BB Question
Old 04-30-06, 04:18 PM
Leviathan
BB Question
I have posted this in the Mechanics Forum also, but I thought you guys might be able to help too.
I just picked up this old frame that I am planning to convert. The BB will hardly turn so I am going to replace it from the get-go. Can anyone tell me how to remove this type of BB from the frame? Also, will this frame accept a modern type bottom bracket? Thanks.
File Type: jpg
Leviathan is offline
Old 04-30-06, 04:22 PM
mikearena
Glorified Blender
mikearena's Avatar
Take off the lockring with a lockring tool, or carefully with a screw driver and hammer. Then unscrew the cup with a wrench.
mikearena is offline
Old 04-30-06, 04:24 PM
baxtefer
Cornucopia of Awesomeness
baxtefer's Avatar
is that an old raleigh?
it kinda looks like one of their old 26 TPI BBs. (if so you're virtually screwed for new BBs - see sheldon for info)
if not, you just need a lockring tool (right threaded lockring) remove that, then you should be able to spin out the removable cup by hand or with a big wrench. then you can have fun with the fixed cup.
if you're lucky a big wrench will do. if you're not lucky then you'll need a fixed cup remover - see your LBS or sheldon for a homemade version
baxtefer is offline
Old 04-30-06, 05:10 PM
Leviathan
It is actually an old Schwinn. Am I still "screwed"?
Old 04-30-06, 07:05 PM
baxtefer
baxtefer's Avatar
oh, not screwed. it should be a regular british threaded BB then
you might be screwed for stem size though......but likely not.
baxtefer is offline
Old 04-30-06, 07:39 PM
dolface
Iguana Subsystem
dolface's Avatar
don't the electroforged schwinns have a giant bb shell that needs the insert-thingy (can't remember what it's called) that will allow a normal bb to be threaded in?
dolface is offline
Old 04-30-06, 08:07 PM
baxtefer
baxtefer's Avatar
yes, varsinentals have ashtabula cranks.
that picture, however is not of an electroforged schwinn, nor of an american BB
baxtefer is offline
Old 04-30-06, 08:15 PM
mikearena
Glorified Blender
mikearena's Avatar
Well, didn't I get lucky. I've got a Schwinn conversion with the weird cranks, and the weird stem. I can't even run modern pedals on it.
Old 04-30-06, 08:17 PM
dolface
Iguana Subsystem
dolface's Avatar
good point.
/wasn't paying enough attention.
dolface is offline
Old 05-01-06, 09:08 AM
Aeroplane
jack of one or two trades
Aeroplane's Avatar
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
I made a fixed-cup remover following Sheldon's advice, and it works like butter. Cost $1 at the local hardware store.
Aeroplane is offline
Old 05-01-06, 10:35 AM
Ya Tu Sabes
Rebel Thousandaire
Ya Tu Sabes's Avatar
Bikes: Public D8, Yuba Mundo (cargo), Novara Buzz (1-speed, soon to be 2-speed w/ a kickback hub), Xootr 1-speed folder
Even you have trouble finding a cartridge bb for the frame, you may not be so screwed. Once you get the thing open, scrap all the bearings and have a look at the insides of the cups - if they're not grooved or pitted, you might be able to just clean 'em out and put in new grease and a new set of ball bearings. I just did this with an old French bb and it is running like new now. I followed Sheldon's advice and traded the bearing holder (that plastic thing that olds 7 ball bearings) for loose bearings (11 per cup). I also scrapped the old axle (which took annoying cottered cranks) for a newer, square taper sort. Maybe you can do the same.
Ya Tu Sabes is offline
