TSDZ2 Conversion - Quick Review
Bikes: '18 Trek Roscoe 8, '10 SOMA Double Cross, '12 Brompton M6R
I'm posting this because I have yet to find a dedicated review or thread of the TSDZ2 motor on bikeforums. However, endless-sphere and ****** have some good forums and discussions regarding.
I purchased a TSDZ2 motor and battery from https://recycles-ebike.com. The website isn't the best, but they were quick to reply when I had questions regarding the shipment and tracking. Overall, I received the items I ordered in a timely manner. It took about 1 week to receive the motor and about 3 weeks to receive the battery due to import HAZMAT requirements.
This is the motor I purchased: Tongsheng TSDZ2 Mid Drive Central Motor Conversion ebike Kit,Torque Sensor 48V 500W 42T Chainwheel Electric Bicycle Motor - Re-Cycles E-bikes. Total cost including shipping was $705 for both the motor and battery. There are now some kits on the website that are ~$600.
The bike I converted is a SOMA fabrications double cross, 9-speed, downtube shifters, and cantilever brakes.
I choose the TSDZ2 500W motor. Reasons:
1. The 500W motor is less expensive compared to the 750W motor, albeit nominally.
2. The 500W motor I purchased has no throttle and no special brake levers. I wanted as few inputs as possible to the motor.
3. I wanted a torque sensing motor and not a cadence sensing motor. Ultimately, this is the main reason I choose the TSDZ vice the BBS series of motors.
Good background info on the motor can be found here: https://www.electricbike.com/tsdz2-7...orque-sensing/
I've been riding the converted bike for about 1.5 months almost daily to/from work and running errands. It's been a blast! I don't have too much experience with ebikes, but my converted ebike can easily challenge any that I've test ridden before at 1/2 the price.
The install was easy and took me about 2 hours. The following YouTube video shows the basics:
. The only extra tool I needed to purchase was a bottom bracket tool for removing my old crank set . The TSDZ comes standard with the required wrench to install the motor.
The ride is effortless - you turn the crank and motor engages. The harder you push, the more power is provided. For my daily commute, my max speed is around 12-24 MPH. This range is due to the traffic I encounter on the multi-use path. I dial up assist and pedal hard when no one is around...I slow way down when there are people present.
On flat terrain, I can get the bike moving quickly with little effort. When you hit hills, you will need to pedal harder (hence the torque sensor). If you encounter big hills, you'll need to downshift. I know some people complain about this feature, but it isn't an issue for me.
Officially, the motor will cut out at 20 MPH, but you can change the motor settings to allow a larger wheel (in my case 700C) to spin faster by setting it to another wheel size (16 inch). I can hit 24-26 MPH for extended periods.
If you are looking to purchase a mid-drive kit that is effortless to install and use, I would suggest you do some research on the TSDZ2. Pics to follow (if I remember).
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
I have one on my commuter bike and my reasons for going with the tsdz2 nearly mirror yours.
I don't think you lost anything by going with 500W instead of 750W. My observation is that, in its highest setting, it seems to add about 150% of what I put in. By that, without it, on a commute, I am generally between 10 & 15 mph. With it, I am between 15 & 20 mph.
The big difference for me is that in winds that would push me down to, or below 10 mph, with the motor I am still around 15 mph. However, it does not get even near adding 750W.
In all I am happy with it for the purpose I use it for, making my commute a bit more enjoyable; yet I still get my heart rate up and I can feel my legs, I am still pushing. As was noted by the OP, I still need to use the gears.
I wanted to add, a while ago I mentioned some error codes. Then it stopped working when my daughter was using it. The problem turned out to be a poor crimp on a power-pole. Once I fixed that I have had no error codes.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Thanks for posting. Earlier this week I ordered a TSDZ2 kit to convert my wife's bike. This will be my first foray into the world of e-bikes. I'm definitely excited about it.
Moe Zhoost - You won't be sorry you purchased! Post pics when you complete the conversion.
Katysax - I just removed the front derailleur, shifter and cable. From my online research, there is an adapter for the TSDZ2 that allows you to run two chain rings, but I wanted to keep the build simple.
I just ordered a TSDZ2 with a battery. I'm excited to get this project going! Now, I just need an appropriate bike.
Have any of you who've installed this run into any issues with the bottom bracket fitting? Apparently, the "TSDZ2 Mid Drive Kits are designed to fit bikes with threaded JIS/BSA bottom brackets". The standard size is 68-73mm. I read that a lot of newer bikes (after 2012) have different bottom brackets (either wider or "press fit" or with different tapering). When looking for a used bike online, sometimes it's hard to find what sort of bottom bracket a bike has.
If you've installed this on a bike without the threaded JIS/BSA bottom bracket, what sort of adapters did you need?
Any other thoughts or considerations around fitting the bottom bracket?
Thanks!
Thanks!
Quoted: 363 Post(s)
Liked 66 Times
To try to deal with the power issue, when riding into the wind, I have a new controller and a throttle assembly. I will try the new controller first, after all, my reason for getting this motor was to eliminate the need for a throttle.
