Heartrate/Effort Question
Quoted: 82 Post(s)
Nope. Maximum for 30 minutes in one hour. Other 30 minutes were in zone4. The speed was higher, but so was the HR. I hit max HR one or two times a year. New record this year BTW. Plus 1 from previous.
Quoted: 82 Post(s)
Sure... But I feel more danger and it spoils the fun. It's OK for me to be not the fastest. I feel that there is a message in cycling but it escapes me.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
In the summer time my hr will be 10-15 bpm higher at a given power output. Heat and humidity can jack you up.
Conversely, in the midst of a big overreaching block my hr can be 10-15 bpm lower at a given power output simply due to a ton of fatigue.
HR can be a tricky thing.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
In general, intervals range in length between 30" and 20', done in one or more sets of 3-6 repeats. The object of the interval workout is, at the end, to be unable to complete another repeat at the same level of effort. That's how you know how hard to go, which takes practice at doing each particular protocol.
Here's a good discussion of the interval concept and application, in a series of articles: Joe Friel - Intervals, Part 1
If done consistently and with proper rest, results are obvious.
Results matter
Results matter
Quoted: 82 Post(s)
What are the options?
Bikes: TREK 8000,Trek Domane 4.5,Felt FR
Quoted: 21 Post(s)
I'm 68YO on a two and have hour ride I will reach a high of 162 a number of time and average 123 for the two and have hours.
Liked 1,938 Times
I read a lot about all that stuff and made my own zones 7-8% each. No lactate tests.
Well... For my muscle mass I'm fast... I think. And my mass do not change for decades. May be @Average@ is not about me. I'm slim and don't have any hope to change this.
BTW, skinny is fast, not slow. Ideal cycling BMIs are in the 19-22 range.
I see that you are anti-science. The training advice on this forum does have a scientific basis, and thus may not be of any value to you.
Results matter
Results matter
Quoted: 82 Post(s)
In what zone according to the science is lactate threshold? I see LT more like a moving target that tries to escape definition.
Quoted: 232 Post(s)
To keep it simple, try the following:
- Have easy days and hard days
- Simplest way to distinguish easy days from hard days is via time
- You'll be able to ride for one hour much harder than you will be able to ride for 4 hours
- So, for example, if your normal ride is 4 hours then once or twice per week do a shorter one hour ride and bust it
- Alternatively, you can do intervals twice per week
- For intervals, let duration determine your intensity
- For example, one day per week do 4 x 4 as hard as you can manage while riding all intervals at the same intensity
- One day per week do 2 x 20 as hard as you can manage while riding the second interval as hard as the first
- The interval / combined duration will naturally govern how hard you can go
- It may take a few tries to get the pacing right
- As you get stronger your interval speed will go up
- Monitor your recovery via resting heart rate, perceived effort (higher effort for same speed is indicator of fatigue), sleep quality, energy levels, appetite, mood and motivation
Liked 1,938 Times
LTHR doesn't vary as much, is fairly easily measured, and has a lot more to do with the training effects of HR zones than does MHR. Perhaps the easiest test to perform can be found here: https://trainright.com/cts-field-tes...-calculations/
Results matter
Results matter
Quoted: 82 Post(s)
Imagine me having average speed 10mph for 1 hour ride with AHR 150 (with a lot of start-stops). What distance should I ride in a year to have significant changes? By significant I see changing AHR 150-->130 or speed 10-->14mph (all other things staying the same). Now I'm riding 750 miles per year fixed gear several years. Yes, that's not much, but I'm sure is better than nothing.
I'm mashing type guy. Fast twitch muscles? Does it matter or not?
Quoted: 82 Post(s)
Another way which is sometimes done is to do a long climb, say an hour, gradually increasing the intensity. At some point, come out of the saddle and sprint as hard as you can until you begin to black out, or as some say, you see Jesus or Moses. That's at least pretty close.
Quoted: 232 Post(s)
Thanks! That's over the top for me, but I'm still interested and have some questions.
https://www.bikeradar.com/forums/vie...9265#p20425961
Liked 1,938 Times
For yearly distance, if you want to really go, ~5000 miles. To get by, 3000 miles. Personal experience. This includes trainer mileage and presumes year-round riding. I've heard it said that 100 miles a week is easy to do! All you need is one 60 mile weekend ride, and two 20 miles weekday rides. This is true, but demands a lot of consistency as well as the endurance to do the one long ride. I recommend working up to that weekend distance goal. That one long ride should be hilly. A good metric is 50'/mile, so ~3000' gain over 60 miles. The long ride makes all the difference. Massive effect on metabolism in all sorts of ways. Obviously, a geared bike is the way to go for this. Really, really hard to get there fixed. After you can do the typical 100 mile week and 60 mile hilly ride, you can consider riding fixed some in the winter. First, get in shape and learn to pedal.
You don't need a fancy geared bike. A $200 craigslist bike with 12 or so speeds will do fine. Once you've built the engine, something fancier will be attractive.
Results matter
Results matter
Quoted: 82 Post(s)
I quit.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I agree with Carbonfiberboy that fast twitch vs slow twitch isn't a discernible difference at this stage. On a fixed gear, it's not clear what "mashing type" means, because mashing = going slow. In that case, it's a matter of training more than muscle type.
Liked 1,938 Times
Quoted: 82 Post(s)
I have a winter bike and several winters under my belt. Have a nice teaching on a BF.
Quoted: 82 Post(s)
I dont know... I am comfortable with this stage. My gear is 86" in summer and I walk 14% hills. It's ok to me. Smaller gears are not comfortable to me. Only at winter, but it's a different story.
Bikes: Nashbar Road
Liked 341 Times
Quoted: 82 Post(s)
Great! I have a question. Faster = bigger leg muscles. More or less. Every picture shows that. OK. Lets not discuss when it is not true (greater efficiency, more nerves, etc.) . In many cases it is so.
Then... Muscles work on blood. For the same work muscle will use the same amount of blood. So there will be the same heart rate after muscle becomes bigger, than before training...
What's wrong with this picture?
Quoted: 1975 Post(s)
Liked 232 Times
To the second part about blood and HR, one of the primary results of training are increased blood volume and increased red blood cell count(hematocrit) so for the same HR you are moving more red blood cells around to the muscle, along with a lot of other adaptions
Bikes: Nashbar Road
Liked 341 Times
Quoted: 82 Post(s)
I tried not to talk about adaptations in my question. Only about muscle mass. Only about muscle mass.
