Quick release axle threaded all the way
Old 06-09-19, 06:30 PM
paramountx
Quoted: 18 Post(s)
I want to rebuild my m475 hub. When I measured my hub end to end it's 108mm
Some axles I'm seeing are threaded all the way across and is hollow. My question is, how come the end aren't like dethreaded or stepped down like in normal qr axles.
paramountx is offline
Old 06-09-19, 07:29 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Have you seen enough front axles to define "normal"?
What's wrong with the current axle? Unless damaged there is no logical reason to replace it.
Bill Kapaun is offline
Old 06-09-19, 07:39 PM
paramountx
Quoted: 18 Post(s)
Lol true. So ok my sample size is small so my normal is ill informed. I need a new ankle just for fun. I want to pretend to know the process just in case i actually need to.
But so are you going to address my comment about it being stepped down vs threaded. I'm concerned that they threads would be damaged.
I have an axle but I'm not sure what it would be called
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
All of the qr axles I'm familiar with are threaded all the way to both ends and are uniform in diameter. They are not "stepped down" or "dethreaded".
HillRider is offline
Old 06-09-19, 07:48 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4201 Post(s)
Liked 3,857 Times in 2,305 Posts
There have been some threaded axles which have had their threaded ends turned down, not many but they do exist.
What does interest me is the photos of your axle and the worn down spots of threading. Looks to me that the axle, and not the cones or intended bearing surfaces, have been acting as the bearing. Is this correct? Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 06-09-19, 08:13 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,682 Times in 4,077 Posts
That's not exactly "normal". That might be a 10mm axle turned down to fit a fork intended for 9mm axles.
When you say m475, do you mean shimano Deore?
Might be cheaper/ easier to get a new front wheel - I've gotten them for around $50.
LesterOfPuppets is offline
Old 06-09-19, 09:19 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
FWIW all of mine are threaded to the end.
dsbrantjr is offline
Old 06-09-19, 09:29 PM
LesterOfPuppets
Bikes: everywhere
There's another thread on this subject with smooth ended Deore m475 axles.
I guess my XTs are old style. m756, they're 9mm and threaded all the way across.
Old 06-09-19, 10:16 PM
Bill Kapaun
Actually, I think I'm done pretending you're actually serious enough to look up anything.
Likes For Bill Kapaun:
Old 06-10-19, 09:22 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
What's going on with all those damaged threads ?
Homebrew01 is offline
Old 06-10-19, 12:07 PM
Andrew R Stewart
Not saying that this is going on but thread wear, as seen along the axle in spots, like this can be from the bearings failing to maintain the ability to keep the axle coaxial with the hub's IDs. In other words the axle got so loose it spun on the axle/hub contacts and not by the bearings. Andy
AndrewRStewart
Old 06-16-19, 06:36 PM
paramountx
Quoted: 18 Post(s)
kthxbai
Old 06-16-19, 06:37 PM
paramountx
Quoted: 18 Post(s)
I'm not too sure. Whoever did it, is not around for me to ask
Old 06-18-19, 08:37 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 943 Post(s)
Liked 658 Times in 371 Posts
Are your hubs disc or non disc? Not sure if it changed along the way, but front disc (Shimano) hubs have had M10 axles for quite some time.
Dan Burkhart is offline
Old 06-18-19, 11:36 AM
LesterOfPuppets
Bikes: everywhere
Yep, 6-bolt disc. These hubs might be quite old. Got the wheelset on a super closeout sale for $200 about 2 years ago. My phone refused to focus on the threads, but they're there
Likes For LesterOfPuppets:
Skipjacks
Bicycle Mechanics
27
01-31-18 03:48 PM
smovlov
Bicycle Mechanics
14
05-31-17 06:09 AM
PIZZ
Bicycle Mechanics
6
11-21-11 10:19 AM
RobE30
Classic & Vintage
3
07-06-11 11:27 PM
Zaphod Beeblebrox
Classic & Vintage
16
07-13-10 09:02 AM
