Curious about 130mm dropouts
Was there a specific demarcation, or did every manufacturer make the change to 130mm in a staggered fashion? For instance I bought a new wheel set, then proceeded to the garage to cold set my frame in preparation, then found it already was 130mm. Somehow I just had it in my head a 6 speed freewheel was 126mm. It's an '84 Lotus frame. Then I looked at an '84 Miyata frame and that was 128mm.
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
During the transition period a lot of frames were spaced 128mm. Especially if the same frame was used for multiple models. This allowed higher models using the same frame to use 130mm drivetrains and lower models 126mm. 1984 seems a little early but maybe it was respaced somewhere in the past.
Bianchi Goddess
Quoted: 2912 Post(s)
Liked 2,838 Times
May 23 1986 @1307 every manufacturer switched over
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
At any rate, no bikes in 1984 would have been 130, and certainly no freewheel road bikes.
Just because a bike has the dropouts at 128 doesn't mean it isn't nominally still 126. OLD is determined by the hubs. Factory might have fudged it a bit, or somebody else spread it to make it easier to get the wheel in.
Likes For Salamandrine:
Bikes: fuji finest, klien pinacle
Quoted: 17 Post(s)
Liked 5 Times
May 23rd was a Monday. The great change over was on a Tuesday (nothing important takes place on a Monday), quite sure the time is correct as long as it’s GMT not EST. Lol
As was stated nothing just changed over everything kinda crossed over as a big blur. At least that what I kinda remember... lol
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Somewhere on his blog, Dave Moulton mentioned that he was building all his frames to 126mm when he hung up the torch in 1993.
