Heartrate/Effort Question
#51
Quoted: 82 Post(s)
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
What about HR in that case?
#53
Quoted: 1186 Post(s)
Liked 289 Times
Not when you have to go uphill. Heavier, stronger (than you need) muscles are just dead weight. Power/Weight ratio is key and, for a fit cyclist, increasing muscle mass will lower power/weight radio for any time period longer than 30 Seconds or so.
#54
Quoted: 1975 Post(s)
Liked 232 Times
no. Wiggins actually cut a ton of weight and his legs got smaller to be able to win the TdF. Why would you ignore other adaptions when they are the major component of power on the bike?
#56
Bikes: Cannon dale t700 touring bike
Quoted: 43 Post(s)
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
That's on the flat. But yes, I'm quite fit at least in summer. I also weigh 142-145 and have a fairly aero position. I also have a nice road bike with nice but inexpensive home built wheels and good tires.
Results matter
Results matter
#58
Quoted: 1027 Post(s)
Liked 325 Times
Great! I have a question. Faster = bigger leg muscles. More or less. Every picture shows that. OK. Lets not discuss when it is not true (greater efficiency, more nerves, etc.) . In many cases it is so.
Then... Muscles work on blood. For the same work muscle will use the same amount of blood. So there will be the same heart rate after muscle becomes bigger, than before training...
What's wrong with this picture?
I suspect (but don't know for sure) that overall rider weight also matters. Someone with a lot of body fat would likely benefit from larger (or more specifically stronger) muscles than someone who is quite light. The reason I suspect this is that, as others have said, strength only matters up to a certain point. I suspect that for someone who is heavier (and thus has to push harder going up a hill) that point would be higher than for a lighter rider.
#59
Liked 1,938 Times
Huh. If that's the reason for your questions on leg size, i.e. that your legs are the size of your hands, then absolutely you'd be faster with bigger legs. When I'm fit, I have 21" thighs (full contraction), the same size as Arnold's arms. Those are not big legs, but they were plenty to move my 160 lbs. up hill quite fast, even better now that I'm down to 145 lbs., same leg size. However they are much bigger than my hands.
Results matter
Results matter
#60
Quoted: 82 Post(s)
My question was about HR and leg muscle mass. If that muscle mass will grow what will be with the heart rate for the same work? I do not see why it will go down unless the heart will grow too.
