Windsor Timeline thoughts
Asker of silly questions
Bikes: '09 Cannondale Aluminum Synapse
I havent seen a Windsor Timeline thread here, so I thought I would start one up (since I am thinking of purchasing said bike).
https://bikesdirect.com/products/windsor/timeline.htm
Now, what do people think about that bike? Specifically, the frame. I am looking for something that is slightly more relaxed geometry, with waterbottle mounts. I was gonna pull the trigger on the Dawes SST AL, but that sold out. I love the fact that the bike can mount fenders, brakes, and has capability for larger tires, etc. I have zero plans for barspins or any trick doing whatsoever. I want it strictly for spinning around with slower roadie friends.
In the end, I could see replacing almost every part on the bike, which is why I was wondering specifically about the frame. Does the frame seem like one that will last? One that will be worthy of upgraded parts?
Thoughts?
Thoughts?
Quoted: 430 Post(s)
Liked 460 Times
if you want a cheap bike that'll get you on the road right away, then i think the timeline is a good choice.
if you're looking specifically for a frame to build around, i would start with something nicer.
that said, it's up to you if you want to gradually put nicer parts on that frame. i mean, regardless of the frame, nicer parts = nicer bike overall.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
If you just want a frame, and a project I'd suggest starting with an 80's Japanese sport touring bike. You can get a great riding frame with horizontal dropouts and large tire clearance for next to nothing. Then, mix and match parts to your hearts content.
If you want something to ride now, the timeline is a pretty good bike.
danke
They're both probably around 20lbs depending on the size you get. If weight is of any concern, then go with a kilo tt, the frame is made with better steel and double butted.
I am thinking about getting either Kilo TT and Windsor timeline as well.
1 thing attract me about the Windsor is that it already comes with freewheel cog which I prefer a single speed instead of fixie.
And it also comes with 2 front and rear brake, with $300 something, i guess it's pretty good deal.
However, I've seen lots of comment recommend the Kilo TT for beginner.
So i need some advise ~~~~~
danke
Get the windsor if you like to coast, kilo if you want to do track stands.
Do u have any idea about siZe?
I am 5'8
should I get 54 or smaller ?
I know for kilo I have to go for 50cm since it has bigger frame or something
I am 5'8
I am 5'8" and like a 54c
[note Kilo is sized C-T vs the standard C-C on most bikes including the Timeline]
https://www.bikesdirect.com
"First they ignore you, then they ridicule you, then they fight you, then you win." – Mahatma Gandhi
Bikes: 1972 Paramount Track, 1972 Paramount P13 Road, 1972 Paramount Tandem, 1986 Paramount Road, Merckx MXL, Gunnar Cross Hairs, Samson Illusion NJS, KHS Aero Track, Titus Racer X 29er, Tom Palermo Custom Touring
danke
SO much easier to track stand on fg.
Yes its a flipflop hub, but you'll prolly have to buy the cog.
baldinbro
Singlespeed & Fixed Gear
8
08-16-15 06:58 PM
heymatthew
9
09-04-14 01:12 PM
