20 inch tire confusion
Quoted: 137 Post(s)
Liked 51 Times
Hi to all, I'm a bit confused about tire sizing. Currently on my zizzo I have 20 x 1.50, 406 tires, but I want a narrower tire, something like a 20 x 1.125 or even just 20 x 1. Ok, easy right ? Not so much, first problem, selection seems very limited, 2nd problem, what I do find is 20 x 1 1/ 8 or 1 3/8 and labeled not 406 but larger. Will they still fit my wheel ? Is a 20 x 1 even made ? Thanks for any help.
Quoted: 801 Post(s)
Liked 249 Times
Always the issue of the wheel sizes in inches that are confusing!
You must look at the wheel sizes in ETRTO mm that gives the rim diameter and not the tire outer diameter.
You need ETRTO406 tires, there are several narrow tires options like the Schwalbe Pro-one 28-406, Schwalbe One 28x406, the excellent Continental Contact Urban 32x406, the Panaracer Minits Lite PT 32x406.
Likes For Jipe:
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
The confusion is because wheel size is a designation for bicycles, not tires. Rim size is a designation for tires.
Quoted: 801 Post(s)
Liked 249 Times
The confusion comes because there are several 16" (ETRTO305, ETRTO349), several 20" (ETRTO406, ETRT451) several 24" (ETRTO507, ETRTO520, ETRTO540...), several 26" (ETRTO559, ETRTO571)...
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Likes For Pinigis:
The convention with 20" tires is for the widths in 406 size to be expressed in decimals (like your tires) and for 451 size in fractions (like 1 3/8"). As stated, only the 406 tires will fit your rims.
Likes For Trocadile:
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
What I love about standards,
is that there are so many to chose from.
Likes For bikebikebike:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
Likes For LesterOfPuppets:
Quoted: 801 Post(s)
Liked 249 Times
It means first that the tolerances on the diameter is tighter.
But these tires have also an internal airtight layer that for some brands isn't very compatible with an inner tube, each brand has his own TL technology.
Even for a single brand, there are several TL technologies different for road tires and MTB tires because the pressure of road tires is much higher than the pressure of MTB tires.
