Do I have to keep the wheels?
The bike size charts say a 29er frame is the right size for me at 6’ I do have the 29er bike now but do I have to stick with the 29er wheels?
I have a set of 26” sturmey archer wheels I want to throw on it. Leaving the 29” wheels mainly for off road use.
but does that throw off the sizing?
Quoted: 4415 Post(s)
Liked 1,567 Times
How are Sturmy Archer hubs going to fit into MTB dropouts designed for wider hubs and a thru-axle? How are you going to brake with no discs?
Other than that, the steering geometry and pedal clearance will be all screwed up.
And this is not a bike fit question.
Likes For Kontact:
Quoted: 6198 Post(s)
Liked 4,814 Times
Every sub-forum here has a description of what it's about. This is the one for this sub-forum.
Though I firmly believe that the sub-forum should be called "Fitting You to Your Bike". Or something that isn't as ambiguous as it is now.
While different size wheels may help you fit on the bike, the information about changing the wheels on that bike to a different diameter is better suited for the Bicycle Mechanics sub-forum as more people that are mechanic's and DIYer's will be in that sub-forum to notice and answer your question. Though some do come here and I think you got a mechanic and me a DIYer to respond here, wouldn't you like to hear the views of more mechanic's and DIYer's so you can pick what you thing best for you?
I don't think the change in wheels will throw the sizing of the bike off for you. It likely will make the bike more sporty handling. So if you don't like sporty handling, which some people call twitcy, then that's a consideration for you.
Fitting Your BikeAre you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Quoted: 3242 Post(s)
Liked 2,089 Times
If the 26" wheels use the same axles and everything is disc brake, it could work. Might handle weird. Best solution is look for a deal on compatible 29" wheels and throw some street tires on them.
assumptions aside..
Your right!
Switch from 175mm cranks to 165
throw the wheels on
and rise the seat a 1/4 inch
I should be good
Quoted: 1858 Post(s)
Liked 664 Times
Well, I agree, but since Kontact alluded to thinking about what it actually might take to make them work and to think about if the wheel swap is really just a swap:
the way a Sturmey AW hub fits a frame, they don't all fit the same.
Are the 29er wheels for derailleur gearing? Any issues there if you swap in the wheels from a Raleigh 3-speed?
The front wheels should be no problem, except the fork end spacing might not be a match,
the brake shoes might not match up to the smaller radius 26" wheels.
In the back if you don't transfer the trigger shifter to the 29er you won't have any 3 speed shifting.
If you don't get a narrow-width Sturmey sprocket the narrow MTB chain might not run smooth.
Will teh rear chainline of the Sturmey hub line up with the MTB front sprocket? If not you might have the chain throwing.
Will the unused rear derailleur be somehow in the way?
Finally, will the brake shoes line up with the rear wheel?
This could easily turn into a lot more than just a swap.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
You have to squeeze a 135mm rear triangle about 20mm in, to get the Sturmey axle nuts to engage any threads. A suitable single-tab anti rotation washer (better a mirrored matching set) needs to be found to prevent the ale from wandering in the dropout. If this is a newer RXL Sturmey hub, then the axle width isn't nearly as much of an issue, as they are spaced at 135 OLD, but the anti rotation thing is more important since the radial shifted hubs need more precision in axle placement for shifting. We still don't know how this bike is going to stop though...
Likes For blacknbluebikes:
Quoted: 2497 Post(s)
Liked 740 Times
Seriously? Personally, I think you're having us on. I'd check your post history if it weren't so late. What's with the crank swap? For the love of God, why? S-A makes a LOT of hubs. And, believe it or not, a couple of them slide into a 135mm OLD dropout just fine. The CS-RK3 (don't quote me) even is a disc hub. But the main issue with your o.p. is the very first sentence: "The bike size charts say a 29er frame is the right size for me at 6’". What, there aren't bikes that fit 6' riders that don't use 29" wheels? Sounds like what you need are "all road" tires that can do a bit of everything. Any other plan is simply silly.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Likes For Eric F:
it’s not a frame size but with a tad of coherentness lol you know what I’m talking about
a little more common sense and a little less of a politically correct imagination lol
too much imagination being used in here. Because I only brought up wheels by sturmey archer I never said with matching hubs lol
all good. Know how it goes on here
Quoted: 2490 Post(s)
Liked 2,958 Times
If the S-A hubs fit the frame, and the brakes are compatible, all you need to worry about is the reduced ground clearance for the pedals, maybe.
Habitual User
Liked 8,099 Times
What is "politically correct imagination"? Using parts that are designed to work together isn't being "politically correct". Generally, it leads to having a bicycle that functions efficiently and safely.
Frame sizes for 29" wheels range significantly, fitting people of a wide range of heights. Same with frames for 26" wheels, or 650b wheels. A 6' tall person could ride any of those wheels sizes (and others) with no issues. However (as others have noted), putting 26" wheels on a frame built for 29" wheels brings up a bunch of compatibility - and possibly geometry - issues that can't be ignored if you want a reasonably functional machine.
All that said, people do all kinds of unusual things with bicycles. Good luck.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
If you're looking at a chart like this, it's only for department store bikes. With slightly nicer bikes you can get a 29er model with choice of frames sized to fit most folks from 5'4" to 6'6" You can also get 27.5" and 26" wheeled bikes with frames to fit someone 6'0"
Share some good photos of your existing bike and 26er wheelset and we might be able to tell you if you can fit those wheels into the frame or what changes might be required to put them in the frame. If you can get those wheels into the frame the bike will handle much differently than it will with 29er wheels and the pedals will be lower to the ground than what you're used to.
You'd most likely be MUCH better off buying wheels that closely match those that came on your 29er instead of fooling around with 26er wheels.
Habitual User
Liked 8,099 Times
Likes For Eric F:
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
The final two entries on the right-side contradict one another as well.
Also, without knowing tire width, the wheel diameter isn't all that informative.
If OP wants smaller wheels, a nice pair of 27.5" might be ideal, and as they are getting unpopular, might be slightly less expensive.
Liked 1,567 Times
so a senior member is going to chime in and share the perception that wheelsets do not come with hubs from other companies.
Thats great
ive never been so enlightened
alright
for the admins i wont put your incoherence into more words than I have
Thats great
alright
Bikes: everywhere
Liked 7,697 Times
AFAIK S/A makes hubs, but not rims or spokes, so S/A wheels basically means a wheel set with S/A hubs. I can't fathom a way of having an S/A wheelset without S/A hubs. Not sure of all this, but maybe a C&V guy can chime in with verified info
Habitual User
Liked 8,099 Times
How did your experiment with 26" wheels go? It's been over 6 months since this was initially posted. Surely, you should have some experience with your attempt to fit those wheels on your 29er frame by now. I'm curious to hear about the results, and maybe see some pics.
Liked 1,567 Times
What kind of SA wheels don't come with SA hubs?
Could you please answer that question?
Some help: https://www.sturmey-archer.com/products
A senior member asked you a polite question:
stop guy guy with your coat of sugar
I know the difference I’m almost against my will annoyingly aware or the condescension.
Or I would had been asked what hubs do I have in my wheels.
Maybe they are not sturmey archer wheels tho it’s possible that this item is using the sturmey archer name is bc the set uses a sturmey front hub idk
heres the image and reason why I refer to them as sturmeys
but ive swapped out the hubs for a dynamo and alfine 8 hub
I did try and put them on my 29 in frame but the rear did not have the spacing for the 8 speed so it was a no go. Then soon after I was on the local trail and took a tumble. I bent the fork a tad. Since then I haven’t really been riding that* bike.
I’ve been riding the 20”
