i can feel/hear rattling around headset area
Old 08-04-10, 01:22 PM
andiakim
when i'm riding, especially over bumpy roads, i can feel/hear some rattling around the headset area. i know for fact it's not the stem/handlebar because i've already tightened them. also, when i lift the front wheel and try to shake the headset up and down (by holding onto the handlebar), it moves up and down very slightly (very little).
is this something that is normal? on smooth roads i hear no rattling.
andiakim is offline
Old 08-04-10, 01:39 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
I thing you self diagnosed it - you need to adjust and tighten the headset. Headset noise and rattle is not normal.
For threadless headsets: https://www.parktool.com/repair/readhowto.asp?id=65
For threaded headsets: https://www.parktool.com/repair/readhowto.asp?id=127
MudPie is offline
Old 08-04-10, 02:26 PM
andiakim
just got back from lbs. forgot to mention i installed a new stem previous to this problem. mechanic said i need another spacer to leave a small gap at the top.
andiakim is offline
Old 08-04-10, 06:01 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Yes, threadless headsets need about 1/8" (3mm) gap between the top of the stem and top of the steer tube. The gap is needed to ensure you can pre-load the bearing system without bottoming out. Anyway, sounds like it's fixed.
MudPie is offline
RocThrower
Bicycle Mechanics
5
07-24-14 05:08 PM
rdtompki
Road Cycling
5
01-28-13 09:12 AM
Deetox
Bicycle Mechanics
6
10-30-12 11:03 AM
greensprout
Bicycle Mechanics
6
06-30-10 05:24 PM
compactdan
Bicycle Mechanics
5
01-22-10 06:33 PM
