Awesome little disc brake gap tool.
Quoted: 763 Post(s)
Liked 1,731 Times
So I saw this the other day and thought for $8, I'd give it a try. While I've not had issue with the gap in my brakes, sometimes I felt like I was not always getting centered. With this tool.....no issue.
Just pop it on, squeeze the brakes a couple of times, tighten the bolts, perfectly centered each time.
Quoted: 1186 Post(s)
Liked 289 Times
Unless I'm missing something normally hydraulic discs don't have a gap between the pads and disc. At least they don't in a vehicle. Are they different somehow on a bike?
It's not clear that this tool helps centering any better than doing the same procedure without the shims. It just creates a small gap between the pads and disc. As soon as you squeeze the brake lever the gap will go away.
The tool, as far as I know, was originally designed for mechanical brakes, which would make sense, since business cards are compressible. It doesn't really do much for a properly operating hydraulic brake. If bolts are walking the caliper, drop some oil on top of the washer beneath the mounting bolts' heads.
Quoted: 86 Post(s)
i think my shimano xt brake came with something similar. two plastic spacers to keep the pistons from coming completely out of the caliper when there were no brake pads present, and another, narrower, set to establish a gap when installing new pads.
Liked 289 Times
Yes, bicycle brakes are different. On even a modest car, you have over 100hp behind the engine, and the dragging brakes means nothing significant (fractions of a horsepower?)...most people, on the other hand, would have trouble generating even 1 horsepower, ergo, rubbing brakes are bad. You should get no rubbing under normal conditions.
In other words, the spring keeps the pads from clattering, but it doesn't retract them. The clattering has little effect on power loss, but would drive most people insane, since they are very much audible (see, people noticing the pads clanging on the slide when they apply the brakes, rocking the bike backwards/forwards).
at least it's cheaper than the Hayes tool https://www.universalcycles.com/shop...41&category=25 although it lacks the cool purple anodizing
I don't need it for my BB7's. When setting up, just loosen the brake some. Squeeze the brakes, they are now centered and tighten the bolts. Adjust pads as needed.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
I used this guy's method when setting up my BB7's: adjust both pads all the way out, loosen rotor bolts, turn inboard adjustment one full turn, then the outboard adjustment all the way in until the wheel is locked. Tighten rotor bolts. Adjust outboard pad out until wheel turns freely. Adjust inboard pad by 2-3 clicks outward. Make any additional adjustments necessary to ensure the pads don't rub the rotor at any point, and to achieve desired lever travel.
Took me a couple of times to get it right initially, but after that it was pretty easy. This method also ensures that the pads are square to the rotor. Not sure if that tool will do that.
