Suggestions needed for Handelbars and seats
Bikes: Tandemania Milano
May I please have your suggestions? I have a Tandemania Milano (pictured in Tandem Switch Parts in my Profile). We would like to have the handlebars, brake handles and shifters switched to something a bit more standard (as pictured in my profile) ...the handlebars made a bit higher, which would necessitate changing the shifting controls...a more comfortable passenger seat.
Thank you for your time.
Robert
Robert
New here ? Hi..
you got nothing in there with only the 1sr post
thousands of which saddle threads generally you have to sit on the saddle not someone's opinion
its your hips not mine sitting on the saddle
I would go to a bike shop see what saddles they have, and sit on them..
bars hold them in your hands .. stoker might like a suspension seat post..
since they cannot see the bumps ahead.. to get off the saddle in anticipation..
I could not see any pictures of your bike, however, if you are looking for traditional road bike drop bars, I prefer wide (46cm) compact bars. I was having a challenge finding compact bars in that width and ended up buying a set of FSA gravel bars. The drops are flared out to sides more than standard bars. They gave me the width in a compact format and they are very comfortable to me.
My stoker prefers flat bars so I put on a straight MTB bar for her.
As the first responder stated, you can’t rely on seat opinions, However, you will have a far greater chance of success if you get measured for a saddle and buy one in the width that matches your measurement. A good bike shop will have one of the seat measuring systems and will work with you via try and swap to find the right saddle for each of you.
Quoted: 2494 Post(s)
Liked 738 Times
Robert
Robert
Quoted: 303 Post(s)
Liked 136 Times
Stoker bars like these: https://www.competitivecyclist.com/profile-design-t2-wing-base-bar?skid=PRD0021-BK-S44CM&CMP_SKU=PRD0021&MER=0406&CSPID=0914&mr:trackingCode=D5147E89-C9E3-E211-B197-001B21BCB944&mr:referralID=NA&mr:device=c&mr:adType=plaonline&mr:ad=185088406963&mr:keyword=&mr:matc h=&mr:tid=pla-383868731175&mrloc=9012562&mr:iloc=&mr:store=&mr:filter=383868731175&CMP_ID=PLA_GOc014&CSPID=0914& utm_source=Google&utm_medium=PLA&k_clickid=_k_EAIaIQobChMIzMfjl_Lr4QIV4v_jBx1zMwcTEAQYASABEgK1PPD_Bw E_k_&gclid=EAIaIQobChMIzMfjl_Lr4QIV4v_jBx1zMwcTEAQYASABEgK1PPD_BwE
were very comfy in my years as a stoker. They give you the flat part and the outer grips as options. I now have flattened areas on all
my bars now. Stoker 'may' need a set forward seat post (ie a set back seat post that has saddle rail grippers that allow the post to be rotated
180° so as to move the seat forward ~3cm.) Thomson is one such, not all set back posts can be used in the 180° rotated position due to rail
gripper design. The pilot position may need a more upright stem and flattened bars in the pilot position are no less nice than for the stoker.
Here is a dirt cheap, probably Chinese drop variant flattened pilot handlebar: https://www.amazon.com/UPANBIKE-Handlebar-Aluminum-31-8mm420mm-Horns/dp/B07CSK3P9N/ref=asc_df_B07CSK3P9N/?tag=hyprod-20&linkCode=df0&hvadid=241987970787&hvpos=1o2&hvnetw=g&hvrand=9206424015380701822&hvpone=&hvptwo=&hv qmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012562&hvtargid=pla-466271890236&psc=1
Saddles: wow really hard problem, I have used saddles that were fine for 30 miles and bad at 50miles. While adjusting to the stoker
position I went through 6-8 saddles courtesy our local dealer but we still found that standing up and coasting for 50-200 yds was needed
to reduce saddle discomfort even with comfy saddles every 5-10 miles on 50 mile rides.
Stokers can't wiggle around like you can on a singleton. Shorts made a difference
as well and the $40-60 Performance shorts that were fine on the singleton at any distance upto 100miles were inadequate on the tandem.
I moved upto Pearl Izumi in the $100-120 range to find 'tandem rated' (by me) shorts.
