wide drop bar 25.4 clamp?
El Duderino
Bikes: 84 Raleigh Portage, 83 Trek 620
Quoted: 7 Post(s)
I've got the Nitto Noodle in a 48 cm which I really like. I'm re-doing my '83 Trek 620 for road use. I have a Nitto Technomic 25.4 stem that I'd prefer to use if possible. I got a new 45 cm Nitto Randonneur bar for this bike, but test riding it without bar tape it feels way too narrow. It seems that in the last few years there are a lot of dirt drop bars that are very wide and have heavily flared drops, but they all seem to be 31.8. Is there anything out there that would be somewhat similar to the 48 cm Nitto Noodle, but with a 25.4 stem clamp?
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I have a Nitto Noodle 48cm just sitting here, but with 26mm clamp diameter. Drop me a PM if interested.
Quoted: 1136 Post(s)
Liked 650 Times
Check out the Rene Herse bars made by Nitto. Both are available in wide widths in 25.4. Expensive but top of the line.
Simworks Japan also has a few options made by Nitto.
Quoted: 4806 Post(s)
Liked 3,928 Times
Funny, I just bid on a Nitto 26.0 because I want that Nitto I trust so much to replace the steel stem I picked up at a swap meet I know nothing about. (I have that Nitto in 25.4!)
I'd offer you my 25.4 but I"m guessing fit (to you) might be an issue. It's a 140 mm -17 degree Pearl. I am not sure there are two more different stems!
Edit: I've shimmed 26.0 stems for 25.4 bars many times. Been a while so I don't remember what I used but it as simply thin aluminum sheet.
Ben
Ben
52psi
Quoted: 790 Post(s)
Liked 802 Times
I recently went on the same quest and the option described above was all I found in 25.4. Ended up finding a Nitto Pearl on ebay with a 26.0 clamp diameter and paired it with a brand-new Nitto Noodle rather than pay the obscene Rene Herse rates.
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
FAIRWEATHER M174 All Road Bar
I have a 46cm Noodle on one bike and JUST ordered the FAIRWEATHER for another bike with a 25.4 stem. I ordered mine from BLUE LUG in Japan and it arrived super fast, less than a full week even. Shipping is a bit pricey, but I added other small items to make it worthwhile.
https://global.bluelug.com/fairweath...ar-silver.html
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
[QUOTE=79pmooney;21629368Edit: I've shimmed 26.0 stems for 25.4 bars many times. Been a while so I don't remember what I used but it as simply thin aluminum sheet.
Ben[/QUOTE]
I use 1” wide stainless steel flat stock in 0.012” or .3mm thickness. It works quite well. I score with a box cutter and break it at the right length.
In this case, I think he has the opposite situation, so he needs the 25.4 bars. I use a 26.0 Technomic shimmed with 25.4 bars.
Otto
Ben[/QUOTE]
Otto
Quoted: 1088 Post(s)
Liked 1,205 Times
El Duderino
Quoted: 7 Post(s)
Yeah, I probably should just stick with what I know I like. So I think I'll just get the Noodle 48 for this bike as well.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
I have a pair of Origin 8 Gary bars that have a 25.4 mm clamp area and a wide flare. They are discontinued, but you may be able to find some leftover stock.
