Middle cog broken tooth
Quoted: 207 Post(s)
Liked 108 Times
So I noticed a broken tooth in the middle cog of a 5 speed freewheel on my 1980 Miyata while chain lubing. It has the uniglide design I think, where the teeth are a bit twisted is all. This is a NOS freewheel I put in about two years ago and there is no other wear or issues. My question is, do I need to worry about this or can I just forget about it? I don't notice it while riding (I use that gear to get up small hills and rises or against strong headwinds).
Quoted: 1820 Post(s)
Liked 1,696 Times
How far have you ridden in those last 2 years? Have you ever changed the chain since you installed the freewheel? If the chain is worn it may slip on a new freewheel. If it wears too much it will start to wear your chainrings
Quoted: 3464 Post(s)
Liked 2,831 Times
It will shift easier.
if it was one of the two smallest cogs, seek out a replacement
Likes For alcjphil:
Liked 2,831 Times
Likes For repechage:
Quoted: 1829 Post(s)
Liked 3,376 Times
I've had a SunTour cog lose a segment BITD. This was a span of a few teeth. I was able to replace the cog, since SunTour cogs were available in shops back then.
The loss of a tooth or teeth suggests a manufacturing flaw in that cog. There's no reason that other teeth might not break off too. You might be able to continue to use this freewheel, but it would be good to have a replacement freewheel (or cog) on hand.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Thanks for the mention.
Unfortunately for the OP, I sold my home and downsized last fall, and all the spare parts for freewheels had to be put in storage for the winter. I probably won't be fully reopened until next fall and all I can do is normal cleaning and service at this time.
Depending on the specific model, I probably do have a replacement sprocket buried deep in the storage unit. However, the best I could do is help the OP see if a match can be found on ebay or Loose screws and talk them through a swap. PM me for my email address if you'd like.
Bob
Bob
Quoted: 207 Post(s)
Liked 108 Times
Thanks all, I'm sensing at this point I should not just tolerate the broken tooth and forget about it. The freewheel is a Shimano Z012 5 speed that I put in two years back when the original started acting up. It is the 20 tooth cog. I check the chain for wear at least a couple times a year, I have about 5000 miles on it and I cannot yet find any stretch in it (I'm pretty meticulous on maintenance). No trouble is noticed in any gears.
I have a modern Sunrace on hand, with the modern hyperglide teeth, seems like cheating...
