Ulock mounting options
Quoted: 20 Post(s)
Hi All, Has anyone heard of aluminum ulock mounts? I'm not really finding any online. I've quickly broken three plastic ones with standard use. They don't seem very durable at all. Or if anyone has any creative ways to mount your ulock? Thanks!
Bikes: Norther Klickitat Pass, Masi Giramondo 27.5, Soma Grand Randonneur
Quoted: 39 Post(s)
Liked 59 Times
I don't know what kind of saddle you use or if you regularly travel with a saddlebag, but I had a lot of luck with THESE before switching to a large randonneur bag. They rattle a bit on bumpy roads and I added a securing loop up top after having one bounce out over some VERY rough tree roots but generally speaking I found it to be a really good solution.
This is how I carry mine when I roll out with full battle-rattle. Lets me pack more stuff inside the pack itself (groceries, souvenirs, etc). Alternatively I slip it inside the pack, which has a pocket inside the main chamber that keeps it from getting tangled with whatever I have inside, just with less room to work with.
Tubus used to be offering a Locc rear rack U lock mounted just inside the left side..
twofish lockblocks
twofish lockblocks
Quoted: 18397 Post(s)
Liked 15,493 Times
The 2007 edition of Cycle Oregon spent one night just outside of Cottage Grove, OR, which is where the Homecoming Parade scenes were filmed. There was a shuttle bus into town so the GF and I went to check it out. I took a photo of an old restaurant sign. When I watched the film again some time after that I noticed that the same sign can be seen in the film.
A friend, I met, here, later, was a stunt double for one scene ,
doing the scramble to the roof , as "Bluto" Blutarsky, during the Parade Scene..
Quoted: 20 Post(s)
Cycleway town
The stress on a mount depends vastly on how it's fitted, and what load is put on it by the lock as a result. Mount it right and you can put a foot in the lock and stand on it. Mount it wrong and all the weight of the lock will be putting a nasty leverage on it, with inevitable results.
Bench vice and Steel workers angle grinder cut off wheel ...
the air powered ones is what the shop uses,
Shipyard , the hose was to a big air compressor on top of the drydock..
Seen a web shot of someone accessing the power from a street power pole and using a grinder ..
In NYC , people walked by never said a thing..
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,956 Times
ABUS makes some of the best U-lock mounts for their quality locks. Other companies see mounting as an afterthought ABUS sees it as part of the lock. If you are breaking those you should reach out to ABUS because that is unlikely to happen. They typically break their test rig before the lock mount. However if you have a rack you can get the Highland Fat Straps and bungee it to the rack fairly easily or put it in a pannier. Or get an ABUS Bordo and they are super easy to carry on a bike.
Clark W. Griswold
Liked 3,956 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
Recent OnGuard U-locks come with useful and sturdy plastic mounts. No problems in more than six months of regular use.
I never got around to messing with the fussy Velcro strap mount that came with my Kryptonite Mini 7. I took off the doodad that clips into the mount, so I can slide the lock into a pocket more easily. I might see if I can repurpose that Velcro strap mount to work with a light or video camera.
