Anyone Use a Wahoo RPM Cadence Sensor Attached to Shoe?
Old 12-11-18, 03:15 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Anyone use a Wahoo RPM cadence sensor attached to a cycling shoe?
Will it work that way?
-Tim-
TimothyH is offline
Old 12-11-18, 03:20 PM
Sal Bandini
Bikes: 2017 Sirrus Sport
Quoted: 420 Post(s)
Liked 7 Times in 7 Posts
I do and it works fine.
EDIT: Not a cycling shoe but it will still work fine.
Sal Bandini is offline
Old 12-11-18, 03:29 PM
surak
surak's Avatar
Quoted: 878 Post(s)
Liked 726 Times in 436 Posts
I did until I got a PM that reported cadence. The sensor pod comes with a mount especially to go between a strap or laces, but it'll work pretty much anywhere that revolves with a pedal stroke. DC Rainmaker noticed that it'll work if you tuck it into a gym shoe, which I've verified on a stationary bike.
surak is offline
Old 12-11-18, 03:52 PM
TimothyH
- Soli Deo Gloria -
Cool. I'll try it.
I have an RPM sensor but my fixed gear bike has almost zero clearance between crank arm and chainstay.
I've tried every possible position for the sensor - inside the crank spider, etc. It just won't fit anywhere and mounting it to my shoe is a last resort before I go for a magnet based sensor.
-Tim-
TimothyH is offline
Old 12-11-18, 04:13 PM
unterhausen
Randomhead
Liked 3,701 Times in 2,521 Posts
I thought i would take it outside and not just on the trainer, so I figured the shoe was the best place. Have it hooked to the boa wire. It works fine there.
unterhausen is offline
Old 12-12-18, 06:48 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
I used mine in my shoe until I got an Assioma power meter for my road bike, at which point I semi-permanently mounted the sensor to the crank arm of my commuter bike. The only thing I have to swap around now is the Bolt computer itself which is an easy twist on/off. When using on the shoe laces you need to orient it forward/backward not left/right, or try DC Rainmaker's method.
zacster is offline
Old 12-12-18, 01:28 PM
TimothyH
- Soli Deo Gloria -
Thank you for this.
I can't find the little plastic doohicky which allows mounting to the shoe.
-Tim-
TimothyH is offline
Old 12-12-18, 06:40 PM
Reynolds 531
Bikes: a few that I can't recall
Quoted: 347 Post(s)
Liked 302 Times in 147 Posts
I made my own bracket out of stainless welding rod. I can switch between cyclocross shoes, spin shoes and others (just as long as I remember to)
Reynolds 531 is offline
Old 12-13-18, 11:56 AM
TimothyH
- Soli Deo Gloria -
Thanks for the photo.
Pretty good. Gives me some ideas.
TimothyH is offline
Old 12-13-18, 12:13 PM
Sal Bandini
Quoted: 420 Post(s)
https://www.wahoofitness.com/devices...-cadence-mount
Old 12-18-18, 01:08 PM
TimothyH
- Soli Deo Gloria -
It isn't working well.
Cadence readings are low, about 40% lower than they should be. Frequent dropouts as well - cadence falls to zero when I'm clearly pedaling.
Not sure what the issue is but it doesn't seem to work too well for me.
-Tim-
TimothyH is offline
Old 12-18-18, 02:21 PM
zacster
Quoted: 22 Post(s)
Two things come to mind. First, is the battery good? That is a common complaint with these. Second, did you mount it forward/back vs. side to side as I suggested? I see in the pic (not yours) that it is mounted side to side, which didn't work for me.
And what computer are you using? It could be a weak receiver too. Is it a cycling specific one? Or a phone? Connecting via Blutooth or ANT+? I find ANT+ to be much more reliable.
zacster is offline
Old 12-18-18, 02:49 PM
unterhausen
Randomhead
wahoo seems to think that wifi messes up the transmission, so that's something to think about.
Does the wahoo app report battery strength? Trainerroad does.
Old 12-18-18, 02:54 PM
TimothyH
- Soli Deo Gloria -
Wait a minute...
Um....
I even thanked you for telling me that.
Can I blame this on the mechanics at the LBS?
Tell me which way it goes one more time, just to be sure it sticks.
-Tim-
TimothyH is offline
Old 12-18-18, 03:06 PM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
-Tim-
Flaky readouts I usually fix right away with a new battery cell.
The sucky thing about shoe mounting...is that if you're a tourist or walking around camp--you're going to keep eating battery with every step
Marcus_Ti is offline
Old 12-18-18, 07:56 PM
zacster
Quoted: 22 Post(s)
The way the video's still appears is actually the wrong way, but the video does show it correctly.
zacster is offline
Likes For zacster:
Old 11-29-21, 05:45 PM
jaxgtr
jaxgtr's Avatar
Quoted: 769 Post(s)
Liked 1,748 Times in 1,017 Posts
Hey there, I just ordered these sensors as I am tired of the up and down connection of the Bontrager Duotrap, but I have boa wire and no velcro straps on my shoes, how do you hook it to your wires? Did you run some velcro around the wire? I thought about running it though my road id ankle strap as well. But looking for idea's versus reverting to an old pair of shoes.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Originally Posted by AEO
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is online now
Old 12-03-21, 08:49 AM
jaxgtr
jaxgtr's Avatar
Quoted: 769 Post(s)
Got the product and got it attached pretty simply,
Old 12-04-21, 06:20 AM
Fendertele
Fendertele's Avatar
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times in 28 Posts
I didn’t have enough clearance on the crank arm and find the shoe mount works well. Especially since I use the shoes with several bikes.
Fendertele is offline
Old 12-05-21, 10:35 AM
unterhausen
Randomhead
Sorry I didn't see your question previously. I have it so it flaps, I suppose I could have done a better job. But usually when I'm pedaling fast enough for it to flap I'm not paying attention to my shoe.
Old 12-05-21, 01:14 PM
jaxgtr
jaxgtr's Avatar
Quoted: 769 Post(s)
No problem....I got it looped on mine as such and it really secure. I also use it with several bikes....
Old 12-08-21, 02:34 PM
noglider
noglider's Avatar
Quoted: 7353 Post(s)
Liked 2,481 Times in 1,440 Posts
What a great idea! I have a XOSS sensor that has an internal accelerometer, so it should work. I'll try it!
noglider is offline
Old 06-11-23, 10:58 AM
jansell
DIY Carrier For Dual Wire BOA
I used the rubber crank arm carrier with the sensor inserted, some fine 7mm cable ties and a small hook and loop strap to get a an adaptation that suits my Specialized BOA shoes.
I passed the small cable ties through the cable holes at each the end of carrier and locked each into a small loop. If you live in the UK you can buy a pack of 6x Velcro straps in an assortment of colours for £2.50 from Wilco.
I passed the strap through the cable tie loops and then round the BOA wires so that sensor sits in the correct N-S position. The strap is doubled over and locks in place. See photo. I tried it for the first time today - it was secure with no flapping. With the hook and loop the carrier can be easily removed when I use the shoes on the turbo.
I will experiment with neater set-up, but so far everything is working well. I hope this helps anyone else left scratching their head in this predicament.
Sorry I can’t upload my photos as I haven’t left 10 posts.! 😟
jansell is offline
Old 06-11-23, 05:51 PM
Calsun
Quoted: 608 Post(s)
Liked 382 Times in 288 Posts
Works great and much easier to move from my road shoes to my mountain bike shoes than something attached to a crank arm.
Calsun is offline
Old 06-23-23, 09:04 AM
Road Fan
Road Fan's Avatar
Quoted: 1858 Post(s)
Liked 664 Times in 506 Posts
Wait a minute...
Um....
-Tim-
Mechanics? Yes, of course, I won't tell! But, what's the name of the shop, maybe I better not go there now ...
Road Fan is offline
Metaluna
7
07-07-17 07:38 AM
TimothyH
0
09-28-16 08:05 PM
Fullcount
0
07-21-16 10:07 PM
LloydXmas
13
12-16-15 10:00 AM
mattkime
Bicycle Mechanics
0
07-22-12 06:12 PM
