Wit's end on chain tension
Old 10-03-19, 12:46 PM
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Last time I had a tire hop that bad it was because of the rim tape not allowing the tire to seat properly.
seau grateau is offline
Old 10-04-19, 06:09 AM
Mikefule
Quoted: 99 Post(s)
Liked 115 Times in 78 Posts
I normally inflate the tyre to somewhere near working pressure, deflate it, then check everything is well bedded before reinflating it.
Mikefule is offline
Old 10-04-19, 04:33 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Originally Posted by bmwjoe
After looking at the video I agree with tugadude. The tire is not round, or is on the wheel wrong. Take the tire off and re-seat it on the rim. You can usually look at the marks on the tire and determine if it is seated properly. You may need a new tire.
Yep, with only a couple psi in the tire, I go around the wheel on both sides and make sure the witness line is the same height above the rim, like this:
https://janheine.wordpress.com/2012/...th-deep-wells/
If you just throw the tire on and pump, it may or may not work out well for you.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-04-19, 08:06 PM
Philasteve
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
Yeah I usually stop twice per tire and kinda rock the tire back and forth pushing it with my palms. Especially with bigger tires, I find they suck in more or whatever you want to call it when the line is going into the rim.
Philasteve is offline
Rvs4
Singlespeed & Fixed Gear
9
09-30-18 07:35 PM
drlogik
14
01-23-18 08:18 PM
sushiboy21
Bicycle Mechanics
3
09-02-12 11:10 AM
bike manhattan
8
05-27-10 01:54 AM
preston811
18
12-14-09 07:32 PM
