Intermittent clicking noise from Crank/Peddles
Hi, I'm sure I'm going to get my terminology mixed up but will try to explain the problem as best I can. While cycling I can hear a clicking noise, it sounds similar to a derailleur trying to shift or being misaligned. I can only hear it when I peddle so assume it's coming from the front. If I stop and spin the bike by hand, or flip it upside down there is no noise. I can only hear it while I'm on the bike riding, meaning I can't see where exactly the noise is coming from. The front derailleur isn't rubbing, as I've tried shifting front and rear gears and the noise persists. It's a 10 speed Raleigh Supersport which I bought from ebay as a commuter bike, so not particularly valuable or in amazing condition. I've had the bottom bracket replaced (6 months ago) but the problem is more recent. Any ideas or recommendations would be hugely appreciated, as I'm broke and can't afford a new bike.
Thanks
David
Thanks
David
Bikes: 1990 Diamondback Master TG, 2015 All City macho man disc, 2015 Trek X-caliber 7, 1989 concorde pdm team edition
OR FD cable tail being just long enough to hit crank or wheel
Quoted: 1438 Post(s)
Liked 1,092 Times
Do the easy, cheap things first. Remove pedals, clean and lube the pedal and crank threads and reassemble, tightening firmly. Try borrowing some known-quiet pedals and swapping them in. Check your quick release skewers or axle nuts for tightness. Have a friend cycle alongside and listen to see if they can localize the noise. Make certain that your derailleurs are correctly adjusted. Stand out of the seat and pedal to eliminate seat and seatpost noise.
Arsenal FC
Bikes: Cube Peloton, Cube MTB 29r
new BB's loosen over time, probably just needs to be tightened up and let it settle.
BradMitch
Bicycle Mechanics
5
06-18-14 08:00 PM
wngo17
Bicycle Mechanics
11
11-20-12 02:24 PM
