Bottom Bracket gets loose every 3 or 4 turns
Quoted: 207 Post(s)
Liked 108 Times
My 1980 Miyata 610 cranks get a little play in them every few turns. The whole BB was loose a few months back and I could not get the cranks off so I had my LBS do the work. They said it looked fine and they just cleaned and relubed, I forgot to ask but I doubt they replaced the bearings even. Is this something I need to worry about, sure seems a little odd to me.
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
Sealed or cup and cone? I had a bike with the bottom bracket coming loose and I was soooo sure the adjustable cup was tight. Turns out the fixed side was loose. Doh.
Quoted: 4512 Post(s)
Liked 6,387 Times
Set up and adjusted correctly, none of this should come loose at all.
I would not ride this until it is completely sorted out, cause, effect and remedy.
No way this would ever end up at the shop, exactly for this reason.
This is why we have cartridge BB's now, hate to think of the good cup and cone parts that have been lost this way.
I recommend attending to it pretty quickly. I couldn't have ridden even 100 miles with a BB that got a little loose. I took it into an LBS I was close to when I realized what was happening, and a mechanic adjusted it correctly while I waited, but my axle got trashed, and I'm pretty sure that was because I had ridden with a loose BB. Maybe the Japanese stuff on your Miyata is more durable than the TA axle I had, but why take a chance?
Quoted: 207 Post(s)
Liked 108 Times
Thanks, so clarifications are original cup and cone, and spindle starts to play in the cups. Just rode it 66 miles last night...
Liked 6,387 Times
I would get it apart, clean all the threads and have a good hard look at the cups and BB shell then get after it with this setup to make sure the fixed cup is tight.
This same setup will always get them off when they are stuck without damaging any parts, pieces, tools, frames or flesh, ever, period.
Likes For merziac:
Quoted: 3814 Post(s)
Liked 3,345 Times
one thing which might cause this symptom is damaged threads
simple enough to disassemble everything and check them
if damaged, chasing might be adequate to sort things
if damaged and chasing not adequate you could tap the shell out to italian
one odd thing which can cause an adjustable cup to loosen is if bottom bracket threads to do not go far enough in toward the centre of the shell
had one case of this in me workshop where the adjustable cup was butting up against the end of the threads right at the point where the bearing adjustment was correct. this caused end loading on the cup which caused it to loosen - an odd problem indeed.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Might be as easy as replacing the lock ring ... if it's the adjustable cup that is moving on you. Blue Loctite might be of some help.
Sorta a pita, but you can usually tighten the lock ring without removing the nds arm
Quoted: 823 Post(s)
Liked 1,395 Times
Are the bearings caged? I had similar problems with a Sugino BB when I put the caged bearings in facing the wrong way ...
Likes For rustystrings61:
Quoted: 207 Post(s)
Liked 108 Times
Thanks much for all the info everyone! I'm taking your advise and putting the bike in inactive status until I take it apart and look at everything you pointed me to. I'll let you know what I find!
Likes For 55murray:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I've seen quite a few cup/cone bottom brackets where poor tolerances together with perhaps a less-than-perfect bb shell conspired to cause such symptoms.
So it may be no fault of the shop who rebuilt yours. I might just tighten the adjustment myself if that can get rid of the play without causing binding.
And as was mentioned, sometimes a bearing retainer gets put in backwards, or one or more balls falls out of place during assembly. Sometimes a ball breaks in half and causes problems, so I would inspect those closely and perhaps replace them with grade25 pieces.
Quoted: 235 Post(s)
Liked 349 Times
I'm wondering if incorrect number of / wrong size / mismatched loose bearings could be the issue. It might seem tight at first, but as things start moving it goes out of adjustment.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
When you have a BB that old you have to take it apart and clean the old grease out completely because grease crystalizes over time . I've seen so many bike shops squirt a little bit of new grease in there without proper cleaning. And it works for a little while then gums up and things start to loosen. But with the amount of riding you have done with it loose there's a good chance it's shot now. Luckily BB's are not that expensive to replace and I'd just buy a new one.
Quoted: 207 Post(s)
Liked 108 Times
Yea, I have probably ridden the bike too much with this issue. It is my only decent road bike.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Suffice to say that you can't trust at least one mechanic in that shop. I'd mention it to the boss just to see what he says. A standup guy would appreciate the feedback.
Quoted: 3464 Post(s)
Liked 2,831 Times
Where would be a good place to get new parts, or good old parts? One thing I have not mentioned, is that when it came back from the shop I had to adjust both limit screws to get the shifting to work well again- it seemed that the rings moved closer enough to the frame to require this (it would jump off the large ring and would not reliably drop to my granny).
upon taking it apart, note if the spindle has a longer side of favored projection, longer is for the drive side. (asymmetrical)
A big enough change in position upon service suggests to me-
flipped spindle
(other organic problems as noted earlier)
lubricated tapers /arms - I suggest dry fit, not lacquer thinner dry, but not greased.
there are many young mechanics that just don't have the "knowledge"
What brand / model of cranks are you working with?
Likes For repechage:
Liked 6,387 Times
The rest were always like "huh, what, oh so and so is the old bike guy" some of them were none to thrilled about it and some pointed me to a guy that was all of maybe 30 and far from enthusiastic so most were not a place I would recommend.
At this juncture we are too far down the line with threadless, cartridge, throwaway cookie cutter, profit at all costs crap to trust anybody else with our stuff, if we want it done right, we need to do it ourselves.
Most of this is not that hard, until it is and when a shop gets stuck, they are often quick to "upsell" you to the modern corner cutting cartridge or whatever "the old one was worn out, just old, too fussy, etc." , in other words they couldn't figure it out, may have screwed it up so here you are, not original anymore, old parts scrapped, SOL.
Phyllo-buster
Liked 2,055 Times
Likes For clubman:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Interesting -- I have never had an English or Swiss (left-threaded) fixed cup come loose, because they self-tighten as you ride. In contrast, I have had to resort to Loctite and heavy torque to keep some French and Italian fixed cups fixed, because they self-loosen as you ride.
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
Phyllo-buster
Liked 2,055 Times
Disraeli Gears
I will second that emotion: count the bearing balls on each side, and measure their size -- when I first read this thread, that's the thought that occurred to me, but it's such a stupid error that I was embarrassed to bring it up. However, if bike shop maintenance was involved, there's no end of reasons why you may have gotten the know-nothing, who failed counting and "some of these balls are not like the others" in grade school, wrenching while doing a Lothario on his phone.
Quoted: 207 Post(s)
Liked 108 Times
Well, everybody was pretty much spot on about this! Components pretty much trashed, the worst being the fixed side cup. That cup was not completely loose, but it was not as tight as it should have been it came loose with very little effort. Sure enough, the spindle had been reversed by the LBS, with the short side on the rings. It had caged 9 count bearings, properly installed, with some just falling out of the cages upon disassembly. Good news it the cranks are OK, the BB shell is good with all threads in fine shape.
Debating about trying to stay vintage or just get a cartridge, standard English size and threads, seems to be 124.5mm spindle. I don't think I need to worry about the offset on the spindle since the bike seemed to run just fine with the thing reversed!
