Electronic Shifting - What's the Point?
#326
There is a reason the car retailed for more than $200k. I dumped another $40k in upgrades. Car was special.
#327
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Especially given the fact that I swapped out the small stock turbos for some big GT30's. They call the car "The Widowmaker" for a reason. I would hit 140 on the big straight at Texas World Speedway but the turbos hit way too hard for most tracks. At 190 mph with the rear engine the front end became very flighty. In stock form the GT2 made a little under 400 rwhp. Mine made double that, all on stock internals. That is because the Metzger motor was a racing engine mass produced for the public.
Likes For GlennR:
#328
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
https://www.artstation.com/artwork/dOJ4W1
Originally Posted by artist
A weird blend of concentric unicycle Kris Holm hub and Rohloff speed hub with what would be huge bearings. Is this even possible ? I don't know. The Effigear cranks are borrowed from my previous bikes, and shortened[
As for electronic shifting, I think it has its place - particularly on road bikes and e-bikes. I personally would like hydraulic shifters for my use and bike.
#329
pan y agua
Quoted: 1443 Post(s)
Liked 713 Times
You could get lost and die.
You could hit a tree and die.
#330
Also a reason you can buy one now for 60k, while other Porsche GT cars are dramatically appreciating. Thought briefly of buying one because as Porsche GT cars go it’s a bargain, but my mechanic, with Porsche racing experience warned me off, and the literature confirmed his opinion.
That motor continued to run strong, and even today is still running great.
#331
Quoted: 356 Post(s)
Liked 323 Times
Porsche cars.
Do we need a Doppelkuppling on our bicycles soon?
Likes For CargoDane:
#332
You would not have to back off the wattage while shifting, you could just power/grind right through with no loss in speed or momentum. It would give you a massive advantage.
For people unfamiliar with the technology, Doppelkuppling (PDK) functions with dual clutches. While one clutch disengages, the other one engages. With a car traditional clutches require you to back off the gas while disengaging from one gear and re-engaging with the next gear. The car looses a tremendous amount of power (temporarily) and momentum. The PDK does not. That is why cars with 500 hp and PDK actually accelerate faster than a traditional 6 speed clutch on a 600 hp car.
Lets apply this to bikes: You have to back off your peddle force every time you shift. Imagine not having to do so, instead powering through your peddle stroke with 100% force while simultaneously changing gears.
Now THAT would be pretty freakin' cool.
Likes For RadDog:
#333
Quoted: 356 Post(s)
Liked 323 Times
Edit: I can't imagine how it would work with chain and derailleurs - two chains and two cassettes/chain rings or something - one on each side?
#334
Quoted: 3943 Post(s)
Liked 7,286 Times
You can already do that.
#335
Quoted: 356 Post(s)
Liked 323 Times
Without breaking something? Which "transmission" (yeah, let's call it that, ha, ha) does that?
My Rohloff doesn't - although it only takes very little letting up to change gears. It's still not something I want to do while putting out max. Can you do that with a modern derailleur bike without fear of breaking something?
I am genuinely asking - not trying to start something.
#336
#337
pan y agua
Liked 713 Times
You need a new mechanic. Yes, the 993's are a fortune, but primarily because so few were made. The 996 GT2 was a very special car. No nannies, just a pure drivers car. The Metzger motor was one of the greatest engines ever made. It is the product of racing. They then took the racing motor and mass produced it. My car, a little 6 banger, made 800 rwhp on stock internals. That is more than 200 hp per liter. And I beat the piss out of it. Tracked it many times, ran a low 10 second quarter and trapped 137, and of course money raced it.
And FWIW, my mechanic, tuner, has a long successful history racing Porsches.
#338
Liked 7,286 Times
Anyone missing a sock?
#339
Quoted: 20808 Post(s)
Liked 9,450 Times
Likes For WhyFi:
#340
Quoted: 645 Post(s)
Liked 797 Times
However, not sure about having to ease off when shifting on the bike. I do this under a few specific circumstances, namely dropping from large to small chainring (if the chain is under too much tension, it can defeat the relatively weedy spring of the FD), and when shifting to a larger sprocket when climbing out of the saddle (I unweight the pedals momentarily by leaning forward onto the bars just as the chain shifts). Otherwise, I’m not aware of any easing off when shifting either up or down.
#341
Liked 7,286 Times
Likes For tomato coupe:
