Quick release disc hub recommendations?
There are the typical suspects like dt swiss, white industries, and hope because they have replaceable endcaps/axles. I'm looking for something more interesting than dt swiss and lighter than WI or Hope. Nice QR disc is tough to find now so interested in used options perhaps. Anything from back in the day a teenager might not know?
Expired Member
If you don't get the info you want after a few days you might have this moved to MTB. They would have had a longer run of QR disc than Cross bikes.
I am potato.
Liked 1,728 Times
Extralite, Tune, Enve, Chris King, Bitex, Carbon-Ti There is no shortage of nice hubs out there.
I like Extralite. I have several. Massively cheaper than DT and their heaviest hubs are lighter than the lightest DT. The caveat though is the road hubs have a 1:1 drive ratio restriction. Their mountain and gravel hubs have no restriction. In either case, they require more frequent maintenance than you probably expect. It's not hard. Remove freehub, clean & apply a few drops of oil. Just something to keep in mind.
As with all premium hubs I recommend monoblock cassettes so as to avoid biting the free hub. But, if you absolutely must use cassettes with individual cogs, White Industries with their standard issue titanium free hub is the way to go.
Car dependency is a tax.
Likes For base2:
Likes For Koyote:
Sunshine
Liked 7,720 Times
What does 'more interesting' mean?
Anyways, bitex hubs are light, reliable, affordable, and come in many colors if that is what you are looking for. They come in a 135mm QR option.
https://www.bikehubstore.com/product-p/bx106f.htm
https://www.bikehubstore.com/product-p/bx106r.htm
Likes For mstateglfr:
Liked 458 Times
Sunshine
Liked 7,720 Times
https://www.bikehubstore.com/product...n-cld-axle.htm
https://www.modernbike.com/product-2...xoCCoYQAvD_BwE
https://www.universalcycles.com/shop...RoCg7QQAvD_BwE
Buying from bikehubstore, you could request that the hubs be set up that way. The store reportedly does a lot of 1off things like that.
I must be blind because I didn't see they had the rear hub for that set as well. Love bitex. thanks for the link
Chris King no longer makes QR disc hubs, sadly.
Industry 9 Torch hubs have optional QR endcaps.
You mentioned WI and DT Swiss, and those are good options. (Not sure what is uninteresting about the latter.)
Onyx Vesper has all options, but it is not considered light. (There are better places to save weight.)
Likes For Polaris OBark:
I never thought of using bike hubs to express my individuality. When it comes to hubs, I'm looking for smoothness and reliability -- and you see so many DTS 240 hubs because they offer those traits.
Expired Member
The suspense is building! What's the bike that rates "interesting" and extra light hubs?
Got my eye on a Poprad frame a friend is selling and I'm building it on paper to see if I'll be happy with it before I get it. As for the weight thing, I'm justa bit of a weight weenie. Finally making enough money to buy carbon rims so I want a light hub to go with it.
Likes For trashbiker:
I am potato.
Liked 1,728 Times
You aren't going to find a lighter tubeless-disc wheel set at any price. But, you may find a lighter if you can live with tubular and double your budget.
For cassettes, I use Edco Monoblock because I like Shimano compatible free hubs. But you can get XDR if that's your jam.
To save a little dough ($350) over the above wheel set and run 38-60mm tires and add a 90 gram weight penalty you can use We Are One Revive Rims. They come in as many as 32 hole drilling if you'd like an even more robust wheel. I have a 28/32 set made with White Industries XMR hubs (& Berd spokes, again) that clocked in at 1200 grams.
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Liked 192 Times
SNIP
Cheers, Mike
Cheers, Mike
Liked 192 Times
The Exalite website has some interesting stuff. Thanks for the link. They have a "coming soon" vintage section. Can't wait.
Cheers, Mike
Cheers, Mike
I am potato.
Liked 1,728 Times
Under a ratchet/pawl system the torque puts the pawls under compression. Components under compression can withstand a lot of load.
The DT Swiss style mechanism uses 2 toothed faces spring loaded to press against each other (one in the free hub, the other in the hub shell) and while there is as many points of engagement as you'd like, each ratchet ring is keyed into it's respective part of the hub with splines. The torque is transferred via sheer force on the face of the splines instead of compression like the pawl system. Eventually the splines (usually those on the softer aluminium hub shell) gather wear, and that wear is especially accelerated with high forces and if debris/grit is present. Hence the frequency and ease of maintenance requirements, and at least for the road version of the Extralite hub, the drive ratio restriction.
1:1 is still a 50/34 mated to an 11/34 cassette, so it's probably not a big deal on road. But, for gravel, 40 or 42 cassettes mated to much smaller than 34 chainrings are common & would generate much, much more torque. Hence the gravel/mountain specific version with additional splines and multiple ratchet ring assembly clocking options so that the shell can be "worn out" multiple times over and the rings easily and readily replaced with new if maintenance is neglected.
Likes For base2:
Liked 192 Times
It has to do with transferring the torque from the free hub through the freewheel mechanism to the hub shell whereby the torque tensions the trailing spokes causing wheel rotation.
The DT Swiss style mechanism uses 2 toothed faces spring loaded to press against each other (one in the free hub, the other in the hub shell) and while there is as many points of engagement as you'd like, each ratchet ring is keyed into it's respective part of the hub with splines. The torque is transferred via sheer force instead of compression like the pawl system. Eventually the splines gather wear, especially accelerated with high forces and if debris/grit is present. Hence the frequency and ease of maintenance requirements, and (for the road version) drive restriction.
Cheers, Mike
Cheers, Mike
I am potato.
Liked 1,728 Times
I've always of the mind that if a company puts in a warning limiting a product and potentially limiting is use case (and limiting it's customer base or sell-ability) I tend to think it's for good reason. Hence the mention of the limitations on that one particular hub designed for that one particular (road) use.
Anything can be abused, I guess. The question is always how far, for how long?
Liked 192 Times
I built a 950-something gram tubeless disc wheel set using Stan's Grail CB7's, Extralite HyperSmart3 front & rear hubs and Berd Spokes. $1200 for rims, $600 for hubs, & $750 for the spokes and the build service.
Cheers, Mike
Cheers, Mike
I am potato.
Liked 1,728 Times
https://www.bikeforums.net/22604309-post23.html
R&E custom frame. Steel. Mostly Tange Prestige, &/or Velo-Spec tubing I think.
The wheels were already mentioned.
Darimo seatpost manufactured for me.
Ax-Lightness saddle & handlebars.
Extralite stem, headset spacers, headset, QR skewers, chainrings & chainring and other misc bolts.
THM Clavicula SE crankset with power meter.
Dura-Ace 9100 shifters & derailleurs.
XTR hydraulic post mount brakes with Carbon-Ti 160/140 rotors.
Whiskey 7 fork.
Connex 11SX stainless steel chain.
GP5000 tires.
Carbon Works bottle cages.
Whiskey 7 fork.
GP5000 tires.
Liked 192 Times
Whiskey 7 fork.
GP5000 tires.
Whiskey 7 fork.
GP5000 tires.
Cheers, Mike
Cheers, Mike
Likes For PromptCritical:
Liked 493 Times
The old school in me thinks an old XT or XTR disc hub would be fun to build around.
Where are you finding carbon rims for the build, though? Even on AliExpress carbon rims are pretty pricey.
