Repair of 90's Rapidfire shifters
Old 04-08-24, 08:33 AM
jacksbike
Bikes: Trek 7.5 Hybrid, Trek 1.1 Road, Holdsworth touring,Raleigh International,Ritchey Commando,Italvega Speciallissimo,et.al.
Quoted: 23 Post(s)
Liked 11 Times in 11 Posts
Hello Everyone,
I am a long time volunteer at a local non-profit that repairs and gives away bikes. We receive quite a few 90's era ATB's with Shimano Rapidfire shifters that are gummed up and do not operate. I am looking for suggestions of what solution(s) to soak the shifters in (off the bike) that will dissolve the hardened beeswax -like old Shimano grease. So far I have been pretty successful soaking them for about 2 days in gasoline but I am not crazy about the residue left (or flammability). I have heard of using mineral spirits, acetone, brake fluid, etc... I would like to use something safe and if possible non harsh chemicals, I am open to any and all suggestions to solve this problem ! Thanks in advance.
jacksbike is offline
Likes For jacksbike:
Old 04-08-24, 09:21 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6238 Post(s)
Liked 4,246 Times in 2,381 Posts
Originally Posted by jacksbike
Hello Everyone,
Soaking the whole shifter isn't the way to fix the problem. You need a more targeted approach. The problem is that the pawl that moves a gear forward tends to get sticky. Spraying lubricant into the shifter housing may fix the problem but if you take the cover off the shifter you should be able to see the pawl that is the problem. Here's a screen short from a YouTube video that shows where the pawl is
Direct lubrication to the pin that the pawl is on and make sure it can move back and forth freely. Light oil will do to lubricate it.
Here's the
I got the screenshot from.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 04-08-24, 09:36 AM
'02 nrs
'02 nrs's Avatar
Quoted: 808 Post(s)
Liked 2,999 Times in 1,506 Posts
rapidfires/
if above video isn't fixing the issue you can further dismantle the unit.there are 3 spring attachment devises that all need to line up on reassembly.when apart you can physically remove the pawl off the shaft & thoroughly clean the gunk off.you may get lucky by using a fast drying spray solvent like carb gumout with the precise nozzle but there may still be gunk within.my '94 stx shifters have needed 3 cleanings-the gunk is very stubborn at times.
'02 nrs is offline
Old 04-08-24, 09:38 AM
Aubergine
Bad example
Quoted: 847 Post(s)
Liked 263 Times in 121 Posts
I hate those shifters. The problem that I come across is that there are too many different versions of those shifters, and not all of them make it easy to take the cover off those pawls. If you can get the cover off great! But if not, flooding the mechanism while shifting it back and forth is the only way to fix them. I hate to say it, but a few times I've had to tell customers to head to a shop for a new one.
Aubergine is offline
Old 04-08-24, 01:26 PM
Arrowana
Bike Sorceress
Arrowana's Avatar
Bikes: Yes
Quoted: 62 Post(s)
Liked 116 Times in 66 Posts
Typically I start by removing any covers that can be removed, spray in some Clean-Streak, isopropyl alcohol, or other degreaser into the shifter, find the stuck pawls and move them back and forth till they start working properly, use an air gun to spray out the degreaser and bits of old grease, then relubricate with Tri-Flow or Dri-Slide. Gets most shifters working fine again.
There are a few models that might not be worth the time, either because the above method hasn't had a great success rate on them, like 7 speed Deore LX M560, and any of the early 90's models that have two tiny finger-like pawls right next to each other, or because they work so poorly even when they aren't gummed up, such as Acera X ST-M290 or Nexave ST-T300.
Arrowana is offline
Old 04-08-24, 06:40 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2751 Post(s)
Liked 3,408 Times in 2,063 Posts
​​​​​​https://www.harborfreight.com/25-lit...saAiesEALw_wcB
dedhed is offline
Old 04-08-24, 09:32 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4222 Post(s)
Liked 3,910 Times in 2,332 Posts
I do much the same cleaning, sometimes working the pawls with a pick to help the dissolving of the gummy grease in the pivot. Where i differ is in the lube after free pawl movement. I like oils with a swipe of grease on top after working in the thin then thick oils. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 04-09-24, 08:55 AM
SoCaled
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1132 Post(s)
Liked 3,869 Times in 1,895 Posts
Originally Posted by dedhed
@RCMoeur has had good success with the ultrasonic method, also for donor bikes, he made a post or thread about it.
SoCaled is offline
Old 04-09-24, 09:15 AM
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 554 Post(s)
Liked 1,910 Times in 859 Posts
Thanks for the tag.
My experience has been that WD-40 and Clean Streak are only temporary fixes. If you really want to get those types of shifters working again, here is the method I use for rather good success:https://www.bikeforums.net/bicycle-m...l#post23196306
RCMoeur is offline
Likes For RCMoeur:
Old 04-09-24, 11:01 AM
bboy314
bboy314's Avatar
Quoted: 354 Post(s)
Liked 815 Times in 420 Posts
All good advice above. One thing I’ll sometimes do before degreaser and lubricant is to flush the shifter with boiling water. This can work wonders for loosening up that hardened grease.
bboy314 is online now
Old 04-09-24, 11:19 AM
andrewclaus
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 678 Post(s)
Liked 749 Times in 434 Posts
Ditto all the above. Dental picks are a big help--my dentist gives me his old ones when I ask. And I'll add, definitely stay away from the gasoline!
And kudos for volunteering at the nonprofit. Keep up the great work. It's how I enjoy spending a good part of my time. Freeing up stuck shifters is a big part of the work, and the reason many of them get donated.
andrewclaus is offline
Old 04-10-24, 03:23 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 319 Post(s)
Liked 281 Times in 195 Posts
Our tried and true method is to remove the covers, saturate the mechanisms with PB Blaster, working the shifter and pawls for a few minutes. Finally follow up with a squirt or two of the 3-IN-One lightweight penetrating oil. Work the shifter again and magic. This stuff is gold for these shifters.
Available at Home Depot https://www.homedepot.com/p/3-IN-ONE...0015/300719551
JoeTBM is offline
Old 04-10-24, 03:24 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 319 Post(s)
Hello Everyone,
Thanks for what you do, welcome to the club.
JoeTBM is offline
Old 04-11-24, 06:18 AM
PromptCritical
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 95 Post(s)
Liked 46 Times in 31 Posts
Hello Everyone,
I use "Tyme" for some of my work (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). To be honest, I haven't tried it on plastic, but my hunch is that it would be okay.
Cheers, Mike
PromptCritical is online now
