Specialized dropping women road specific designs
#51
Quoted: 18410 Post(s)
Liked 15,530 Times
Originally Posted by philbob57;20893218[b
]The all flat-black 'men's' bikes are as ugly as sin, IMO. [/b]With my relatively long torso and short legs, WSD bikes aren't for me, but the colors are. Don't forget, at one point the charcoal gray suit with pink shirt was one of the most admired looks for men.
And as for colors, when I had my custom ti frame built I wanted a Cerakote ceramic finish. My first choice was pink. Thought is would look great with the red Chris King hubs on the wheelset being moved over from my existing road bike. I was planning on matching that with a red headset and post collar. Unfortunately, the applicator couldn't quite get the shade correct. (Cerakote colors are normally a boring, matte finish, but if you mix them with gloss white you get a pearl finish.) Came out looking too much like bubble gum. So I went with what we call a sea foam green.
#52
Quoted: 1856 Post(s)
Liked 664 Times
I listened to the first one, and really it was a particularly excellent conversation. I'm not binging, but listening slowly. What did you think of her talk with Ian Jackson about breathing?
For anyone interested, they're available here or on iTunes.
#53
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
@Road Fan, that's them. They were all posted to iTunes on 6/20/2018.
#54
Quoted: 3450 Post(s)
Liked 420 Times
Most womens specific frame designs were just a marketing scam anyway so I'm not sad to see them go.
Until they get them right anyway.
The main premise of "WSD", for better or worse is that Women are more likely to have a longer leg to torso ration than men are which isn't always true to be honest.
Still, lets say that's what they were designing it for so did they get it right?
No, they failed miserably and they probably knew they failed but continued for "Marketing" reasons.
When designing a frame for best fit you need to consider behind the BB (bottom bracket) and in front of the BB separately. You specify behind the BB for the legs and in front of the BB for arms/reach.
A true WSD for a long legged / short torso woman would have the same seat tube angle that a man need but then the front/centre distance needs to be pulled in which would lead to the front wheel being closer to the BB and a relatively tall head tube. At a certain point of course you will need a smaller front wheel to allow the reach to come closer.
That's what's truly needed but not what bike manufacturers do. What they do instead is give "WSD" designs a steeper seat tube angle which moves the rider forwards towards the bars. The top tube length is now shorter on a spec sheet which seems right yet it just places more weight on the riders hands/shoulders.
Its just a quick and dirty fudge. I'm happy to see it die.
If they get it right though, that's a different matter.
#55
Liked 664 Times
By now, the big companies have been able to observe, analyze, and copy the thinking of Ms. Terry for nearly 35 years, and to test their own adaptations of "the woman's road bike" in the marketplace and the race track, if still relevant. For a woman whose skeletal proportions and weight distribution are similar to those of a particular man, I have no doubt their frame design solutions should be similar if their intended riding styles are also similar.
But Terry also introduced more features: narrow, low-reach, shallow-drop handlebars that reduce the required hand size, with brake levers suited to smaller hands (pre-brifter/pre-Ergopower), saddles (such as Fly and Butterfly) that are intended to enhance anatomical comfort. Clearly slotted saddles (to look only at the coarse nature of the feature) are not ubiquitous for both genders, as are sitbone supports combined with reductions of pressure in the areas forward of the bony contacts. Perhaps it's just that the science of saddle design (Joshua Cohen and others) has moved forward in the same time frame, even Brooks has applied the research, and innovative leathersmiths (Rivet and Selle AnAtomica) are growing into their own games.
Terry had a special new handlebar, selected (or commissioned?) from 3T with bend that suited and a cutout behind the hook, and a tall brazed stem with a short extension, both used on Mrs. Road Fan's 1997 Georgena Terry Classic. Now the "compact" bar style accomplishes the same thing, and the saddle-bar drop can be managed with taller head tubes and threadless stems.
So I think there was a lot of valid innovation in conceiving women's bikes, and a lot of opportunity has been taken to apply some of these innovations to the whole cycling market. While there is probably still a reasonable need to use staggered wheel sizes, I would not call "the woman's bike" just marketing, nor would I call the withdrawal of WSD bikes a mistake, in the mainstream. But if it's left to the LBS to fit the female cyclists, are they adequately skilled? In the component and frame space, the tools are there.
And guys, pink is the color for the winner of the Giro d'Italia (arr arr arr)!
#56
Liked 420 Times
I have to say, I'm not that familiar with what Trek and Specialized did to make a WSD product that is actually different from the general road product line. What you outline as truly needed is what is done by Georgena Terry, and she started doing them back when horizontal top tubes were de rigour. !
I can read the geometry and to a "T" they all just steepened the seat tube angle to make the top tube spec shorter on a spec sheet and left it basically at that. Maybe some narrower handlebars and a different seat but that was about it.
In truth you can only build a bike with 700c wheels down to a 52/54cm frame. Any smaller than that and you are into some serious geometry bodging. Bellow 52cm you need 650c wheels or even 24" wheels to get the geometry right.
#57
Quoted: 185 Post(s)
Liked 36 Times
Wsd
I was only commenting on the big companies WSD designs and not on Terry bikes.
I'd never had a WSD specific bike before. All of my other bikes, AC Spacehorse, Diverge, etc have 42cm bars, and I've swapped out saddles on everything I've ever bought, but have to say, they all ended fitting me very similarly, though the Ruby is probably the most comfortable of all. I hope the end of wsd bikes doesn't mean that I'll only have choices of various takes on "black" for color.......
#58
Liked 420 Times
I'm waiting for the day when small size bikes have decent geometry for men or women. Current/previous "WSD" designs are just something that needs to die before this can happen.
I used to be very pessimistic about this happening. Currently though I'm seeing some hopeful improvements. There are some current juvenile bike designs from Giant and Specialised that have made some HUGE improvements to the point that I can now ride an off the shelf bike with only some minor adjustments.
I bought one of these recently,
https://www.giant-bicycles.com/au/arx-24
A 24" wheel juvenile bike. Its a HUGE improvement geometry wise for short people over what came before it.
#59
So Is Merida, who owns a fat share of Specialsed a brand they supply with product going to continue?
Trek has a WSD geometry model in many lines..
more than 1 source .. Shoppers..
#60
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
There is as much variation between individuals within a gender as there is between the genders as a whole, and that two individuals of a particular height and weight are likely to need a similar fit regardless of gender. That is to say, they are selling bikes to individuals, not to genders. "Women" don't buy bikes as a group, they buy them as individuals.
Consider socks. Outside or fashion or cultural preferences, there's no reason a man and a woman who both have, say, a size 42 foot can't wear the same socks.
I think Specialized's logic makes sense. Sell frames for people of a given size, and leave the gender specific fitting to things like saddles, bibs, or other areas where gender plays a bigger role than simple size.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
#61
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
My only question is whether this means they're going to stop selling smaller size bikes or that they're just going to produce the same range of sizes and just not "gender label" them. If there really aren't statistically significant differences between the average proportions for the two sexes, then it's just the same problem for both sexes buying bike--finding the combination of sizes and proportions that fit you individually. Since virtually no one is "average" in both of these dimensions, that's the same as it ever was. Sex, then, enters into it only as styling and naming preferences.
I would think that not gender-specifying should actually allow Specialized to be able to market its smaller bikes more efficiently. If you divide up the already small segment of the market at the left end of the size curve into two parts, you're increasing your production costs per bike--in theory, lumping all the small riders together should allow Specialized to produce the smaller size at lower cost than is currently the case.
#62
Quoted: 672 Post(s)
Liked 417 Times
My only question is whether this means they're going to stop selling smaller size bikes or that they're just going to produce the same range of sizes and just not "gender label" them. ...
#63
Jet Jockey
Unless you’re talking about the geometry challenges inherent in very small frames, the whole “women specific” thing was always marketing. They do up charge nicely for it though, don’t they?
Most of the women I know who ride just ride bikes. Like most of us, they choose saddles, stem length, and bar width for their unique morphology. But they’re riding “men’s” bikes I suppose.
Likes For Banzai:
#64
Georgina Terry got The Segment going , now She seema focused on selling what you wear ,
to look good, riding , rather than selling bikes.
#65
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Seems fair to me.
In many cases, the main differences seem to be the stock saddle, color, size availability, and sometimes, handlebar width. IMO stock saddles are usually gross and handlebars are easy enough to replace. For Trek's Emonda and Domane lines, these are in fact the only differences: the frame geometry, by size, is identical.
Maybe this is a backwards move for Specialized, but I doubt it. Turns out that a lot of female road cyclists - particularly those expecting to drop $2K+ on a bike - are athletes like anyone else, and really do not want/need something that looks girly. Entry level and comfort bikes are a different story entirely.
#66
Tragically Ignorant
Liked 9,098 Times
Seems fair to me.
#67
This much is true. Took a while for Specialized and maybe others to realize that.
It was a marketing move at best that didn't pan out in the end.
I always loved Specialized's Womans Specific Design...Ha!!!! Pure marketing fluff right there.
Closest thing to a woman targeted bike should be the color. Lot of women I know like pink, purple and baby blue colored bikes. 3 colors of bike I will not buy.
Counterpoint: black goes with everything.
#68
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
Seems fair to me.
#69
Tragically Ignorant
Liked 9,098 Times
But my bike is so pretty! Then again, I don't think the silver/pink paint scheme would necessarily be a turnoff for all men. I've had plenty of compliments on it out on the road - and none from women. And I didn't have to sacrifice on quality. The Ruby Sport and Roubaix Sport had exactly the same components. And the list price was the same for both. I got a deal on the Ruby because they needed to clear inventory and they don't have a lot of people looking for 56 cm women's specific carbon fiber bikes.
It sounds to me like your bike would probably be a perfect fit for me, but I wouldn't have bothered to look at it because I would just assume there weren't any 56 cm bikes in the women's section. I really couldn't care less about the color. So basically, they probably cut off half or more of the potential buyers of that bike because they stuck it into a section where most men just wouldn't bother to look.
I do love that you got such a good deal off of a change in their marketing strategy.
#70
so nobody actually in the company or a shop employee writing here just consumers in the bleachers , watching..
#71
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
That might be the main downside to eliminating women-specific bikes: fewer good deals on WSD bikes in sizes that are usually found in both men's and women's varieties (I'm thinking 50-56cm or so). FWIW, my road bike is pink. I'm definitely not a pink person, but the bike is pretty rad, so I roll with it.
#72
M.
#75
They've probably been losing money, a lot of money, for a long time now. I'm sure they stuck with the line for as long as they possibly could, and then some.
It's like the wnba: it's been losing tens of millions of dollars since it's inception. It's not a business, it's a social justice campaign. It's pathetic because the women players claim they are "underpaid" even though the league has never, ever turned a profit!
The BOTW women's tennis tournament just shut down operations at Stanford University recently. My understanding is that the tournament lost money just about every year as well.
How much money is being wasted promoting women's cycling? I would lay a bet that every single bicycle company is losing money on women's specific designs.
Women spend money on yoga pants, shoes, makeup, stuff like that. Bicycles, not so much.
