What's up with sticking V-brakes?
My usual disclaimer: I have mostly worked on vintage, so centerpulls, and sidepulls, with centerpulls being by far the majority. And I don't have problems with centerpulls. Only once in many dozens of bikes, with a bent arm, fixed (and thankfully not broken) with a cresent wrench.
However, the majority of V-brakes I've come across stick, or in other words, one side or the other doesn't retrack. This is so common, I expect it. Even after changing cable and housing (my preferred first step), I sometimes have problems with brakes not retracting, hence rubbing the rims. Usually it's one side only, and iirc, usually the cable guide side, although yesterday, the cable clamp side. Sometimes the adjustment screws works, sometimes not. I finally fixed yesterday's by changing the boss hole that the spring inserts into. But once I did that the other side was rubbing until I changed that insertion point also. I have no illusions that this is correct wrenching, and I consider it brute-force, but it has worked three times now. After I did both sides, and trued the wheel (it was already pretty close), I managed to get everything well dialed in before a buyer showed up for the bike. I (think I) understand that the adjustment screw has a similar effect to moving the insertion point. Indeed, yesterday I realized moving the insertion point takes the adjustment screw completely out of the picture.
I think I understand v-brakes in general, but recently sat through a youtube video anyway. But that did not help me diagnose this reoccuring problem.
While I'm at it, I was going to buy more cable guides because a lot of these bikes I see have rusted ones (nothing like putting a new cable housing into a corroded old noodle). I saw some ads showing the guides sold in pairs, 90 and 110 degrees. Never having noticed, I assumed they were all 90's. When would I use 110's?
Quoted: 4211 Post(s)
Liked 3,880 Times
First thing I would check is the pads condition. If a pad has a lot of wear and has developed a lip along it's lower edge this can act as a hook and snag on the rim's edge. More an issue when on the repair stand that in riding as the rim's motion will reduce the snagging lip's ability to hang up on the rim. Next up is that V brakes have a third spring effecting the arm movement and pad centering, the cable casing. Very few wrenches I know of pay attention to this aspect. Then there's the trend to weaker return springs on V brakes, compared to other and older brakes. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
In addition to the above, some bikes get abused enough to have bent caliper springs. Unhook both springs and see if they're symmetrical. Also check for extra friction in each caliper as it rotates on its post without the spring. The springs are easily bent roughly by hand, then final adjustments can be made with the screws at the base of the calipers.
110 noodles can be helpful at the rear brake where a frame stop is welded to the top of the seat post, and there's a short piece of housing to the noodle, especially on smaller frames.
Quoted: 514 Post(s)
Liked 451 Times
Also, many of these anchor the return spring in a plastic collar that often breaks, so you have a pad that won't return on once side.
Thx everyone.
In my recent case, the pads were good. I check for that in general, but have not seen that hook effect from worn pads before. Another thing to add to my list. I've collected many sticky brake tips over the years. Here's a couple of fun ones: the pivot bolts of center-pulls, the pivot pins of brake levers.
I usually replace the cable and housing when I have this problem, and anytime they look old and worn in general, even without symptoms. And I lube the cable with Tri-Flow. But, I've often asked myself if the lube is necessary in lined housings. Opinions?
I will check all these suggestions the next sticking V-brake I encounter.
Likes For dsbrantjr:
Quoted: 194 Post(s)
Liked 204 Times
I usually end up taking mechanical brakes apart if they have seen some use or been left standing, especially at the cheaper end of the market as they usually spend a lot of time outside and see little good maintenance. My most common issues are frayed cable ends and poorly routed/length housing. Any brake that has been used for some with such cable/housing issues will probably have other issues as a result that make it difficult to correct through adjustment.
110 noodles might be handy if you have a folder with a downpull side caliper at the rear, because the cable has a large angle to turn through and must squeeze between the chain and frame.
Randomhead
Liked 3,700 Times
I have had this problem and the usual solution is to put Shimano brakes on the bike. I messed around with the Tektro front brake on my daughter's bike for the longest time, and there was no way to get it to work right.
Likes For unterhausen:
Quoted: 581 Post(s)
Liked 921 Times
A few things can lead to stubborn unbalanced brakes:
1. Make sure the wheel is in the dropouts straight. This catches even experienced techs off guard. A crooked wheel will make all your brake adjustments unbelievably difficult, and it will all be for naught the next time you remove or straighten the wheel. I have a front wheel with a slightly bent axle and this results in me having to recentre the brakes every time I remove the wheel
2. Rust or other impediment to the brake moving on the pivot. Often one side of the bike is stored in such a way that one side is more effected by the elements so one brake post is rusty and this reduces the ability of that side's spring to pull it out. Removal of the brake arm and sanding off the rust is the solution to this
3. I don't know why, but cheap brakes (like the ones on dept store bikes) are muc hmore difficult to get and keep the brakes adjusted. It seems like such a simple mechanism, but I guess you get what you pay for. My experience with Shimano or Tektro or Avid direct pull brakes has been almost universally positive, while the least expensive brakes are almost universally a pain.
4. Make sure the levers are compatible with V brakes. Using 'short pull' brakes as were specced on old (pre-mid-nineties) bikes, or on most road bikes, and sometimes on inexpensive dept store bikes that were supposed to have long pull levers, result in extremely small clearance between rim and brake pad, and very difficult or impossible adjustment to keep the brakes from rubbing.
Likes For ClydeClydeson:
Quoted: 581 Post(s)
Liked 921 Times
I am not generally a proponent of replacing parts as a fix when the root of the problem is not well known, but Shimano parts work better and are generally easier to adjust than any of their competitors.
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
If the adjustment screw isn't enough, back the screw out a bit and bend the spring outward a little. This always works.
I'm going to piggyback the comments of Shimano and Avid brakes being great. Every time I've had to set initial adjustment, it's been easy and then rarely need to make any further adjustments afterwards, maybe occasionally tweak the screws just a touch. Quality parts typically give quality results
As mentioned, the cheap stuff really sucks. Just yesterday I was adjusting the dirty old v-brakes on a friend's extremely low end bike. Every time I removed the front wheel and reinstalled it, the adjustment on the brakes would change. One side would stick, then the other. Came down to low quality and dirty parts.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
Stuart Black
Stuart Black
Quoted: 1612 Post(s)
Liked 2,594 Times
I do have an NOS Surly Long Haul Trucker frame though which will get all the expensive goodies, one of which being the Paul Motolites or Touring Cantilever.
Hahaha, the first time this happened was on a Walmart bike, and every time I’ve dealt with it since the brakes have been at best, Tektro, or worse, no visible brand. I’m not sure I’ve ever even seen Shimano V-brakes, but I will look for some. I do have one decent mtn bike circa early 2000’s. Shimano everything but the brakes are Dia-compe. This does explain though why someone gave me a box of no-name V-brakes. He had probably been replacing them with something decent.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
One other thing to check is if the brake track on the rim has a wear indicator utilizing a groove in the track, the pad can wear with a raised groove that will mate with the recessed groove in the rim track, and will not release cleanly when the pad is pushed up against the rim.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
They’re never really balanced because one side is attached to the frame by housing and the other isn’t. Ideally the housing isn’t a factor but really it’s firmed up in compression. If you really crank up the springs, it can help, but then the lever effort gets bigger.
I’ve also had trouble with the hole in the arm being just barely too long for the post so it drags when cinched.
I think the main reason for the adoption of v brakes was that they allowed the brake to go on the moving part of the suspension fork or swing arm. Hydraulic disc brakes are so much better at that it isn’t even fair. It’s no wonder their heyday was brief. They survived a long time on cheap bikes though because they were just a little better than cantilevers
Quoted: 581 Post(s)
Liked 921 Times
Oh I would love to have Paul brakes on all my mountain bikes. However, those are quite pricey and when used Shimano/Avid brakes practically grow on trees, it leads me to pick the low hanging fruit.
Quoted: 581 Post(s)
Liked 921 Times
Plus Vs are much easier to set up than cantilevers, especially the ones with 'smooth post' brake pads as were common in the mid nineties when Vs came out.
Shimano actually made V brakes for use with smooth post pads for a short time (STX?) and they were a pain.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I think some have had problems with the Paul brakes, at least the Minimotos:
Paul Minimoto brake squawk: any solutions? - Bike Forums
I've been fortunate to have had a lot of good service from Tektro linear pulls. I've had one set of Avid Single Digits, but every other bike I've had with linear pulls have had Tektro brakes. I don't think I've ever had a Shimano linear pull, though understand they're also good. Important with any brake (for stopping performance at least) is a good brake pad compound.
Quoted: 207 Post(s)
Liked 108 Times
When you replace the cables and liners for V brakes you have to replace the noodles as well. They really get bad on the inside. They are only like 6 dollars a pair or something, and come with new rubber boots as well.
