About my 105 pedals and $5 SPDs
Quoted: 166 Post(s)
Liked 27 Times
Hey all. So, I finally took the plunge and bought my first pair of clipless pedals, 105's. I jumped for a nice pair of road shoes (Lakes.) Now I can see why so many riders use clipless. I "feel" more powerful on the pedal, in some indescribable way. More connected. The only issue I find is that the pedals don't fully 'right' themselves after I unclip. I have to toe the clips over and then clip in. I was under the impression that Shimano's always right themselves to align with the cleat. I selected Shimano over Look because I thought that Look pedals tend to turn upside down when unclipped. Am I doing anything wrong with my 105's?
Also, I was in my local thrift store today and came across a set of brand-new SPDs (PD M530.) Unused. Got them for $5. They even came with the instructions.
Likes For ArgoMan:
Quoted: 682 Post(s)
Liked 453 Times
Look are weighted so that the cleat (usually) hangs vertically and you toe them forward as part of clipping in. Sounds like your SPDSLs are the same.
Likes For choddo:
Quoted: 3259 Post(s)
Liked 2,099 Times
Your experience is how the pedal works, you have to use your foot to get the pedal to rotate to where you can clip in. Is why many folks say why bother and use SPD mt pedals.
Likes For Steve B.:
Liked 2,099 Times
Method to My Madness
Quoted: 1972 Post(s)
Liked 1,494 Times
That is a great deal and the pedals are calling for a gravel bike to be assembled around them, especially since it sounds like you should be able to get the hang of SPD-SL for your road bike.
Bikes: SL8 Pro, TCR beater
Quoted: 994 Post(s)
Liked 588 Times
The heaviest part of the pedal (the back where the clamping mecanism is) should always be pointed towards the ground because of gravity. It helps sliding your cleat forward in the pedal and then clipping the back. Some of them don't move as free as others and you may end with pedals ''stuck'' in another orientation.
Takes a while to ''get it'', but once you do, it becomes natural.
Quoted: 4453 Post(s)
Liked 4,916 Times
Quoted: 138 Post(s)
Liked 133 Times
I rode flat pedals on my road bike for a number of years before transitioning to clipless. The difference was a dramatic difference in efficiency. Can't believe I ever rode without.
Likes For WaveyGravey:
Quoted: 6234 Post(s)
Liked 4,837 Times
I use single sided PD-A520's. Which are also SPD. Neither of the two sets I have moved freely enough when new to put themselves into the proper position to make it easy to clip in. But after a 100 miles or so they got better quickly. So give your pedals a chance before you start getting annoyed about them not righting to the proper position.
Also, when I re-lube them, they are stiff for a while until all the excess grease get pushed out of the way.
Perhaps if I bought the more expensive Ultegra or DuraAce they wouldn't need the break in period. But they don't make them in SPD.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,444 Times
IME, the toe flip becomes natural, same with clipping in and out, takes some time and experience. The flip is still necessary with dual sided spd pedals. The thing I do not like is the toe area getting significant wear from doing the flip. Even shoes with a toe cap show the wear. It is an aesthetic thing, I wind up using shoe polish or a marker pen to mask it.
The drawback on the spd-sl’s is twofold, the cleats wear out much faster, and it takes a low number of steps to speed that up dramatically. To mitigate that, a cover for spd-sl cleats works well. One just has to remember to bring them on a ride, and to put them on. Obviously, if you don’t get off the bike, not an issue.
Likes For delbiker1:
Liked 1,494 Times
For double-sided SPD, you can buy XT or XTR.
Liked 1,494 Times
For me, the most noticeable difference in going from flats (with pins) to SPD-SL was more comfortable feet from wearing and pedaling with CF-soled shoes, which have hardly any flex and no compression.
Liked 4,837 Times
I'm still happy with the PD-A520's I bought in 2016 and 2017. They still work. All I've done is re-lube them once about 3 years ago. I guess it might be time to re-lube them again.
Quoted: 166 Post(s)
Liked 27 Times
I can't say why, but it feels like I'm getting more out of every stride with the clipless pedals. I "feel" faster. I'm sure some of you understand this. Maybe it's the shoes? Before switching I wore a pair of rubber-soled, flat Adidas running shoes. Narrow and tight, but with some cushion. I was using MKS campy race reproductions with the clip attachment, but no straps. Very easy to get in and out of, very secure. And I did feel attached to the pedal. So maybe the difference can be attributed to my new Lake shoes. Very expensive, but worth the money, I think. Solid platform. This is for my race bike that I'll be using in an upcoming Tri. For my everyday bang-around bike, I think I'll keep a set of the MKS pedals on it.
When clipping in on the SPD-SL I don't use the toe of my shoe, rather I use the cleat itself by catching the front of the pedal to push it over and then just press until it catches.
Likes For TiHabanero:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,444 Times
The shoes and pedals likely likely give you more efficiency in the pedal stroke, especially changing from shoes with a lot of flex. That may give you a little more speed. The “feel” of being faster could be, in part, the placebo effect. That can also play into the actually being a bit faster. The mind is a powerful entity.
Liked 4,837 Times
So sure, if your cadence is improving and your feet confidently held on the pedal then you will be faster. And perhaps you naturally pull up with the other leg which also adds power to the crank that you can't do without foot retention of some sort.
Stiff soled cycling shoes are better for power transfer to the pedals. It use to be that SPD shoes weren't thought to be stiff enough, but I think today many are. I still use SPD on my road bikes and don't have any intention at the moment to go to anything else.
Totally! That, and I'd had an unfortunate incident where my foot slipped off the front when I was out of the saddle, giving me a chainring tattoo...😁
Liked 4,916 Times
That’s a bad idea and ineffective, although there are guys on BF who are totally convinced that they produce power by pulling up on their pedals.
Likes For PeteHski:
Quoted: 166 Post(s)
Liked 27 Times
I saw a video on YouTube that very technically compared clipless to flat pedals. The conclusion was that difference in power output was negligible, if even present. Made me feel really good about keeping with my old-school Campy pedals with clips....until I took the plunge and bought some 105s. I don't really know if there is any real difference in my ability to create power, but it just feels better. Maybe its the shoes?
Advocatus Diaboli
Quoted: 4752 Post(s)
Liked 1,537 Times
Likes For Sy Reene:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 414 Post(s)
Liked 941 Times
Your calves and hamstrings can contribute about 25% of your crank torque, provided you are clipped in, of course.
Quoted: 2502 Post(s)
Liked 2,980 Times
Certainly works that way for me. On the rare occasions that I take a bike out that has conventional pedals and toe clips, I'll usually experience, at least once, one foot violently flinging backward and up when I'm putting power down with the other to, e.g., sprint up a short hill.
