Rear threw axle and trainers versus road
I have a trek Domane that I ride on the road and on kicker snap . I changed the rear threw axel to be compatible with the trainer and use the same threw axle when riding outside. Am I damaging anything by doing this? Should I be switching the threw axle all the time depending where I’m riding - trainer versus road? That’s a hassle so I hope not- but don’t want to do any damage to the bike either .
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
THRU axle. No, it's fine to use the same one when riding.
Likes For cxwrench:
My trainer axle has an extended length and a nut on the right side that requires an 18mm wrench to remove. If I ride on the road, I better remove that nut in case a flat repair is needed. I'm not carrying an 18mm wrench.
Likes For DaveSSS:
Quoted: 6196 Post(s)
Liked 4,811 Times
Where did you throw the axle?
Likes For Iride01:
Quoted: 136 Post(s)
Liked 57 Times
Some trainer thru axles are not made to used off the trainer. Saris's for one, are not. Robert Axle Project's are ones that are designed to (robertaxleproject.com) I would check with the axle mfr. and confirm usage.
I had the same question back when I bought my Kickr SNAP - I asked Kickr and Trek and they both said OK to use trainer axle outside. Now a moot point - I just leave my 25 year old Trek 520 on the trainer, use the Domane outside.
