What are the odds I can make my 1,600KM bike trip without plugging in? :)
I just got my 350ht rr bionX kit yesterday, but am leaving for my trip to Hider ALASKA tomorrow... I really want to do the trip without assistance, but... anyways, can I can re-charge the battery enough every day without plugging in to make the trip. Can I still be proud and say I did it "basically" on my own...? Or is this just a pipe dream and re-charging the battery manually everyday just too hard? Will I just use too much power and would not be able to re-charge? I guess what I'm asking , has anyone gone on a trip with an electric assist bike and managed something like this??
EDIT; if this is in the wrong part of the forum please move to road cycling or where ever...
Bikes: xtracycle, electric recumbent, downtube folder and more
If you are asking, can you recharge the bike by pedaling it, then the answer is no. That will become apparent as soon as you try it. We are so used to cheap power that we don't realize what it takes to charge a battery. If you want to do this without plugging it in, use a non-electric bike. It will be tremendously lighter and easier to pedal and people do it all the time.
That's pretty much my answer. Pedaling with the BionX in easiest regen mode is a fun spin-bike type of thing but I wouldn't want to do it for a long ride. Any higher regen mode is not fun. And leaving it in 4 is pretty good theft protection unless the thief knows how to undo it.
Last winter I had the bike on the trainer with half the bars showing. In regen level 1, it took the equivalent of 30 miles at 12mph to get full bars. Next time I did it in regen level 2 @12mph and got up to all bars after 15 miles. You can extrapolate with my observation but regen 3&4 are impossible unless you are going down a hill.
Bikes: 2012 Kona Lanai
That's the same figure I'm getting too.
[HR][/HR]
If we don't make changes to our use and abuse of energy, Mother Nature will make it for us.
Be a part of the solution to Climate Change instead of a contributor.
Soylent Green is People!
[HR][/HR]
OK, I guess I will just have to try it and see... By knurly's numbers there maybe a chance... Maybe as good as... 391.5 billion to 1...
I'd like to go camping but I don't like the thought of leaving my battery in need of charge over night. Don't think you can charge your battery with a good downhill at regen 4 neither. You'll know when protective circuits kick in when the battery can't take the charge, even the brake regen will be ineffective. If it was me, I'd get a trailer and bring along another battery. You can charge your batteries whenever you see a laundromat or if you find an acceptable hostel, or whip out your dad's credit card for a motel.
Since the odds are totally against your favor, perhaps, it is best to work on your endurance and make sure that your bike is just as fit.
Bikes: Schwinn Empire XL
ok the max rang is 37 miles in assistance mode level 1. So if you ride it untill the battery is half dead then ride it in regen mode 1 for 30 miles then you be back to full. So you'll be riding for 18.5 miles with assistance mode level 1 and then 30 miles with regen mode 1. Do this for 21 times and you'll be there.
I don't have one but I bet it takes many more miles to recharge than it took to discharge.
DAY 1; 75 KMs finished with 3 bars down, had to re-charge
DAY 2; 74 KMs finished with 2 bars down, had to re-charge
I need to figure out how much to "use" the power mode as compared to how much I can regenerate in a particular day... But things are not promising so-far... I "KNOW" I can ride the bike without any power for the whole day but it's sooo tempting to use it up hills that's it's going to be an up-hill battle restraining the use of assistance on the hills... ...
Not exactly "non-charging", but at 20mph(32kph) you could ride for 5 hours (100m/160km), rest for 4 hours to charge, ride another 100m/160km (5 hours) and recharge and start over in the morning.. 200m / 320km per day would take you 5 days to travel the 1600km you want!
There's a lot of daylight in Alaska right now.
https://www.absak.com/library/average...olation-alaska
Why not charge while you sleep?
https://www.powerfilmsolar.com/rollab...r-chargers.php
Cheers
R
Cheers
R
Cheers
R
Cheers
R
There's a lot of daylight in Alaska right now...
If you have a car with you, why bother with an electric bike? I would just use a regular bike which would be much lighter and more pleasant to ride up the hills. I think you are trying to use an electric bike in a fashion that it isn't much good for. Like using a rock for a hammer, it works but there is a better tool.
Liked 10 Times
Because there is no such thing a 100% efficiency in any mechanical system it takes more energy to charge a bike than you will get back out of it. The rest will be lost as heat. If you are self charging an electric bike takes more energy to go the same distance as a normal bicycle. If you are charging from the power grid that energy is not coming from your legs and you don't suffer the energy loss.
