Building Cross Barriers
Old 01-24-07, 05:28 PM
drumbum
drumbum's Avatar
Bikes: Moots CX, Redline CX
Hi all,
I'm aware of the lameness of my question; please forgive me:
Whats the best way to build a set of cyclocross barriers? Looking at constructing a couple for around my property. Standards? Materials?
Thanks!
drumbum is offline
Old 01-24-07, 06:49 PM
Walleye
member
I made some out of 1/2" PVC pipe. I'm assuming you want a pair for practice. I think that for each barrier, i needed 10' straight PVC, two 90* elbows, and two 90* tee connectors. Out of the 10-footer, cut a 3' piece (the cross piece you'll hop), two 16" (or whatever height you want to jump) pieces for the down tubes, and four 12" pieces that will serve as bracket stands. What's nice about these is that they break before you do should you fall on them- not a feature of, say, pressure-treated 2x lumber. They are also light, and twist flat (or disassemble) should you want to take them somewhere. As far as standards go (height?), I routinely learn and forget this several times/season
Walleye is offline
Old 01-24-07, 09:09 PM
ronbridal
ronbridal's Avatar
I built something very similar but I used two horizontal bars to make it sturdier. My barriers are also a little wider. This is a very cheap way to do it and makes the hurdles very mobile as well. I have two built and stick them on my shoulder and ride down to the park to practice. Below is a picture of one of the hurdles. If you build like this, you will need two elbow joints, four tee connectors, and enough PVC. Not a bad set up. Plus you can take off the top tube and practice bunnyhops.
ronbridal is offline
ronbridal
ronbridal's Avatar
Forgot the picture.
Old 01-24-07, 10:38 PM
endform
blacksheep the blemish
Bikes: 1973 Schwinn World Voyageur (manufactured by panasonic), Italvega Super Speciale (fixed, primary ride now), Kona 2004 JTS 10 spd
You could also have your 8' or whatever horizontal bar attached on both ends with a T, and then put a 16" or whatever piece on one side of each T, then pound some rebar into the ground through the open hole.
endform is offline
Old 01-25-07, 08:10 PM
drumbum
drumbum's Avatar
Originally Posted by ronbridal
Forgot the picture.
Went to Lowe's tonight and bought the same supplies as in your picture for a grand total of $4.08. Will assemble tomorrow...thanks again!
drumbum is offline
Old 01-28-07, 11:14 AM
JimmyMack
JimmyMack's Avatar
I did this same thing. It works great as Walleye pointed out. Very portable. If you hook up with a couple of friends for practice they will be very happy you brought them.
A folding lawn chair bag works well for carrying the parts when broken down. Practicing Barriers is not lame by any means, well maybe to the genreal public. Barrier work is essential and I commend you on your effort.
JimmyMack is offline
Asi
Bicycle Mechanics
23
07-27-18 01:38 PM
roastbeef
Singlespeed & Fixed Gear
3
08-29-08 12:24 AM
paxtonm
Touring
17
01-24-08 07:47 PM
kyselad
12
05-27-06 11:15 AM
ZappCatt
10
11-25-05 10:15 AM
