Kickstand problem
Kickstand problem
Some time ago, I stopped and while putting my kickstand down it just came off from my foot. The components with the picture fell off. I need help to re-mount it.
Pics: https :// photos. app .goo. gl/ BGitzbgPrMyKVb3o8 (remove the spaces) (Sorry admins, but I need help for a kickstand, not for posting 10 things)
Bikes: Lynskey GR270
Quoted: 115 Post(s)
Liked 69 Times
No offense, but have you tried? It's pretty obvious where the bolt goes? If I had to guess, the spring goes on the little "ball" sticking out of the stand arm, and probably mates with a recessed surface inside of the part that is still attached to the bike. (Pics don't show the insides).
There's 3 loose parts, that's not a lot of ways to fit these things!
If the bolt doesn't screw tight into the part that's still on the bike, the threads may be stripped, in which case you'd need to find a longer one and use a nut on the other side.
I've tried putting it in. There is no parts in the inside, just space. I put the spring in, then the ball that is sticking out on the spring and the bolt on the hole, but the stand is too loose and when testing the bike by jumping it up and down the stand slowly falls down. And after putting the stand up and down the bolt somehow came out a bit by itself.
Droid on a mission
Quoted: 315 Post(s)
Liked 276 Times
So you are either missing parts that fell off before you put the kickstand down or some broke off.
Solution.... buy a new kickstand
Here are a couple to choose from that look similar to yours
https://www.amazon.com/BV-Adjustable...-1-spons&psc=1
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
I prefer the rear-mounted kind, myself. The local cops have them on their bikes, too. https://www.amazon.com/Greenfield-SK.../dp/B002FVYTLI
