ISO and for trade thread part 5
#1626
Pedalin' Erry Day
ISO down tube cable stops, the old clamp-on style. They can be Campy, Shimano, or Suntour - it does not matter. What does matter is that they are clean. I'm not looking for NOS, just gently used clean stops. Oh, it is for a Raleigh Gran Sport/Grand Sports.
I have stuff to trade or dinero.
#1627
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Quoted: 145 Post(s)
Liked 120 Times
WTB- Maillard freewheel remover
I think the correct tool is 31mm 24 spline . I believe VAR405 or bicycle research CT-3. Anyone have one they don’t need and willing to sell?
thanks! Steve
thanks! Steve
#1629
Quoted: 1324 Post(s)
Liked 927 Times
Still looking for a Suntour Cyclone bottom bracket spindle to fit a 68mm bottom bracket with a double chainset. I have the cups.
Thanks.
Thanks.
#1630
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
#1631
Quoted: 350 Post(s)
Liked 276 Times
ISO: Above average condition Deore DX long cage rear derailleur (for 7spd)
Thanks
Thanks
#1632
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
I may be able to help you out on the Deore RD. Will check tomorrow...
#1634
aka: Dr. Cannondale
Liked 3,404 Times
Yours for $40 plus shipping.
Easiest/fastest way to reach me is by e-mail at rccardr@cox.net
#1635
Liked 927 Times
#1636
Phyllo-buster
Liked 2,054 Times
#1637
Not lost wanderer.
Quoted: 885 Post(s)
Liked 994 Times
ISO; any 86mm bcd crankset and some rings, prefer 46t or 47t and 30t or 32t.
SR or Stronglight.
SR or Stronglight.
#1638
Liked 927 Times
#1639
Quoted: 1303 Post(s)
Liked 1,911 Times
Miele Man,
If you can get me specific numbers I will go through the 100 or so spindles in our co-op to find you the right one. I would like total spindle length, right side ledge to end of spindle and left side ledge to spindle end. And if you have it, the number stamped into the spindle. TIA, MH
#1640
Not lost wanderer.
Quoted: 885 Post(s)
Liked 994 Times
#1642
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
ISO or WTT Shimano SL-BS50: a six speed bar end shifter.
Have: Shimano 10s Bar End set, a ton of Tri-Color stuff, or just ask - you never know!.
Your consideration is appreciated.
Mountaindavid - in search of ever more awesome half-step drivetrains.
#1643
tantum vehi
Liked 992 Times
I should clarify that this could be either 7 speed or 6 speed with an insert. It should still have 6 clicks, but the cable pull is changed.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#1644
Not lost wanderer.
Quoted: 885 Post(s)
Liked 994 Times
#1646
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
adding some un-called-for details the SL-BS50 AND the SL-6400 DT shifters both use a little C-shaped clip that fits the cable groove in the SIS shifter which effectively increases the diameter of the "barrel" with 6-speed, and is left off for a "smaller diameter" 7-speed. It's a small part that's easy to lose but if you need one you might be able to scavenge it from an SL-6400 (probably many more of those were sold).
#1647
tantum vehi
Liked 992 Times
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#1648
Liked 1,062 Times
I'd have to try it out to remember but IIRC this clip does nothing to affect the number of clicks so I believe you have a "ghost shift" at the end of the range if you use them for 6-speed and yes it's your RD adjustment screw that prevents it from over-shifting...but I could be remembering wrong, and not the 1st time THAT happened!
#1649
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Modifies the radius, not the clicks.
#1650
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
