Gearing question
Gearing question
Is there any advantage to running a larger chainring?
My current gearing is 45X16 (73.9 gi).
48X17 is very similar at 74.16 gi.
Also, a stiffer crank should make a higher gearing (more gi) easier to pedal, right?
Dave
Dave
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times
Not really any advantage if the gear inches are similar unless you just want a new crankset.
A stiffer crank won't really make it that much easier to pedal. A higher quality bottom bracket might.
What kind of bike / crankset do you have?
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
Advantage of using larger chainring and sprocket: lasts longer because wear is spread over a larger number of teeth.
Disadvantage of using larger chainring and sprocket: weighs slightly more than smaller components.
Currently running a Kilo TT with Sugino VP130 road cranks. I need to buy another crankset to build up a single speed for my Dad (going to put the Sugino on the SS) so I figure it's time for new crankset. A lot of the ones I've seen have. 46-49t chainring, which made me wonder if I should run something bigger.
Quoted: 365 Post(s)
Liked 457 Times
Ok. In that case putting on a larger cog would make sense to keep the same gear inches.
Good luck with the build!
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
45/16 is what I use, although the effective gearing is lower due to smaller wheels. If I had the chainstay clearance, I'd be on 48/17!
