lubricating component pivot points
Questions to the forum:
1. What lube are you using on your component pivot points (front/rear derailleur and brakes)?
2. How often do you lube your component pivot points?
3 summits of Athens
Bikes: SCOTT AFD/KLEIN MANTRA/BMC SSX Streetfire
chain lube is fine, after every clean-degrease session, that is once or twice a month
How much does it weigh?
Bikes: Lotus Fixed, Bianchi Virata 2004
2. Every ride over 15 miles.
Bikes: SS Surly Crosscheck; '91 Cannondale 3.0
dude, if you seriously need chamois cream on any ride over 15 miles then you either need new bibs or a new saddle.
Oh I don't NEED it, but it's nice to use when a single ride is over 15. I'm perfectly comfortable doing a century without any chamois cream/butter/whatever, but since I can use it, I will use it
Bikes: Giant OCR 3, Bontrager, Trek 1500
Thanks for the reminder. My front brake was squeaking a little. Some chain lube and a wipe down took care of it.
Some sort of pithy irrelevant one-liner should go here.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
I use melted butter.
I really just blast it down with dry PTFE liquid wrench, but any lube works well.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
The reason I asked is because I used Pedro's dry lube and it seems to have done zilch. Sounds like I should switch to Tri-flow or something like it.
