Seat Post Collar Size.
Bikes: 2017 Cannondale Carbon Synapse,2016 Cannondale Beast of the East, 2014 Cannondale CAADX, 1990's Specialized Hard Rock
Quoted: 16 Post(s)
Need Seat Post Collar Size. The seat post says it's 31.6 mm, So a 32.0 collar should work? Cannondale Beast of the East 3.
Thanks.
Thanks.
Quoted: 2026 Post(s)
Liked 1,095 Times
You are going to have to buy measuring tools.
ID + 2 x the tube wall thickness is the OD of the tube..
generally tubing uses inch sizes, but are spoken of in metric ..numbers..
Quoted: 1438 Post(s)
Liked 1,092 Times
A 32.0mm will not work since the seat tube is certainly thicker than 0.2mm (~0.008"). You will need to measure.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Harbor Freight sells a perfectly OK digital caliper for not much.
Licensed Bike Geek
You'll need a 34.8 (35mm) seat post clamp.
Quoted: 16 Post(s)
Thanks guys, didn't think about adding the frame too.
Quoted: 2595 Post(s)
Liked 1,923 Times
IMHO this is one of those questions with "go to your LBS" as the correct answer. Buying a caliper good enough to measure to the nearest tenth of a millimeter is going to cost more than the markup a decent LBS will put on the collar.
Liked 1,095 Times
Except afterwards you will own the caliper and have it available whenever you need to accurately measure something else. Going to a bike shop only gets you the need to do it again the next time you need similar help.
Liked 1,923 Times
I know, he who dies with the most toys and all. But let's get real about cost and savings. I've only replaced one seat post collar, and it cost less than $25 at the LBS. Where can you get a decent caliper for anywhere near that? A really good mechanical one (if you can still find such a thing) is upwards of $75. The electronic cheap caliper from Harbor freight was $30, IIRC, and it took another $10 of batteries to get it working again within two years. Cheap plastic mechanical junk cost me more in ordering the wrong size part than either of the other two. So where's the savings again?
Liked 1,095 Times
Yes, "name brands" such as Starrett and Mitutoyo cost much more but are not needed unless you work in a machine shop.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Current online price for HF digital caliper is $19.99. Looks like the one I have. Functional.
cqlink
3
01-16-19 01:21 PM
