or stop is at the "4-o'clock" position...not saying that eventually Huret may have made some DOs that adopted the more common form, but I haven't seen them. Also that frame might not be the model that came with a Huret RD, so it might have a standard DO...you'll know when you see it.
Hah, just realized that "7" can look like "4" when you view it from the wrong side...keep your POV on the drive side, my boy!
Will take note of all who shared!
Stay blessed!
No, that shows a hanger with typical "7-o'clock" tab position, such as found on Campy dropouts as well as most other brands of Italian and Japanese DOs.
I shall post a closed up picture once i got the frame.
I offered him $115 and I got the deal
Quoted: 4722 Post(s)
Liked 3,036 Times
While I know little about non-boom era Gitane, that appears to be an Asian serial number format for 1982 or 1992. The latter is by far the better candidate given the dual bottle mounts, internal cable routing and uni-crown fork. Given the era, I wouldn't be surprised if Gitane, like most other European manufacturers, was having a lot of their production done in Asia. There may not be any French indicators.
How do you determine that is Asian serial? Any website which can refer?
I have took the frame today and I again check with the seller, he said he could not remember if this is a gitane or viner. But confirm this is a european frame.
I have gotten the frame
Here are more details that I observed from the frame
Weight: 4 kg (including BB and headset)
RD dropout:
indication - 7 o'clock
no stamping on the bracket
Rear brake holder:
Flat top & bottom
Rear cabling housing
Dedicated attached to the chain stay
Round shape
RD dropout:
Rear brake holder:
Flat top & bottom
Round shape
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
For some reason I was thinking Univega but I see the OP is in Kuala Lumpur, so that is out. I do agree the frame look "Asian" to me (yes those letter go to www.FoxTV.com) looking at the frok crown and internal cable routing. I also agree it is likely closer to a early '90s frame.
Second thought is maybe a Fuji or Pannasonic. I suspect whatever it is, this model and likely brand was never seen in the US.
Sugar "Kane" Kowalczyk
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Most mid level and higher Gitanes that I encountered in the 80's had better looking lugs (windowed) that what that one has. Lots of them aslo had nice touches like diamond shaped reinforcements at the ends of the seat and chainstay bridges. and the top cable routing comes in and out of the top of the tube, not near to the bottom and to the side as this one has. So this one is not showing the typical "Gitane" signs I would suspect, which makes the possibility of a bike sourced from maybe an Asian subcontractor that have different designs from what they had in France to use. Weird thing is, the frame design looks very similar to later 80's/early 90's Peugeots too...
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Regardless of the heritage, it looks like it should be a very nice bike.
Real cyclists use toe clips.
jimmuller
jimmuller
After all, I believe this could be a good frame back then as it has double bottle mounts and quite a good finishing at the joints.
I am not too sure 4kg for this frame would consider light for classic road bike?
Liked 1,062 Times
all I can say is now that I see these pix I doubt that it's a Gitane, also doubt that it's a Viner, but I suppose it could be almost ANY brand that sourced frames from an Asian contractor in the late 80s or later. The brakebridge looks similar to a Cinelli or GPM unit, but the dropouts look unlike any I'm familiar with (see those sharp corners on the raised forging?), similar to a lot of known shorty DOs, yet different...maybe they've been modified.
Usually associate that "slot" style BB mech with cheaper Asian frames...
I wonder if it this has an Australian connection?
Anyway, I am still happy with it and will look forward to do a repaint and shop for classic stuffs to fit into the bike
I find that the shifters mounts are rusted..can sandpaper or metal polish do the job to restored it like this?
Liked 3,036 Times
My initial thoughts were Fuji too. The serial number format is very similar to that used by Fuji in the 1990s, but is not identical. There are one too many characters. However, that could be an accident, as the OP does show a space in his original post. However, I would think that by this time Fuji would have been producing Fuji branded dropouts and not using generic versions. Still, I can't say that with absolute certainty and therefore cannot rule out a Fuji.
I've been collecting and studying serial numberS for a number of years and, to date, have identified and decyphered the serial numbers for approsimately 50 different Asian brands, along with several non-Asian brands. If you want to see some examples of my work, check out the Serial Number Database threads for Centurion, Fuji and Nishiki, on this forum.
I am getting more interested to find out further about the real identity of this frame.
Like some quoted, this frame which comes with internal routing brake cable, dual bottle mount...might be a fairly good frame.
Though it might not have a perfect DO's...the frame weight at 4KG.
Back then, this weight of frame consider normal? Means any lower end road bike would also weight the same.
Thx
Bikes: i don't have a bike. a few frames, forks and some parts. that's all
Quoted: 54 Post(s)
Liked 52 Times
i was always starting from the 'diamond' shaped seatstay top reinforcement as a Gitane signifier.
(with exceptions, of course)
to my 'untrained' eyes, the frame looks 80's Japan-made
with its typical mixture-hybride-mish-mash of all different kind european signifiers details.
(shown across lotta major brand names).
i mean, regardless, it will come out a beautiful project for sure.
"versatile" to any components group in terms of style or functionality,
therefore easier to find the right components—when determined— right?
Liked 3,036 Times
4 kg. is very heavy for a frame. It's not quite as bad if you're talking as rec'd condition, with the fork, headset and bottom bracket. The best indicator for frame quality is the required seat post/internal seat tube diameter, though given the apparent era, even the entry level sport models were using seamed, butted CrMo, so it may not prove anything.
Bianchi Goddess
Liked 2,923 Times
very fine sandpaper or steel wool will do the trick.
Next is to brain what color should I go forward?
Noticed that classic are usually in Blue,Red,White...sometimes yellow (which I am considering)
I would like to confirm, this frame should be able to fit Shimao's or Campy groupset ??
