Seatpost bolt, Campy
I need to replace the bolt on a Campy single bolt post. Should I just buy a bolt that fits at the hardware, or does it need to be something special? Thanks.
(edit) A quick check online informs me that this isn’t going to be easy to find. Maybe a new post is in order.
I believe the size is M8 x 35 mm fine thread. Can anyone confirm that? And if a source is known, I am all ears.
Quoted: 413 Post(s)
Liked 109 Times
They’re a very odd thread. Every blue moon during a solar flare, if you get lucky, eBay’s crystal ball gets a hit.
I see there’s a few listed now started at $25-ish. If it’s M8x1.0 pitch then try Amazon or Home Depot. I saw 50mm length on Amazon.
Likes For miamijim:
Quoted: 4533 Post(s)
Liked 6,440 Times
That sucks, is the broken piece stuck in the cradle?
We had this a few weeks ago on an older version with the regular hex head bolt, snapped just like this once the OP was able to get a hold of it right proper.
I have one that was slipping and wouldn't tighten enough. I got it apart, cleaned and burnished? the threads on the wire wheel, anti-seize and a well fitting 6 point wrench FTW.
Seems like these and many others need to be serviced better, more often if we want them to keep going.
This one broke while I was riding - an interesting sensation. At least I found the clamp bits without too much trouble.
The bolt broke where the threads begin, which I suppose was predictable. Maybe it was over-torqued at some point.
I will probably wind up ordering a bolt from Italy. Worst part is the delay, but I guess that's why we need multiple bikes.
Likes For due ruote:
Liked 6,440 Times
Nope, not stuck at all. In fact, I just unscrewed it with my fingers.
I would also be inclined to explore a better substitute to avoid this going forward, maybe even rethread the cradle for a common bolt and maybe even add a locknut on top of the cradle.
We know from the SP binder bolts and these that Campy may not maintain fasteners at the same level as the parts and pieces themselves.
As noted in the other binder bolt thread, they are cut threads instead of rolled and from my observation not that well done IMO being sharp and jagged creating many stress risers therefore doomed to fail as they often seem to do.
The wire wheel and anti-seize or grease can go a long way towards preventing this.
Bikes: Eddy Merckx EX & Bob Jackson R:753 tubing
Quoted: 15 Post(s)
Liked 44 Times
https://www.mcmaster.com/screws/syst...d-type~socket/
Mc Master Carr, they are a good place for fasteners as in 8×1.0 seat bolt/screw.
Liked 6,440 Times
https://www.bikeforums.net/22642405-post19.html
Likes For merziac:
As luck would have it, I went to the hardware and used their thread board to determine that it is in fact a M8 x 1.0 x 35mm bolt that I need. And although they only stocked coarse thread, I was able to find one on Ebay for $7. Cool, right? Almost. Only then did I realize that I had found all the bits except the contoured thrust washer (or whatever it's called) that goes under the bolt head. I returned to the scene of the crime and did a few slow passes, but no luck finding it.
So now I am looking at this seatpost and thinking OK, I will never find one of these bits, but really how hard could it be to fab. one?
Does anyone have a Victory post laying around? I would love to see a picture of the wedge piece and get a couple measurements. I tried Velobase but keep getting security warnings, so I haven't actually seen what's there.
Liked 6,440 Times
That's cool, but I think maybe that's a C-Record (?) post and what I have is a Victory. The post has a cavity where the bolt head goes so it's not visible from that view.
Really shouldn't be that hard to cobble something, even if temporary.
Liked 6,440 Times
@due ruote
Mine is the style with a slot like yours I think, has a big stout bolt, may have been changed and the little concave/flat squarish washer, its good hard stuff so....
Might be a challenge to fab a really good substitute but wouldn't stop me from trying.
@due ruote
Liked 6,440 Times
Thanks. That’s what I was afraid of. I don’t really have the facility for something like that.
(Edit) I gave this a little more thought, and perhaps I will give this a go after all. I found a chunk of 1/2" steel rod laying around, and it looks like a decent fit. I do have a vice, angle grinder, files and a drill press... @merziac, if you (or someone else) are able to post a photo of the piece, that would be very helpful. If the post is installed and you don't want to unsaddle it, I get it. Thanks.
Liked 6,440 Times
On it, standby.
I don't think it really has to be that hard but it and the bolt on this one seem to be what you would want long term, weight weenieness not withstanding and not ever a concern for me.
Liked 6,440 Times
Mine is decidedly concave where the washer sits, which is why I mentioned trying to use round stock to make the part.
I am pretty sure mine had some type of washer in there, but I didn’t have the presence of mind to search for it when the post exploded. Probably got picked up by a car tire and is who knows where by now.
Pics:
Liked 6,440 Times
Thanks a lot for posting that. I am not sure we have the same seatpost.
Pics:
Pics:
DOH! Yep, you're correct, the UNO workaround might work by turning the half round 45 degrees. I would hesitate to make one out of steel as the wedging might hack on the SP if it has to be good and tight as they usually do., I would get some alloy rod or an UNO that would have all you need to get back on the road even if you had to rework the half round to fit yours.
Something compelled me to go back for one more look and voilà:
And btw it is steel.
Thanks for going along - sorry it was all for naught, but who doesn’t like a happy ending?
Liked 6,440 Times
Not surprised the original is steel, I was concerned about fabbing one and having it be off enough somewhere to get stuck or blow up the program.
Factory stuff can be sneaky "oh *****, I thought it could be a little smaller, bigger, longer or shorter", snap, crackle, BANG!
Glad you found it.
I'm sorry that I come to the party late. If you are still seeking a replacement bolt, Jim Merz has made some of titanium. I have one from Jim on the same seat post. I no longer worry about that seat post.
He did have a few on hand, last I knew. When he makes a custom bit (like Ti crank bolts), he generally makes a few. Ask him.
Cheers!
Cheers!
1959 Hilton Wrigley Connoisseur (my favorite!)
1963 Hetchins Mountain King
1971 Gitane Tour de France (original owner)
* 1971 Gitane Super Corsa (crashed)
* rebuilt as upright cruiser
1971 Gitane Super Corsa #2 (sweet replacement)
1980 Ritchey Road Touring (The Grail Bike)
1982 Tom Ritchey Everest
(replacing stolen 1981 TR Everest custom)
1982 Tom Ritchey McKinley (touring pickup truck)
1985 ALAN Record (Glued & Screwed. A gift.)
Last edited by cb400bill; 09-15-22 at 02:51 PM. Reason: removed non forum members email
Cheers!
Cheers!
