Compact Road Crankset
Old 02-12-07, 09:13 AM
Leviathan
I am building another fixie and am down to the crankset. I have a compact crankset laying around that I would love to use but I am unsure about chainring selection. So, what is the smallest outside ring I can get and largest inside ring on a 110BCD? Thanks.
Leviathan is offline
Old 02-12-07, 09:31 AM
Psydotek
Body By Nintendo
Psydotek's Avatar
Location: Videogames ruined my life. Good thing i have 2 extra lives.
Bikes: Giant TCR2, Giant TCX, IRO BFSSFG SE, Salsa Casseroll, IRO Rob Roy.
33T is the smallest possible i believe, avaliable through Harris Cyclery last i saw. 34T is much more common though (FSA makes some, avaliable from JensonUSA).
Originally Posted by jsharr
A girl once asked me to give her twelve inches and make it hurt. I had to make love to her 3 times and then punch her in the nose.
Psydotek is offline
Old 02-12-07, 11:18 AM
Aeroplane
jack of one or two trades
Aeroplane's Avatar
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
You'll be really hard pressed to find anything smaller than a 34t. If you get into 4-bolts, then it goes down to 32.
Aeroplane is offline
Old 02-12-07, 11:23 AM
MrCjolsen
MrCjolsen's Avatar
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
Liked 4 Times in 3 Posts
The inside and outside BCD on a double crankset are the same. So you can put a 50t ring on the inside and a 34t ring on the outside. Do whatever gives you the best chainline. Seeing that you are building another fixie, you should already know this.
MrCjolsen is offline
Old 02-12-07, 12:54 PM
Leviathan
Well what I meant by inside/outside is that most places sell rings for compacts as "inside" or "outside". I was really hoping that someone would say that there is a 42 or a 44 out there somewhere for 110BCD. Is that not the case? Thanks.
Old 02-12-07, 12:58 PM
dirtyphotons
antisocialite
dirtyphotons's Avatar
lots. here are some:
https://www.sheldonbrown.com/harris/chainrings/110.html
the cheaper rocket ring works quite well for my purposes, your mileage may vary.
dirtyphotons is offline
Old 02-12-07, 03:24 PM
Aeroplane
Aeroplane's Avatar
The "inside" and "outside" refers to how they are ramped and pinned to help shifting. Since you won't be shifting, it doesn't really matter, and you probably don't rings that are anyways.
You can find rings from 34t all the way up to 54t pretty easily.
Old 02-12-07, 04:58 PM
Surferbruce
Surferbruce's Avatar
salsa cycles also has a big range of rings with various bcd.
Surferbruce is offline
Old 02-12-07, 05:05 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
loosescrews.com has a good selection of rings
JanMM is offline
Old 02-14-07, 11:33 AM
E !
E !'s Avatar
Bikes: some
I second salsa rings. One differance between large and mid rings. The large ones are made to fit the chainring bolt to the outside. Middle rings are not made that way. I would only use a ss specific ring though.
E ! is offline
Old 02-14-07, 12:41 PM
fatbat
spinspinspinspin
fatbat's Avatar
salsa rings last much longer than the rocket rings.
fatbat is offline
Old 02-14-07, 01:29 PM
Landgolier
THIS SPACE FOR RENT
I'm done with rocket rings after this one, 1000 miles or so and it looks like crap, the teeth aren't worn so much as they are deformed.
Landgolier is offline
Old 02-14-07, 02:28 PM
Retem
Paste Taster
Retem's Avatar
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
rocket rings bro 33 and 32 if you can find em they are a popular size
Retem is offline
