What to do if unhappy paint job?
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
I just wanted a nice flat black pain on my hybrid silly bike build . I got some Montana tarblack stuff , thought it would be cool , it was but it rubs off doesn't stick well and feels sticky . So I tried a matte clear coat , now it turned slightly green .
Where do I go from here , do I sand away , and repaint . What home Depot spray paint should I try . This is a simple cheap build I'm not getting it done , I'm a spray and pray !!!!
you got some really good spray paint kinda surprised it comes off, might just need a light sanding so it sticks?
Quoted: 169 Post(s)
Liked 84 Times
Is everything off of the frame?
Strip down to bare metal. Edited to remove Sand
If it is a steel frame, then typical rattle can primer. 2 coats and let dry. If aluminum, I'd suggest an aluminum primer as it adheres better.
Get some 600 grit sandpaper and lightly scuff the primer.
Respray with as good of a flat black paint as you can find.
Flat paints do tend to buff out and get shiny. Just their nature.
When you do all of this, also paint some other objects so that if you have to do a matte clear on it you have a test piece.
FWIW, I have top quality spray guns and materials on hand so my paint jobs tend toward optimum quality.
did some reading on the tar black since i didn't recognize that specific montana line. could it be because it's a bitumen based paint, might not have same adherence as typical cans.
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
I thought Montana spray paint was one of those geared toward graffiti or mural "artists" -
Beautiful colors, for sure, but I'd question durability on something meant to be handled, like a bike frame.
i honesty think it's the fact that this particular blend is a bitumen base, that is also why it turned green, it reacts differently with other paints.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
'Sanding' is probably the worst way to remove paint. Media blasting (if you know someone or a business that can do this cheaply) or chemical paint stripper (toxic AF but it works) will get you down to bare metal.
Tremclad or other 'rust paints' are widely available in many colours and bond well to bare steel.
Likes For Wilfred Laurier:
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
i tend to dabble in graffitti and have sprayed bikes with graffiti cans in my case molotow. the thing about graff paint is usually much higher pigment ratios and usually more durable adherence and color. after all 95% of their customers are still doing illegal painting on anything and anywhere. idea is to make sure it will stick, so it will be hard to remove and to keep the colors true without fading.
As I said, the colors are outstanding with those paints, but I always assumed they were meant for a rough, porous surface, like a building wall (Although a railway car might not be considered porous), and that they might not hold up on something smooth and handled often, like a bike.
Do the paints have any sheen to them, or would they need a clear coat for gloss?
Quoted: 6193 Post(s)
Liked 4,808 Times
Does help to know what your paint is intended for before you use it. This paint has nothing that you'd want for a bike. It never was intended to be a durable surface. It's for art.
This is interesting - You've actually had good results on a bike frame with that kind of paint ?
the whole thing about graffiti paints is it needs to stick to anything and everything and have the best possible colors not just porous surfaces. Specially considering some of the spots that give you the most rep are all smooth surfaces (train cars, truck cabs, highway direction signs, all either smooth metal or other smooth composite material.) As for the sheen they usually do not have any sheen it's usually flat colors, but there are some gloss lines out there if i remember correctly. there is availability of both matte and gloss clearcoats from all the major brands.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
Fortunately, paint stripper takes rattlecan paint right off. Don't ask me how I know this, but I have lots of experience trying to fix botched rattlecan paint jobs.
I fear that sanding would only "smear" the paint, and cause a lot of unnecessary work and mess.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
As pointed out above, Montana paints are for graffiti on concrete. They claim an "ultimate urban street calligraphy experience". Tarblack is bitumen based and probably never really drys. It certainly is not a good paint for bikes.
Use paint products formulated for automotive or bike use. Strip all the crud that's on there now down to metal (stripper and a wire brush, or media blast). Mask threads and interference fits. Then prime, basecoat, and clearcoat, using the times between coats as recommended. You can probably wet-sand some coats (600 grit wet-dry paper). Wipe down thoroughly before every next coat.
Quoted: 319 Post(s)
its a felt full aluminum frame yes i see the tarblack was a bad choice but it looked so cool lolol , if use a paint stripper how should i do it , outside in the yard over a kiddy pool , i have never done this in my life ????
Sophomore Member
Liked 1,057 Times
At minimum you would want eye protection, good rubber gloves, and a wire brush. I like the aerosol stuff, it's similar to oven cleaner, let it foam up for 15 minutes or so, until the paint has lifted, then wipe the paint off with paper towels, in sheets hopefully. Then the use wire brush for nooks and crannies. Needless to say, this stuff will burn the crap out of your skin, about as easily as oven cleaner would, so watch out.
This is the stuff they have at the local Wallyworld. One can might do it, I'd get two to be safe.
I've heard of some people putting plastic wrap over the stripper, to let it work better as it's foaming away. I tried this, but only made a mess, and didn't seem to help the paint stripping process much.
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Bitumen is tar, no wonder it didn't dry. It's used in roads surfaces and roofing... Probably meant for roof and driveway patches. I would see if there's a specific product that will make removing it easier. That being said, any of those goof off, goo gone, citrus type strippers should work.
I would use a large pore 3m pad so it doesn't get gunked up to quickly.
