what size seatposts does a bridgestione keirin frame use
huge member
I don't want to try to jam my miche seat post in a frame it doesn't fit
Bikes: Land Shark, Level Professional, Tsunami singlespeed, Giant Reign 1
depends on the frame. 27.2's pretty common.
jam it in. if it doesn't fit it won't go in, and then you'll know. No biggie. 27.2 is the most common size.
The Autopsy
Bikes: RAP / 1949 Malvern Star 3 Star / 1954 Super Elliott
thebigmrT
Bikes: IRO Mark V, Panasonic Sport 500
caliper isn't always right due to human error(read: measuring in not the exactly center of the tube) we have a cool little tool to gauge the tube, it steps up, i think by 0.2mm and when it stops you know what size the tube is...so bring it in to a shop
"not enough rage"
Bikes: Old ****ed up Cannondale roadie, peice o **** Gitane as a beater, and I use my Nishiki for bike camping
Originally Posted by trons
tubing tubing tubing tubing tubing what kind of tubing
thebigmrT
i actually have no idea, i just always call it the seat tube deal, when im in today i'll see if anyone knows a name for it
ganbatte!
Bikes: '06 Vanilla touring, '09 Vanilla cx, Zanconato cx, Moots Psychlo-X RSL prototype, Nagasawa track, Kalavinka track, Black Cat 29er, Cannondale Rize 2 26er, Serotta CRL Legend
Same here, although oddly I've had both 27.0 and 27.2 posts in the same tubeset (Ishiwata 019)
3RENSHO SRA | CO-MOTION CROSS | SAMSON | KALAVINKA | DE ROSA | DE ROSA PRO | CANNONDALE SIX13 | CO-MOTION NOR'WESTER
many many bikey photos
Standard post diameter is 27.2. Seat tubes are seldom perfectly round in the vicinity of the seat lug, so it may not feel like a fit for a 27.2 but only because the tubing is slightly ovalized. That doesn't mean that you want to put in a smaller post, because it will loosen up or the seatpost clamp will overclamp and never fit right. You can also have paint, flux, some brazing metal, or whatever that affects the inside diameter. If a 27.2 doesn't fit properly, you may want to have a shop run a flexhone through the seat tube just to clean it out and remove any burs -- that can make the difference to give you a very clean fit. A builder like Nagasawa uses one before his frame ships, but other frames -- especially those produced in larger numbers -- don't necessarily get this treatment.
If you go to thicker tubing sets they jump up in wall thickness by 0.1 mm, which of course means your inner diameter jumps by 0.2 mm increments. However, seat tube sets typically don't thicken up at the top, just so you can standardize on a 27.2. Now occasionally a builder will use another tube (not the one intended for a seat tube) and will have butting at the top end that drops down in inner diameter slightly. There are also unorthodox tubing sets or loose tubes that are used from time to time (because they're available, because a frame needs extremely long or short tubes, because someone wants to use them up, or because someone had a very long tube or very short tube that wasn't trimmed within the specified range), and they can create odd seat post diameters as well.
If your frame was built with a standard tubing set and was cut within the specs of the correct designated seat tube, it should be a 27.2. I've probably seen a couple hundred full NJS keirin frames up close and had to borrow a seatpost and saddle from time to time. I've found a 27.0 seatpost once; all the rest were 27.2. Hope that helps.
Bikes: track bikes, etc
27.0...HOLLA! That was my fly ride and then the Rootbeer one was 27.2.
Originally Posted by dutret
trackosaurusrex.com is just about the best thing ever!
The Autopsy
Originally Posted by Ceya
I have had only 27.0 and 27.2 frames.
S/F,
CEYA!
S/F,
CEYA!
huge member
If your frame was built with a standard tubing set and was cut within the specs of the correct designated seat tube, it should be a 27.2. I've probably seen a couple hundred full NJS keirin frames up close and had to borrow a seatpost and saddle from time to time. I've found a 27.0 seatpost once; all the rest were 27.2. Hope that helps.[/QUOTE]
MADE IN HONG KONG
Bikes: some but not enough
note; there was never anything that would bar a shoemaker from owning a track bike.
huge member
mess that 1rst one up. anyway.
that 27.2 seatpost is not fitting at ALL.blurrs, paint,even tried to spread it open with the trusty ol' screw driver so you can add one more to your list
and an empty road
of the ~15 bridgestones current listed on eframebank, two have the seattube listed as 27.0, the rest being 27.2. good luck.
