ideal campy cross set up? help.
Old 02-16-07, 11:20 AM
oharescrubs
yack
Bikes: all of them.
So spending a boring day inside my house while the plumber is tearing my bathroom apart, ive been daydreaming of my next cross bike... Ive seen some cross race bikes with full campy, what campy stuff is the best for cross purposes? or what do you use etc etc? and to adapt this TIRED old question to cross, any reasons campy over shimano, but in cyclocross specific terms.
oharescrubs is offline
Old 02-21-07, 06:25 PM
JimmyMack
JimmyMack's Avatar
centaur. works good.
If you go with campy, you better like enough to own spare wheels. Some bigger races might offer a neutral wheel tent. I doubt they will have anything other than shimano for you.
JimmyMack is offline
Old 02-22-07, 02:29 PM
Iffacus
Iffacus's Avatar
I have been using Campag for the past 4years on my cross bikes. One thing I do like is the little button on the side of the brifters that when pushed increase the amount of clearence between wheel and brakes.
Nice little trick if you racing in very muddy conditions.
Iffacus is offline
Old 02-23-07, 08:52 AM
MrPolak
Just ride it.
MrPolak's Avatar
I have a Centaur setup with a compact crank on my Flyte. The 50-tooth ring is replaced with an FSA 46-tooth. The inner is 34. Rear cassette is 10-sp 12-25. I have Campagnolo Scirocco wheels as well, which have done well.
MrPolak is offline
Old 02-23-07, 05:53 PM
ejpres
Did the FSA chainring fit on the Campagnolo CT crank as it was or did you have to tune it in a bit? I hear the radius for the bolt behind the crankarm is a bit different from the normal compacts.
ejpres is offline
Old 02-28-07, 04:26 AM
cs1
cs1's Avatar
Bikes: Specialized, Schwinn
Quoted: 143 Post(s)
If I was going to use Campy on a cross bike, it would be Mirage. Centaur and Chorus are way too expensive to trash in the mud. Mirage is very affordable and performs well. I am running a Veloce/Mirage with Campy barcons on one of my bikes now. It works very well. Good luck
Tim
cs1 is offline
Old 03-01-07, 09:27 AM
alreadyblue
Bikes: Specialized Allez
I really suggest you don't use Campy stuff on your bike.
1. It's much more expensive than it's Shimano Equivelant
2. Very few people in the USA run Campy on their cross bikes, so finding spare wheels at a race is hard to impossible.
3. Used/spare parts are much harder to find and fetch a lot more money on Ebay. And let's face it, cross bikes go through a lot more parts than your road bike will.
I have a friend who switched his Kona JTS over to Campy because his road bike runs campy. I guess that makes sense for him, but he'll always have to bring spare wheels. God forbid he trashes any other part at a race. I think he runs Veloce on the JTS.
alreadyblue is offline
Old 04-21-07, 09:18 PM
Ronsonic
Quoted: 54 Post(s)
I'm running last year's Campy Mirage and it works great. I'd say they were a bargain compared to the Shimano stuff, but that's taste, I guess. BTW, a 9S Campy shifter and der combination will shift a Shimano 9s cassette just fine. Make half a turn on the barrel adjust and you're good to go. I've got Campy and Shimano wheelsets, right now one has road tires. Don't be afraid to go Campy.
Ronsonic is offline
Old 04-22-07, 04:17 AM
cslone
Quarq shill
cslone's Avatar
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
Mirage or Veloce are going to be the best bang for your buck. If you have a Shimano neutral support, the 9's will generally shift almost flawlessly, while the 10's isn't perfect, it will get you through the race. Campy is not much more expensive than Shimano, and I run 3 roadbikes with Campy, which is why my cross build is also going to be Campy.
cslone is offline
Old 04-22-07, 05:45 AM
jhota
blithering idiot
jhota's Avatar
Bikes: 1991 Trek 930, 2005 Bianchi Eros, 2006 Nashbar "X," IRO Rob Roy
i don't race, but i've retired my mtb in favour of my 'cross bike, which is Shimagnolo. not exactly what you're looking for, but i like it - brifters and front derailer are Centaur, rear mech is XTR. gets pounded a lot, and works flawlessly.
cheap and easy to match the cassette, too - i'm running a 9-speed 105 right now...
jhota is offline
Old 04-28-07, 10:41 PM
nitropowered
Bikes: Custom Custom Custom
I guess if you have Campy road bikes, It would make sense to build it with Campy.
If buying new 2007, I'd get Chorus shifters, centaur or veloce UT cranks (the only difference is color and the machined vs stamped rings, but if you are going to change the 50t to a 48 or 46t might as well take the cheaper veloce crank), centaur or veloce cogs, veloce chain, spooky brakes, veloce rear derailleur (no carbon) centaur or veloce FD.
If you want to save money, hit up ebay for pre-2007 shifters.
I'm building a cross frame now and I'm really torn on what parts to use on it. My road bikes are campy and have 1 spare rear campy wheel. I really like to try out SRAM since the wholesale cost on it is so low but i'd have to buy/build new wheels.
nitropowered is offline
Old 04-30-07, 01:01 AM
fogrider
Bikes: Ron Cooper, Time VXSR, rock lobster, rock lobster, serotta, ritchey, kestrel, paramount
I'm running centaur 10 shifters with shimano 9 speed wheels. I don't like 10 speed chains...they don't last more than 1,500 miles and they have been known to fail. shimano shifters rely on too many small parts which don't like dirt and mud.
fogrider is offline
Old 04-30-07, 08:16 PM
mellowdave
Красный Октябрь
mellowdave's Avatar
Bikes: Cervelo R2.5, Kona Jake The Snake, Pinarello Galileo, and Fisher Zigurrat.
Centaur, Mirage, Veloce, all work fine. Ignore all the B$ about this has been known to fail, that has been known to fail. My uncles buddy's niece saw some campy parts fail once. Jeez.
The only truth up there is the statement about finding neutral wheel support. Though Lately I see that changing too. Maybe in the NW its an issue, but its not so bad here. Anything you do break can be ordered as parts if you cant find a quick replacement, so get in good with your LBS. There is a HUGE difference between retail and racer price.
All posts are crafted by an adult, for adults. Not responsible for hurt feelings, snot bubbles or tears. If something someone says to you on an internet forum affects your happiness, you have issues. Get in touch with your true self.
mellowdave is offline
Old 05-02-07, 09:26 AM
somnambulant
So I says to Mable I says
somnambulant's Avatar
Bikes: '05 Urbanite Fixie, '06 Lemond Croix de Fer, '06 Jamis Dragon Pro, '07 IRO Bikeforums Track, '07 Planet-X Uncle John
I'm planning on going Centaur on my new bike.. Personally I figure I'm not really competitive enough to care about neutral support. If I flat and they don't have a campy spare, then a big 'ol DNF for me. At least for this season as hopefully I'll have a spare wheelset next year.
somnambulant is offline
Old 05-11-07, 03:40 PM
amorrow
Bikes: Witt Custom / Cinelli SuperCorsa / Raleigh Cross, nothing original / Very old Bianchi Mtn Bike
This stuff about 'cross being hard on parts is true, but that doesn't warrant buying shimano. In fact, last season, I busted the internals of my older ultegra STI levers when I wrenched on the lever in the heat of it. Now, I can't fix it. It's toast. Campy can be repaired. I've done it to my record levers and it requires patience, but no particular skill. This year I'll use old campy 9 speed parts from ebay and craigslist.
Oh, and shimano wheels work on campy... most of the time.
amorrow is offline
daven1986
Bicycle Mechanics
4
07-21-10 12:15 PM
Roy G. Biv
Singlespeed & Fixed Gear
14
06-16-10 08:53 AM
IllSpecialist
212
04-29-08 03:51 PM
