Swift folders
#3851
Some questions on the pivot bolt.
1. Is the diameter 10mm?
2. How long is the pivot bolt?
3. What are the thread specs?
4. Can someone post a photo of the pivot bolt?
5. When the bike is unfolded and in use, what type of load does the pivot bolt bear?
Thanks
Thanks
#3852
N + 1 Strikes Again.
Well, it sat on Craigslist for 19 days without a buyer... so I bought it
Pretty much stock, aluminum frame, 132.5 OLD.
Although it came with a Selle Royal SLR Gel Flow saddle.
Likes For Numerozero:
#3853
Xootr Swift Pivot Bolt
My metric Screw Chek’r says the threads are M6 x 1.0
I used a 3/32” punch to drift out the bolt, as it’s a tight fit (as it should be).
Last edited by Numerozero; 07-11-19 at 09:43 AM. Reason: Added screw thread picture
#3854
I just have to say that, although I've never ridden one, I think the Swift has more "pleasing" proportions than most 20" folders--probably because the top tube is straight and nearly level and sits relatively high off the ground--which is part of the reason that it doesn't fold down very small, I guess. I almost bought a used one for myself recently--same model with the rear derailleur--but made the mistake of letting the ad sit too long thinking the seller would lower the price. Oh well, Congratulations! I like that color, too.
#3855
Bikes: Ti Airborne Valkyrie - converted to 650b wheeled "all-road bike" / Vitus 992 converted to 650b / modified Swift folder
Quoted: 12 Post(s)
My Version of the Swift
Getting this Swift on the road has been a 6 mo odyssey but i'll spare you most of the gruesome details. The bike in the pics below began as a late version Xootr which is different, IMHO, from most folders in 3 important ways: (A) Peter got the geometry right. Unlike many poorly designed folders with insufficient trail the handling is neutral, confidence inspiring and yet still agile. (B) and it's affordable as a result of Peter's business decision and lack of "Prime Time" popularity. And, finally, (C) it's really heavy. The frame, fork, riser tube and seat tube is just a hair under 10 lbs!
When I got it (used) the complete bike weighted 25lbs. I managed to shed 4 of those lbs so it currently weights just under 21lbs. One of the way I did this was by having a CroMoly fork made for me that's lighter than the 2+ lb fork that came on the bike. And the curved riser / stem is also custom & ti. Seatpost is 31.8 rather than the stock 34mm (which saved almost 9 oz). This is a bike that i'm going to keep in my micro RV to use on trips so it seemed to be a perfect candidate to try out my 1st 1 x 11 drive train. And so far I love it! 11-42 cassette w/ a 52T chainring give me plenty of range for recreational riding. The tires are Tioga PowerBlock S-Spec OS-20 20X1.60 (451 x 41) which, so far, only measure 38mm and are only 260g! Highly recommended. Here's the pics:
Likes For laffin_boy:
#3856
Quoted: 4201 Post(s)
Liked 3,857 Times
It's always nice when a project sees the road for the first time. Looks nice! Andy
AndrewRStewart
AndrewRStewart
#3858
Quoted: 12 Post(s)
Hi Jur!
Neither actually. It's powder coat and the color is "transparent copper" - shiny aluminum base coat with a translucent color coat that gives it an anodized effect.
And the riser / stem is from Titan (long story which i'll tell you by email)
Tom
Tom
#3859
Very nice work....where did that fork come from and what kind of shim or seat post set up do you have?
#3860
Nice bike, and a beautiful colour!
#3861
Quoted: 12 Post(s)
The stock 34mm Xootr / Swift seatpost weighs just under 1.5 lbs! (I think Mel Gibson used one in the main battle scene of Braveheart) I found this on eBay and two of these 31.8 to 34 adapters and saved over 1/2 lb. PM me for install details if you need to.
#3862
How do you pack the Swift in your minivan? When I had a saloon, I'd dump the bike wrapped in a blanket on the back seat; it pressed against the rear of the front seat so it couldn't move around. Now I have a minivan, there is nothing to hold the bike tightly in, so it sloshes around. I've tried putting it folded in the front passenger footwell, but it requires enough room to open the door really wide and lots of manipulation. Lately, I've tried placing the bike upright and width-ways across the van, sandwiched between the tailgate and the last row of seats. This works OK, but it needs catching when the tailgate is opened, and I have to be very careful that it doesn't press on a window. There must be a neat or elegant way to carry it. I've seen internal racks for some specific cars, but they rely on taking the bike's front wheel out and clamping the forks into a quick release skewer, but dismantling a folder seems silly, and I get my hands dirty. Who'd have though having more load space would have been a problem?
#3863
Anyway, nice job!
#3864
Delayed response due to computer issues.
May I trouble you for 3 further measurements?
1. What is the internal diameter of the recess/aperture into which the pivot bolt fits? See attached figure for clarification.
2. What is the internal depth of this recess from the surface/top of the recess to where it meets the top tube?
3. What is the distance from the surface/top of one recess to the surface/top of the other recess? This is the distance between the two yellow arrows.
Please ask for clarifications if my request is not clear.
#3865
Xootr Swift Pivot Hole Inside Diameter
As you can see, a Craftsman 10mm thin wall socket barely fits into the recess. Even my Wera 10mm wicket is too wide.
#3866
Another Measurement
Outside distance varies due to slanted faces.
This measurement at approximately the middle of the slanted faces..
4mm alone key side, showing the M5 Pitlock Pit Stopper. This deters someone from splitting your frame into to halves (separate review coming).
The distance between the two recesses varies as their outer edges are slanted. The distance between the two’s bottom to bottom can be derived from the bolt dimensions I posted above.
#3868
Noob questions here, and sorry if this is a double post. My first went poof.
Are all Xootr Swift frames identical, and Xootr achieved S,M,L frames simply by offering various post and stems?
What are the obvious areas to look in a AL frame for fatigue, potential failure? Or is this risk minimal?
#3870
#3871
This threaded trailing-link suspension fork from Pacific Cycles is set up for 451 wheels. Has anyone here used it with a Swift (is it size-compatible?) and converted to that wheel size, changing out the brakes?
novis rebus studentem
#3873
Mind my asking where you sourced the 451 wheel sets?
Are the brakes Tektro R556 long reach? Couldn't quite see when I zoomed in on the photo.
#3874
Quoted: 12 Post(s)
Thank You
I built them. Used Velocity A23 24H rims that I could only find at Velocity (= expensive) Good rims, light but don't recommend Velocity as a good company to deal with. Unfortunately I bought Shimano Tiagra 36H hubs (skip every 3rd hole) to save $ but they're really heavy hubs. (would go to BikeHubStore.com next time) Bought custom sized Laser / Race Sapim spokes from yojimbo on eBay which aren't cheap either but are light & strong.
They're long reach Tektro R559's - the successor to the 556. Work great on the Swift with 451 wheels.
#3875
