Assessing bent derailleur hanger?
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
visually, my hanger appear very slightly bent. I am considering removing it and testing with a straight edge but then I wondered;
1. are hangers always manufactured perfectly straight?
2. is ANY amount of bend acceptable?
3. is it acceptable to attempt to straighten it with a hammer on an anvil?
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
1. No
2. Maybe
3. No
Adjust hanger while mounted on the bike. Use the Hanger Alignment Tool. Ust the correct tool for this job.
2. Maybe
3. No
Likes For trailangel:
Friendship is Magic
Bikes: old ones
Quoted: 26437 Post(s)
Liked 10,397 Times
Likes For 3alarmer:
Clark W. Griswold
Quoted: 4389 Post(s)
Liked 4,027 Times
Use a proper hanger or derailleur alignment gauge pick a spot on the wheel like the valve hole and use that to straighten it if you know what you are doing, otherwise just have a shop do it. The correct tool is not necessarily a cheap tool and the job is one you want to do with accuracy and some knowledge on the topic to not make it worse.
I would not recommend the just bang on it or bend it with other tools "method" as I am sure some one will suggest because it worked for them. Just do it right and then not have to worry.
Likes For veganbikes:
LR÷P=HR
Quoted: 868 Post(s)
Liked 1,208 Times
You can't test a hanger for correct alignment with it off the bike.
The process of aligning the hanger on the bike, places bends in it that are customized to your frame.
Even if you were to purchase a brand new hanger, these custom bends will be required to align it for use on your frame.
Hope that helps
Barry
Hope that helps
Barry
Likes For Barry2:
If you don't have the tool you can check the alignment by removing the deer. and screwing in a spare or borrowed rear wheel. They are both 10X1 mm. If the wheels are parallel, there is no problem., If not use the spare wheel to realign the hanger Once. Aluminum doesn't take to a lot of rebending..
Likes For davidad:
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
Hope that helps
Barry
Hope that helps
Barry
Likes For Schweinhund:
Likes For Barry2:
Friendship is Magic
Bikes: old ones
Liked 10,397 Times
...if you are going to use it a lot (like professionally), this might matter. But they all work about the same, so for home use, get something that's cheaper.
For some reason, this is one of the tools that has spawned all sorts of high end, beautiful tool versions. They don't do a significantly better job than the cheaper ones, if used properly.
Here's one for 25 bucks.
Clark W. Griswold
Liked 4,027 Times
Here are my top choices:
Abbey HAG (I own this personally)
EVT Tru-Arc
Park DAG-3
Shimano RD-TL11
Park DAG-2.2
Wolf Tooth Pack Hanger Alignment Tool (portable)
Yes some of these tools are maybe initially expensive but a precision tool that lasts a long time and does the job well is well worth it. You will not regret spending money on high quality tools you will regret having to buy cheap tools over and over again and potentially doing damage to different parts on your bike.
Make sure you read the instructions well or watch some videos on the tool you end up with. Having this tool and knowing how to use it is helpful but if you don't want to do it your local shop can do it but having the tools and knowledge is pretty awesome.
EVT Tru-Arc
Park DAG-3
Shimano RD-TL11
Park DAG-2.2
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
If the hanger is bent BADLY, then smacking it with a hammer while off the frame is a way to Temporarily straighten it out and make it usable.. BUT it May Crack and it WILL BE WEAKER...trying to straighten a badly bent hanger ON the Frame MAY ALSO BEND THE FRAME.
note any offset or cutout portions of the hanger and take steps to not mess up those areas.... and i advise only hitting the outside of the hanger,not the inner side. and avoid hitting any Threaded Holes to limit damage to those threads.
THEN ORDER A NEW HANGER. Once they bend, they get WEAK and WILL BEND or BREAK easily after "straightening"
Likes For maddog34:
Likes For oldukbkr:
Quoted: 507 Post(s)
Liked 652 Times
A HAG is the right tool, but if you don't have one, an old school front wheel will work. You can take the hanger off, and check it on a flat surface, but its the combination of the hanger and the dropout when attached that is important, so make sure it's secured properly on the frame, and then align when mounted. An adjustable wrench will work also. If you aren't very experienced, (and even if you are) having a spare is never a bad idea. You want to determine where you want to end up, and make one adjustment there, you don't want to make a bunch of little adjustments.
Liked 741 Times
Except the fact that a Bent Der. hanger causes more rapid wear on derailleur rollers, Der. cages, Sprockets, and the chain....
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
It can do that without affecting shifting at all?
Liked 741 Times
Hammer, yes, yes, always, and please post video.
Liked 741 Times
people have different levels of "affecting"... and will often ignore what you or i may call a "problem."
example: Eliminating sluggish and variable shifts from the rear of a Box store bike is nearly impossible, but millions of them roll around not shifting correctly by our standards... the owners never know the difference until they buy an upgraded der. or a better bike.
another example: a twisted hanger can and does cause advanced wear, but the bike may still "shift" fine...
and another: the hanger was bent, so the owner grabbed the der and bent it back to roughly vertical... it was out in two more planes... still bent, but back in position enough to allow sluggish and variable shifting,which the owner is ok with, but you or i would not be satisfied with.
Likes For maddog34:
Liked 2,571 Times
RUSA #7498
Liked 741 Times
operative words in your reply .. "I" and "I'd"
look at things from other possible perspectives.
Liked 2,571 Times
Obviously we are all an "I". Tangents are fun, but the OP has not offered any evidence that his RD hanger is actually bent. For all we know, his eyes are just fooling him. So I propose getting out of the weeds and discussing symptoms first.
Liked 741 Times
bye bye.
also see: the thread opening post... "Slight bend"
Liked 2,571 Times
Feel free to put me on ignore if it helps keep your blood pressure down.
Liked 741 Times
and to anyone saying a Der. Hanger should not be pounded on.. MOST Der. hangers are made in a stamp mill.... under thousands of pounds of POUNDING and SHEARING force
and "checking with a ruler" is a great way to check them for a "slight bend".
next time, you "experts" should advise doing the ruler check on the inner side since it was the downside during STAMP FORGING and is one of the Reference Surfaces during the MACHINING step of the processes involved in making a Der. hanger.
to thermonicscott.. now you're building a strawman. I hope you defeat your imaginary opponent!
i'm going riding now... a fast downhill awaits my attention... the comencal is aired up and ready to fly.
