Tights with shorts
Tights with shorts
OK So it has finally got cold enough here that I am going to have to wear tights. The tights I bought don't have a chamois....So...do I wear my shorts with a chamois on the inside or outside of my tights?
Boo-ya!
Bikes: Handbuilt steel with Ultegra10/FSA parts; a fully customized Bianchi Pista with phil hubs, carbon fork, king headset, etc. it's tough.
You Know!? For Kids!
Shorts with chamois, then tights on top.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
When it gets cold enough I just throw 15lbs of crisco around my legs and use plastic trash bags to keep it on.
1/2 a binding 1/2 a brain
Bikes: Serotta Ottrott ST, Titus RX100, Seven Sola 29er HT in the works
inside
Or you can opt for a chamios liner instead of shorts ...still worn inside.
bought a new car
Bikes: 01 Pista and 99 Lemond Chambery
Shorts on the inside and tights on the outside. I always do this when it's below freezing.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Next time it is Crisco and Hefty for me...
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Quoted: 15 Post(s)
Liked 27 Times
OK, it took me a minute to even realize that this may be serious.
it's only just become too cold to ride without tights? where do you live, and what's too cold?
and, to answer your quaestion - wearing the tights under your bibs would be comprable to wearing underwear under your bibs!
WTF is that smell?
Originally Posted by dgregory57
I tried this with the cheap store brand of shortening and trash bags, and I can report that it was no fun.
Huachuca Rider
Bikes: Fuji CCR1, Specialized Roubaix
I usually use 60 degrees as the cutoff for adding or switching to tights. I wear tights with chamois if I expect the temp to be low throughout the ride and shorts with chamoisless tights when I expect it to warm up.
As was stated earlier - nothing between me and my chamois.
Just Peddlin' Around
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Leg warmers avoid the problem. I find the extra layer of the tights over the shorts tends to be uncomfortable. With leg warmers you're legs are covered, and there's not an extra layer to sit on. and if it's too cold to ride with leg warmers (which hasn't happened yet here in florida)its too cold to ride outdoors.
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Here in MT, 30 is the cut-off for the shorts/legwarmer combo. Any colder and you'll need a tub full of hot water, two pr0n mags and an Oreck 8lb vacuum if you ever want to see your naughties again.
jw
