Removed chain pin
Removed chain pin
Hi there old masters of vintage bikes,
As needed to repaint the frame on an old Raleigh from 1984 I removed the chain by taking a pin out - shall I get new pin and if so which as is 2x6 (12 speed) or get chainlink and if so which as chain I think is slightly wider than 8/9/10/11 ring ones?
Many thanks for you help
Quoted: 1370 Post(s)
Liked 1,743 Times
Were it me and assuming that you are running a five, six, seven or eight cog set, go with an eight speed chain. They are lighter and easier to work on, in my opinion. I use them on all of my bikes and guess what - they all have a removable master link, making it easy to remove the chain for what ever reason. The chains, SRAM, are not all that expensive, again my opinion...
52psi
Quoted: 790 Post(s)
Liked 800 Times
Google KMC Chains.
Never push the pin all the way out. The way to do it is to push it only part way out, just far enough to be able to wiggle the link open.
It is extremely unlikely that you will ever find a matching replacement link or pin. But don't worry. Chains are consumables. Never hurts to replace it. Try a SRAM or KMC 6/7/8 speed chain as suggested. I vote for SRAM, by a nose.
Likes For Salamandrine:
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
While I don't recommend it and suggest a new chain (cheap), the pin can go back in with needlenose, 5 hands, patience, and copious amounts of expletives.
Likes For dedhed:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2182 Post(s)
Liked 4,526 Times
+1. Did it once (successfully), and - unless I become very poor - will not do it again.
Likes For non-fixie:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
A couple times (on at least two new builds), a new 8-speed chain skated between the two chainrings on a double. A new 5-speed kmc chain solved the problem.
Quoted: 796 Post(s)
Liked 522 Times
My method for dealing with pin connector chains
1. remove pin with chain tool
2. remove chain and place in trash/recycle
3. buy new SRAM 800 series 8 speed chain with quick link
4. lnstall
5. Smile cause you never have to deal with #$%^&8ing pin connectors again!
Note having the park quick link tool (pliers) is handy if you need to uninstall the chain.
4. lnstall
Quoted: 556 Post(s)
Liked 132 Times
But it was worth it. A nearly new Sedisgold chain. I wasn't about to throw that out.
Good luck getting that pin back in the chain.
Quoted: 195 Post(s)
Liked 206 Times
Good luck is right. You guys that put the pin back in place have my admiration! I just popped the next pin over and didn't push it all the way out and tossed the "broken" link I screwed up. Unless your working with close tolerances you'll be fine. By buying a new chain you may find it hops on your old freewheel. Why take a chance?
Quoted: 2350 Post(s)
Liked 1,729 Times
MEASURE the chain for wear / elongation. If you've just bought the bike, you don't know if the chain might have been replaced very recently. Replace if there's more than 1/16" elongation over 12 full links (12"). Or if you know that it's the original or a very old chain, replace. Or use a Park chain checker tool. If you determine the chain is fresh, you have the option of lining up the pin with a needle-nose pliers and trying to press it back in. It only took me three hands and a few cuss words.
Half way there
Quoted: 985 Post(s)
Liked 879 Times
To the OP: Amazon has 5/6 speed KMC Z33 chains for about $6. These do not come with a quick link.
Super Moderator
Quoted: 1173 Post(s)
Liked 924 Times
If I were reusing the chain, I'd splice in a link from another chain.
If the chain's old, replace it as suggested already.
Shifting is fun!
Bikes: Yes, please.
Liked 4,526 Times
I did. Very briefly.
Quoted: 863 Post(s)
Liked 2,227 Times
I have done it a couple of times...P.I.A. Don't let the pin come completely out! Needle nose trick works but not the easiest maneuver . Get a new chain , then the world is happy again, Joe
Super thanks to all who replied to mu post - new chain will be....
A note to editor - could not even reply to no2 as he added photo of his bike? Rules are one thing, being petty is another IMHO.
Liked 1,729 Times
^^^^ All you'd have to do is remove his photos from your reply. Nothing "petty" about it; it's a programmed rule, not an arbitrary decision. Without the "10 posts" rules, spammers / "carpet-baggers" tend to dash in and clutter up the forums with junk posts. In addition, you're only two posts short of the threshold.
Liked 1,729 Times
^^^^^ Been a while since I registered, but I think you get a "Welcome" Email (or perhaps a PM) that mentions the 10-post stuff.
Liked 1,729 Times
When you can snatch the quick-link from my hand.....
Señor Member
Quoted: 1491 Post(s)
Liked 1,072 Times
I've had people who I think should know better try to tell me that it's dangerous to break chains and put the pins back in. I've only had one experience (out of dozens) where the chain was a problem after I did this. That said, mixing and matching between chains that aren't identical is something I would not attempt.
