Is it possible to swap road bike tires with gravel/cyclocross ones and vice versa?
Old 06-01-19, 02:49 PM
seru6119
I don't think I'll get the information I want here. Mod please close the thread. Thanks.
seru6119 is offline
Old 06-01-19, 02:56 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Yes, you can put road tires a gravel bike.
Also: “fetus position” ???
caloso is offline
Old 06-03-19, 07:27 AM
medic75
medic75's Avatar
Bikes: '19 Trek Stache 5, '17 DB Hannjo Trail, '09 Scott CR1 Pro, Schwinn Central commuter, '16 DB El Oso
Quoted: 108 Post(s)
Liked 57 Times in 29 Posts
It's all about clearance. If it fits, you can use them. I doubt you would get gravel tires on most road bikes due to clearance, but cyclocross tires are a real possibility. The other way around - you can get really wide slicks on a gravel bike.
medic75 is offline
Old 06-04-19, 04:04 PM
caloso
caloso's Avatar
Huh. I literally answered the question.
caloso is offline
Likes For caloso:
Old 06-05-19, 05:06 AM
medic75
medic75's Avatar
Quoted: 108 Post(s)
I wonder what information he wanted that we were unable to provide.
medic75 is offline
Old 06-05-19, 05:24 AM
acidfast7
Bikes: 2010 Cube Acid / 2013 Mango FGSS
Quoted: 1053 Post(s)
Liked 41 Times in 36 Posts
I think you mean foetus?
acidfast7 is offline
Old 06-05-19, 10:12 AM
Wrokkar
I just did this.
I recently got a new Trek Checkpoint for commuting, and other types of rides.
I swapped out the 700x40 gravel tires for 700x32 Gatorskins. Only did this as the weather has changed and the roads are better. Will swap back when the the weather turns back or if I do real gravel or lite touring.
Wrokkar is offline
Old 06-05-19, 12:55 PM
RidingMatthew
Let's Ride!
RidingMatthew's Avatar
Quoted: 327 Post(s)
Liked 37 Times in 24 Posts
yes
i used gatorskin tires on my cyclocross bike and would swap to cyclocross for rail trail riding for a touch wider tire. it all really depends on the frame.
RidingMatthew is offline
Old 06-05-19, 01:08 PM
daoswald
Quoted: 212 Post(s)
Liked 83 Times in 54 Posts
The constraints to consider are:
  • Will the tires fit the frame clearances?
  • Will the tires fit the rim width?
  • Will the tires fit the rim circumference?
  • Will the tires work with the rim type (tube clinchers, tubeless, etc.)
  • Will the tires work for the type of riding you intend to do.
Road tires are quite often narrower than CX tires, so frame clearances should not be a problem.
There is a lot of latitude in what tire widths will fit what rim widths. There are recommendation charts, but suffice it to say your CX rims will probably be fine with anything but the narrowest of road tires.
700c tires are all the same bead circumference (give or take a couple millimeters). So you're ok here.
If your rims require tubes, there are tube tires for road bikes that will work. If they require tubeless, there are road tires that will meet that requirement as well.
If you intend to ride your bike on roads, road tires would be an appropriate choice.
So maybe this provides the information you are looking for which can be summarized by "Yes."
daoswald is offline
Old 06-05-19, 02:14 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
The OP posted one post in his life here, and then left. I think the rest of us know the answer...
(Maybe he went to ******Ican'tsaythatonBF to find what he was looking for)
chas58 is offline
Old 06-05-19, 04:16 PM
robertorolfo
robertorolfo's Avatar
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times in 113 Posts
Cool, so can we turn this thread into a discussion on how annoying/difficult it is to follow topics on ******? The format, the "upvoting" system, the constant complaints about "downvotes"... it's all just a mess.
robertorolfo is offline
Cyclist0103
9
02-19-16 06:07 AM
09box
32
07-21-15 09:39 AM
CanadianBiker32
Road Cycling
4
04-23-15 01:51 PM
el nicho
Road Cycling
36
05-22-13 09:22 AM
Kurious Oranj
Road Cycling
11
10-19-10 09:20 AM
