Bizarre clicking when pedaling
Young wippersnapper
Bikes: 2009 Land Rover G4 Hardtail, Fausto Coppi San Remo
Well, I'm back here again!
I'm sure this is a really simple and basic question that you guys see all the time, but it bugs me that it happens.
When I'm pedaling, I hear a small clicking noise that sounds a bit like when a stone hits the frame, or one of my laces are flapping around on metal (I know it's neither of these).
I've tried shaking the cranks and they seem tight - no rocking from side to side and the pedals seem to spin without a problem. I've also noticed that it doesn't do it unless I pedal fairly gently, like if I'm going downhill or waiting for someone to catch up with me.
The pedals are fairly new so I would hope it's not them.
Can anyone suggest what this may be?
Thanks,
Thanks,
Quoted: 5789 Post(s)
Liked 2,581 Times
If it's a fairly new bike and the clicking happens once or twice per crank revolution, there's a good chance that it's simply the chain passing over the shift gate on the outer ring.
The shift gates are the cut down or missing teeth on the outer or middle rings (innermost rings don't have them). As the chain passes over them it can move over slightly then catch on the next tooth. It's comparable to the sound a train wheel makes going over a switch.
You can confirm this easily enough, by noting the crank position when it clicks, and then putting the crank in the same position and seeing if the gate is in the 11 o'clock position just about engaging the chain.
FB
Chain-L site
FB
Chain-L site
Young wippersnapper
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I had a similar sound and I first thought it was my crank on my new build, this was quite disturbing since I was at the halfway point of a 30 mile ride. Turns out it was a loose spindle on a brand new set of pedals.
Canadian Chick
Bikes: Lots
Quoted: 5 Post(s)
Liked 6 Times
There's many things it can be, things I would check are the chainring bolts, if they are loosening they can make clicking noises. Or, chain may simply be hitting the rings as it goes around.
It should not be expensive at all to change the chain, that's ridiculous! If you follow a video you can do it easily... all you probably need is a chain breaker, a new chain, a zip tie and a master link (these usually come with the new chain).
Young wippersnapper
Also, noob question, which are the chainring bolts? There seem to be rather a lot of bolts/screws in that area...
Young wippersnapper
Quoted: 453 Post(s)
Liked 104 Times
I was told by the LBS that he's had trouble with the chain slipping after changing just the chain, something to do with uneven wear across the sprockets and the chainrings. I was quoted Ł35 for the sprockets, Ł25 for the chainrings, Ł10 for the chain and Ł10 for the fitting. Is the wool being pulled over my eyes here?
The chainring bolts, are part of the chainset, they are the bolts which hold the chainrings on, so you already have them, and they can be re-used.
For your issue, have you checked where the cable from the front mech is going, as this can cause the type of noise you are hearing, if it hitting the frame on every revolution, when the bike is stationary, this will probably not be seen as causing the issue.
Not sure that changing any of the drive train will actually fix the clicking clicking problem, could also be the bottom bracket, no-one has mentioned that yet.
For your chain being worn, would suggest that it is worth getting this replaced, as if worn, it will wear the cassette / block, then the jockey wheels and chainrings, again, knowing your bikes spec woudl be useful in knowing what you have, and approx cost.
Quoted: 305 Post(s)
Liked 2,038 Times
It depends on your pedals but I have shimano m520's and I ordered the tool to fix the pedal. I could tell there was a problem with the pedal because of the pedal moved side to side and the shaft didn't. I will pull a part the pedal and tighten the nut at the end, that's all.
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
I've noticed that my BB creaks when the weather changes. Taking it out, regreasing, and properly retightening fixes it every time.
Young wippersnapper
I've been through as many of these as I can, aside from the chainbolts because I can't work out how to tighten them up, or what the chainbolts look like!
I think I'm gonna have to replace the pedals, it seems to be the only solution.
In the meantime, the headset bearings seem to have gone. Poo.
Thanks for all the responses anyway
whatisit
Bicycle Mechanics
7
06-10-13 07:59 AM
bobotech
Bicycle Mechanics
10
07-26-12 07:14 AM
